New shocks/U bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by jblair, Apr 2, 2011.
  1. Apr 2, 2011 at 11:38 PM
    jblair
    jblair [OP] Well-Known Member
    Colorado
    99 taco 2.7L I4
    lift, big boy tires, deck plate, no more sway bar, painted stuff
    So we've got a 99 tacoma, and we're going to flip the u bolts with the rock stomper u bolt flip kit, and mount the shocks on the top of the bolts because that's just how the kit works, http://www.parksoffroad.com/tacomamods/rockstomperuboltflip/rockstomper.htm see?
    The truck has a 2 inch lift and we're getting new rear shocks too. My question is what shocks should we get for this situation? Preferably 100 bucks or less each, so nothing ridiculous, but some travel would be nice too
  2. Apr 3, 2011 at 7:06 AM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    Remove your old shocks and articulate the suspension in a controlled environment to determine how much compression and extension your particular setup will allow BEFORE you order or buy your shocks.This can be accomplished by parking on a level surface, removing the rear shocks and jacking up one side of your truck until the tire comes off the ground. (Make sure the truck is properly jacked and braced for safety.) Measure the distance from the center of the lower shock mount (on the raised side of the vehicle) to the center of the upper shock mount. This is your extension measurement.Now measure the same distance on the opposite side of the vehicle. Even though you have one side jacked up, the other side is not necessarily fully compressed, so you have to compensate for this. Measure the distance between the lower and upper bump-stops and subtract this distance from the mount-to-mount measurement you just recorded. This will approximate your compression measurement.
  3. Apr 3, 2011 at 9:38 AM
    jblair
    Colorado
    99 taco 2.7L I4
    ok but I can't find compression/extension numbers for anything, so what can I do with these numbers?
  4. Apr 3, 2011 at 9:41 AM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    some sites tell you what their shocks are compressed and extended. the difference in compression/extension measurements is the travel you need. what shocks are you lookin into getting.
  5. Apr 3, 2011 at 9:50 AM
    jblair
    Colorado
    99 taco 2.7L I4
    well I'd like to get some bilsteins because I know how good they are, but it depends on pricing for what we need
  6. Apr 3, 2011 at 9:54 AM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    whats your measurements?
  7. Apr 3, 2011 at 10:00 AM
    jblair
    Colorado
    99 taco 2.7L I4
    I'll let you know as soon as I can, we haven't gotten a chance to work on it much lately, but we should be able to before next weekend
  8. Apr 3, 2011 at 10:17 AM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    all pro's website shows the extended/compressed measurements for the billys,so whenever you get your numbers you can check er out.
  9. Apr 3, 2011 at 10:34 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    +1 what i was going to add. plus they sell the bad ass 5150s for only a 100 bucks!
  10. Apr 3, 2011 at 11:17 AM
    jblair
    Colorado
    99 taco 2.7L I4
    cool but how should I measure everything with the u bolt flipped, because we haven't done that yet and I don't want to be running around without dampeners haha
  11. Apr 3, 2011 at 3:34 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    just mock it up,see where the mount will be with the flip kit in place and adjust your measurements accordingly
  12. Apr 3, 2011 at 5:58 PM
    jblair
    Colorado
    99 taco 2.7L I4
    The problem is that's what smart people do, and stupid people don't think of that right away haha
  13. Apr 3, 2011 at 6:00 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Where in Colorado are you?
  14. Apr 3, 2011 at 6:24 PM
    jblair
    Colorado
    99 taco 2.7L I4
    Monument, about ten minutes from mt herman rd:)
  15. Apr 3, 2011 at 6:25 PM
    S.B.
    Sean
    never been to mt.herman, I always forget about it. lol
  16. Apr 3, 2011 at 6:27 PM
    jblair
    Colorado
    99 taco 2.7L I4
    go up there and go down 320c and 318, they're great trails where are you?
  17. Apr 3, 2011 at 6:28 PM
    S.B.
    Sean
    Colorado Springs.
  18. Apr 3, 2011 at 9:31 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Check out Downsouth Motorsports. A lot of shock knowhow there. That is their specialty. Give Marco a call, he'll answer all your questions. He'll also give you a discount if you tell him you are on TW.
    If you scroll down this page a bit, you'll the compressed/extended lengths available for the 5125 Bilsteins. Very reasonable at $80 each.
    http://downsouthmotorsports.com/i-135588-bilstein-5125-series-performance-shocks.html
  19. Apr 3, 2011 at 9:57 PM
    jblair
    Colorado
    99 taco 2.7L I4
