New shocks needed with 3 inch leaf pack?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DreDog, Sep 15, 2011.
  1. Sep 15, 2011 at 3:27 PM
    DreDog
    DreDog [OP] Well-Known Member
    Andrew
    In the rear I have a 3 inch all pro leaf pack and heard somewhere that I NEEDED new shocks for the back? Do i need extended shocks? Is this true? I already have the brake lines.
    What happens if I don't get new and/or longer shocks?
    Or is this just a myth? :confused:
  2. Sep 15, 2011 at 3:30 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    You're going to need new shocks.
    Stock shocks are meant for stock height, so if you stay with them you'll have stock travel on a 3" lift....so your rear will not flex at all.
    That is, if the shocks can even extend to handle the lift in the first place. You'll have them maxed out all the time, which will eventually break them
    Grab some 5150's and be on your way. :thumbsup:
  3. Sep 15, 2011 at 3:31 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    i would think you need them, when i ordered my ome dakar leafs from toytec, the had the extended length billys with them. not sure what the negative would be if you dont get the extended length, however if toytec or any other shop recommends them i would just get them. the ome dakar was only 2.5 in. lift. I would just get them and do it right.
  4. Sep 15, 2011 at 3:33 PM
    DreDog
    Andrew
    Are all 5150's all the same length or do I need special length ones?
    And as for my current stock shock rear end, say if I flexed.. Could my shock possibly pull out / pull apart?
  5. Sep 15, 2011 at 3:35 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    IIRC, there's 10 and 12 inch shocks, but try give DSM a call for the proper length. both should work though
    if you lift the back and keep stock shocks, your shocks will be the limiters of travel. so say your leaf pack can flex 10", but your shocks can only handle 6, you're going to have one wheel in the air instead of an articulating rear suspension. I haven't seen a shock being pulled out, but eventually maxing out the shock all the time will lead to damage
    Edit:
    added the "call DSM" to sound smart and copy whipper
  6. Sep 15, 2011 at 3:44 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    I have 5100's in the rear with 2.5in DAKAR leafs. Was it a mistake not getting 5150s?
  7. Sep 15, 2011 at 4:28 PM
    DreDog
    Andrew
    IIRC? DSM? :confused:
  8. Sep 19, 2011 at 3:00 PM
    allpro
    allpro Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    With our 3" springs, we recommend at least a 9-10" travel shock. However, be careful of the collasped lengths since too long of a body can limit travel as well.
    Also, I wouldn't recommend the 5150s since although they are a 10" travel, you have to run an eye to stem converter that adds another 1", making them too long.
    We just got in the new 5160 Bilsteins, similar to those pictured here:
    They make them specific for the 05+ Tacomas valving and mounting wise. They give about 9 3/8" of travel with a short body. They retail for $189/ea.
