New Seats
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004TacomaNavy, Apr 16, 2013.
  1. Apr 16, 2013 at 12:47 PM
    2004TacomaNavy
    2004TacomaNavy [OP] Well-Known Member
    Brian
    Oak Harbor, WA.
    04 Extra Cab 4X4 SR5
    All Pro rock sliders, U-Bolt flip kit, Shock mount relocation tabs, All Pro Billy 3" lift front and back, 2014 Tundra Bed Rail tie down system, Fuel 17X8.5 Wheels on 32's, LED front light bar, Raptor style grill W/lights, Tinted Headlights w/LEDs, ARB Dual Air Compressor W/ 2 Gal. Tank, Smoked Tail Lights, Double Din Sat radio w/ back-up camera, Redline Hood Struts, ARB Dual air compressor W/ 20 Gal. air tank, Sig P320C Security System!
    Just got done installing the drivers and passenger bucket seats from a 2009 tacoma into my 2004. A LOT better! :)
    I had to do some modification to the old mounting rails and newer seat rails.
    I am here to tell you that NONE of the mounting locations/holes line up or will fit the newer 2005 and up seat rail mounting holes.
    The new seats sit about 2" taller. It takes a little to get used to after sitting in the old ones for so long but I wouldn't trade them for anything! Unbelievably comfortable!!!
    This weekend I will finish my new grill mesh installation and post pics.:D
  2. Apr 16, 2013 at 12:52 PM
    Geosh
    Geosh Why yes, I AM a rocket scientist.
    Chandler, AZ
    '03 PreRunner DC, 3.4L
    Got pics of the mods to fit them in? Any more details on the process!
    Looks great in those tiny pics anyway.
  3. Apr 16, 2013 at 2:14 PM
    BigOly
    BigOly Well-Known Member
    Bay Area, NorCal
    14 MGM DCSB TRD/OR 4x4
    Nice retrofit and those seats look pretty comfy. I guess it must feel like having a little mix of the best from both gens, very nice! :)
  4. Apr 16, 2013 at 2:16 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    looking at the tiny tiny pics it looks like a clean install nice!!
    i am going to put some seats in my truck this weekend out of a matrix
  5. Apr 16, 2013 at 2:23 PM
    MLB007
    MLB007 Active Member
    NE Indiana
    06 PreRunner SR5 TRD offroad
    I put seats from a Camry in my 95 some years back. Worked great and were immensely more comfortable. Was able to use the stock seat bracket too.
  6. Apr 16, 2013 at 9:49 PM
    2004TacomaNavy
    Brian
    Oak Harbor, WA.
    For the install, I had to take the original mounting rials and with a 90 degree cutoff wheel, I cut off/removed the slider so I was left with a thin strip of metal connecting the front and back mount on the inboard and outboard rails.
    Then I took the new seats flipped them upside down and cut off the front and back mount brackets that are riveted to the sliders.
    Next, I installed the original rails to the floor, then I set the new seat on top of the rail and sat in the seat to align it properly, making sure I had clearance between the seat and door and the center console.
    When doing this make sure the inboard and outboard sliders for the new seat are positioned the same, front to back.
    When the seat is in the proper position you will notice that the outboard rail does not line up directly on top, this is not a problem.
    I carefully got out without moving it. Once I marked the rails and the mounts I used JB weld and clamps to bond the new seat and sliders to the mounts.
    Then I had the seats welded and I cleaned them up, repainted the newly welded metal, installed the plastic coverings.
    You will have to use your original seat belt receptacle that mounts to the inside of the seat. You will also have to straighten out the bends some that are in the seat belt bracket so it angles correctly.
    Tomorrow I will take better pics and post them.
    New pics just added below!
  7. Apr 16, 2013 at 10:10 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    phx
    01 trd
    wet okoles, icons, t/c uca,skids, skull shifter knob. Bfg at 265/75/16
    What year of camry ?
    OP. Those look nice to bad they raise up so much.
  8. Apr 18, 2013 at 7:12 PM
    2004TacomaNavy
    Brian
    Oak Harbor, WA.
    Im still working on a way to lower them or fab new brackets that will.
  9. May 15, 2013 at 9:55 AM
    SteveFaust
    SteveFaust Well-Known Member
    Poway, CA
    1995 XtraCab XL 2.7 4x4
    Hey MLB007 -- what year Camry seats did you put in your '95?
    I have a '95 Xtracab 4x4 with the 60/40 split bench and was wondering if Camry seats would bolt in / fit in the Tacoma.
  10. May 15, 2013 at 11:36 AM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    If you want to go a much simpler route I believe there is still a set of bucket seats for sale in the 1st gen marketplace.
    Somewhere in Cali too (yes, I know it's a huge state but at least it's not across the country)
  11. May 22, 2013 at 7:44 AM
    SteveFaust
    Poway, CA
    Thanks Madjik_Man -- looks like they are the gray ones and I need tan (bummer) however, I might try to work a deal as he is local for me and I'm thinking about doing a recover anyway. Appreciate the info.
  12. May 22, 2013 at 12:09 PM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    Looks like a lot of work, but NICE JOB! :D
