New shocks and AAL
Discussion in 'Suspension' started by bowhuntingaddict, Jul 14, 2010.
  1. Jul 14, 2010 at 10:21 PM
    bowhuntingaddict
    bowhuntingaddict [OP] Well-Known Member
    I have three question, to the bilstein 5100s lift your truck with the stock coilover, and if they are set at 2.5" what size AAL to I need to keep the truck level without the TSB, lastly do I need longer u-bolts
  2. Jul 14, 2010 at 10:48 PM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    The Bilsteins will provide up to 2.5" of lift with the factory coil springs. If you set them to 2.5", you will likely need a 2" AAL for Non-tsb springs, for it to sit close to level. And longer you bolts are not required for most AALs.
