New Shocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by cmtoney, Jun 15, 2015.
  1. Jun 15, 2015 at 5:15 PM
    cmtoney
    cmtoney [OP] Member
    Clinton
    00 4x4 SR5 lifted on 33s
    Tough Country 5 inch lift, Remote start, Grey wire mod
    I have a '00 Taco with 2 inch blocks in the rear and my factory shocks are at full extension, what is my best option for new ones?
  2. Jun 16, 2015 at 10:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  3. Jun 16, 2015 at 10:55 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    Bilstein 5125 series 1-3"
    Driver Side Rear 5125 Series Shock Part #:
    BE5-6252-H5
    Passenger Side Rear 5125 Series Shock Part #:BE5-6253-H5
    ^ unless ordered specifically...
    the bushings will need be replaced with 3/4" hour glass bushings.
    Business such as can supply the correct bushings in the original order.
    direct link... if it holds.
