New shocks too stiff !
Discussion in '1st Gen. Tacomas (1995-2004)' started by tornado63, Aug 3, 2013.
  1. Aug 3, 2013 at 12:21 PM
    tornado63
    tornado63 [OP] Member
    Butch
    Lancaster, PA.
    01 Tacoma TRD
    I recently replaced all my shocks with Bilstien HD and now im not happy with them , I can feel every little bump in my steering wheel , I want to replace them with something else but not sure what to go with , Has any one else had this same problem ? Im not a big off road driver , I go off road maybe twice a year . Seems to be to be too many choices of shocks/struts to chose from and I don't want to make this mistake again !:confused:
  2. Aug 3, 2013 at 4:59 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Why did you replace your shocks?
    And why with heavy duty off-road shocks?
  3. Aug 3, 2013 at 5:08 PM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    I have BILSTEIN HDs on my 2004 and love them,over the stock BILSTEINS
  4. Aug 4, 2013 at 2:40 AM
    tornado63
    Butch
    Lancaster, PA.
    01 Tacoma TRD
    I replaced them because I had 99,000 miles on the original Tokico shocks and the truck was not holding the road well on bumps . Any suggestions on replacing the Bilstiens . I Guess I should of done more research first !!
  5. Aug 4, 2013 at 8:03 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    First person I've heard of not happy with bilsteins as a stock replacement
  6. Aug 4, 2013 at 8:09 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Might try playing with your tire psi until the shocks get worn in... or get out and offroad more often.
  7. Aug 4, 2013 at 8:16 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    So you're stock height, stock weight, stock coils with 5100's?
    I don't remember mine being that stiff at first in a harsh way, better, more planted, firmer yes, harsh, no.
    Are you sure the fronts were installed on the lowest settings? They have 3 mounting locations on the 5100 body.
    (Correct me if i'm wrong) but if your stock coils are shot too, your rebound/compression rates will be off providing a harsh/unexpected ride.
    You could look in to something like OME 881 coils for a near-stock height coil (initial lift is ~1" but will settle a .25" over time.
  8. Aug 4, 2013 at 10:40 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    I think it's because he's running the HD ones. they're similar to the factory bilsteins and ride like them. 5100's get all the love around here :D
    OP I have to ask why didnt you just go with the 5100's? you'd probably be happier with them.
    oh and I don't think he can't use aftermarket coils, the shocks don't have the travel that 5100's have.
  9. Aug 4, 2013 at 12:01 PM
    tornado63
    Butch
    Lancaster, PA.
    01 Tacoma TRD
    They perform great on speed bumps and cornering , Its that I feel every little bump and crack on the road radiating into my steering wheel ! I never had that with the old shocks , Thanks for the reply's .
  10. Aug 4, 2013 at 12:05 PM
    TheCookieMonster
    North East
    It might be time to replace Steering rack bushings and Sway Bar bushings with Polyurethene ones.
  11. Aug 4, 2013 at 12:07 PM
    TheCookieMonster
    North East
    I replaced my OEM Bilsteins with the Bilstein HDs on stock truck and feel that they are a better truck shock,although the OEMs were more of a car like SUV ride that most people want. I feel the overall performance and quality of the HDs make for a better shock but that's an opinion.
  12. Aug 4, 2013 at 12:09 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    It's most likely because your shocks were so worn you didn't feel the bumps. I'm not a fan of a soft spongy ride myself and when i bought my truck is was super soft. i didn't like it so i changed the shocks to 5100's and loved it. I think you might just have to drive around on them for a few thousand miles to brake them in a little they should soften up some over time. New shocks will always be stiffer then shocks with 100,000 miles on them.
  13. Aug 4, 2013 at 12:11 PM
    tornado63
    Butch
    Lancaster, PA.
    01 Tacoma TRD
    Biscuit , I was told the valving was the same on 5100s and they were for lifting the truck which I was not looking to do so I went with the HDs
  14. Aug 4, 2013 at 12:16 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I don't think the shocks are the problem, they are magnifying a bigger problem; maybe softer tires (KUHMO tires are quiet as a mouse on the highway) and/or it's time to start thinking about rebuilding the front end.
  15. Aug 4, 2013 at 12:19 PM
    TheCookieMonster
    North East
    Yes this could be true does the OP have P metrics or LT type tires this could lead to rougher rides:tinfoilhat:
  16. Aug 4, 2013 at 12:20 PM
    tornado63
    Butch
    Lancaster, PA.
    01 Tacoma TRD
    Thanks Jerry !
  17. Aug 4, 2013 at 12:27 PM
    tornado63
    Butch
    Lancaster, PA.
    01 Tacoma TRD
    I run destination A/T s , They are worn to about half of what they were new , Guess I will have to find someone in town to check my front out for worn bushings
  18. Aug 4, 2013 at 12:32 PM
    TheCookieMonster
    North East
    I ran those Destination ATs stock size on my truck and besides the fact they get great recommendations I felt they were not the best Road pavement handling tires,I have since upgraded to the Michelin LTX AT2 and they blow the doors off those Destinations in comfort and handling at a bigger price tag,well worth the money tho.
  19. Aug 4, 2013 at 12:38 PM
    TheCookieMonster
    North East
    You can easily replace the sway bar bushings yourself,just unbolt the u clamps one at a time and replace don't have to jack up or remove the bar. Only about $25-$30 bucks for ENERGY suspension bushings get the 26mm if your a TRD model. I had my rack bushings replaced by a shop ran about $300 with alignment.
  20. Aug 4, 2013 at 2:41 PM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    oh I was just curious because there is a stock height setting on the 5100's
