NEW RUST DISCOVERY
Discussion in '1st Gen. Tacomas (1995-2004)' started by Andy.G, Jun 16, 2014.
  1. Jun 16, 2014 at 9:41 PM
    Andy.G
    Andy.G [OP] Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
  2. Jun 21, 2014 at 12:09 AM
    Andy.G
    Andy
    Virginia
  3. Jun 21, 2014 at 12:15 AM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Ok so you bumped it but what for? You take the bed off yet?
  4. Jun 21, 2014 at 12:18 AM
    Andy.G
    Andy
    Virginia
  5. Jun 21, 2014 at 12:31 AM
    Andy.G
    Andy
    Virginia
    Answer your question.lol
  6. Jun 21, 2014 at 1:59 AM
    DrFunker
    DrFunker Prisoner of the midget circus.
    Doc LastName: Funker
    413
    2011 DC SB OR
  7. Jun 21, 2014 at 6:47 AM
    Andy.G
    Andy
    Virginia
    I have pics of frame but getting loaded by phone takes forever with the cell service here in mountain foothills.I plan on some welding(very little). Actually think I caught this in time for fairly easy fix. Don't want to clean up too good until I get under coating in hand. Plan on using por 15 for that. Not positive on paint for finishing. From cab forward looks great on frame. Original owner must have had leaky valve cover for years. Nice oily coating [​IMG][/url [​IMG][/url [​IMG][/url [​IMG] will add more later. So for those that should do this,but are holding back I got this. 4 gas door bucket bolts,6 bed bolts(heat,heat,heat),6 mudflap bolts,bumper(easier for back 2 bed bolts),tail lights(harness removal),and a way to get bed off easily. I used a rope in tree with a come-along and a ratchet strap to each bed tie down.Only bed bolts were hard to remove. With the ratchets straps you can level bed and then come-along straight up. Unless you are lucky enough to have help.I'm doing solo!haha
  8. Jun 21, 2014 at 12:10 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Doesn't look to bad. Looks like some welding in some reinforcements after prep and removal of the cancer and you'll be good.
  9. Jun 21, 2014 at 12:15 PM
    Andy.G
    Andy
    Virginia
    Yeah pretty happy really . Truck lived in Va. for entire life. Lucky for me 1st owner afraid of snowy roads. Wish my 95.5 had looked this good.Also found drain holes in rail bottoms clogged. I have pics but won't be able to load till late night because of cell activity.
  10. Jun 21, 2014 at 12:25 PM
    TheTimmyJimmy
    TheTimmyJimmy Dumbazz
    Tim
    Colorado
    04 Tacoma DBl Cab
    Lots of lil stuff
    Love my truck but the amount of time I spend on rust prevention and removal not to mention the cost of rust incapsulator, paint, grind wheels etc..... It pisses me off. I mighht have to get a newer 4runner just so I dont have to worry about it!
  11. Jun 21, 2014 at 4:05 PM
    Andy.G
    Andy
    Virginia
    Well this is the 1st time for this frame since 1996! It is the weakest link but if I can fix easy enough it should go till almost 2030. If everything else holds up like it has it will be an amazing truck. I did absolutely nothing to my truck with no payments for ten yrs.(except normal maintenance).
    Don't get me wrong,in the end it still sucks donkey dicks in hell!!
  12. Jun 21, 2014 at 10:19 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '03 Black & Tan SR5 xtracab 2.7L 4X4
    Pretty much stock with a small lift and Timbrens
    The Tacoma rust war really sucks. I'd still have my 97 TRD if these things were made to specifications. That truck only had 65k on it when bought back. They're not the only rust buckets out there though, and at least Toyota made good, for the most part. Despite it all, I've owned four. I'm hoping my current will be around until 2030!
    Good luck with the repair, and long live Tacoma!
  13. Jun 21, 2014 at 10:34 PM
    Andy.G
    Andy
    Virginia
    They recalled my Sequoia also for frame. Sprayed it but looked like 3rd grader did it. It's a nice 03 but to much to tackle. Will have to part before it starts to go downhill.
  14. Jun 22, 2014 at 8:01 AM
    Andy.G
    Andy
    Virginia
    Here's a few pics after chipping,scraping and power washing with blaster tip.
  15. Jun 25, 2014 at 9:24 AM
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    Man that sucks Andy. I can't believe you got another one. I have one for sale in Richmond if you are in the market...
    J/K good luck with the fix.
    Brandon
  16. Jun 25, 2014 at 10:14 AM
    Andy.G
    Andy
    Virginia
    Yeah it's all good. I'm gonna fix it. Only 2 spots need any cutting,grinding,welding. Looking at por 15 or eastwood products. Like the aerosol with tube to get product inside boxed frame section. Gonna do it right! It's parked in my air cond shop. Thanks for the offer Brandon. Later
  17. Jun 26, 2014 at 7:23 AM
    JAGER91374
    JAGER91374 Well-Known Member
    Des Plaines
    3 TRD O/R
    OME 883's and Dakars, OME Shocks, Gray Wire, Deck Plate, Blacked Out Chrome, RAT Skids, BAMF BPV Bracket, Toytec Diff Drop, Braided Extended Brake Lines Front and Rear, In-Dash Nav.
    Have you considered contacting Toyota to see if they would replace the frame on that truck.
  18. Jun 26, 2014 at 9:26 AM
    Andy.G
    Andy
    Virginia
    It's a 96. They only honor for 15 yrs, if at all. My original 95.5 was way worse! Missed recall by 2 months back in 2010. Took it in and they barely looked at it,told me it was eligible. Called me back and said I was 2 months past 15 yrs. Real bitch was I bought new and paid 500 extra for frame protection. Can't count on corporate toyota for sure.
  19. Jun 28, 2014 at 9:19 AM
    JAGER91374
    Des Plaines
    3 TRD O/R
    Damn man. Sorry to hear that. Looks like you have your hands full with that repair.
    Good luck to you.
  20. Jun 28, 2014 at 9:32 AM
    kn38ms
    kn38ms Well-Known Member
    NW, FL
