New Shoes, Crappy Mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alpman, Sep 17, 2013.
  1. Sep 17, 2013 at 8:41 AM
    Alpman
    Alpman [OP] Member
    Greg
    Angels Camp, CA
    '12 DCSB PreRunner SR5
    2" Shock Spacers, 1/2" Blocks & Gabriel Air Shocks, Projector Fog Lights as Aux Reverse Lights, 4" Running Boards, Alpine INE-Z928HD w/ Perfect Fit Kit
    Just got a set of 265/75/16 Cooper ATP's installed on my '12 DCSB 4.0L two weeks ago. I love the look, ride & handling, a huge improvement over stock. But my mileage is suffering. I used to get 20+ mpg avg but now I'm down to 16! I've even aired them up to 42/40 with no improvement. My driving habits have not changed nor the gas that I use. I installed new plugs 7K mi ago, so I don't think that's an issue either. I just can't believe my fuel economy would be reduced by 20%! Can anyone else chime in?
  2. Sep 17, 2013 at 8:46 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What load range are the tires?
  3. Sep 17, 2013 at 8:46 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are those the exact same size as your original tires?
  4. Sep 17, 2013 at 8:47 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Welcome to the club.
  5. Sep 17, 2013 at 8:52 AM
    Alpman
    Alpman [OP] Member
    Greg
    Angels Camp, CA
    They are standard load tires, original size were 245/75/16.
  6. Sep 17, 2013 at 8:53 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    how did you not see that coming with more aggressive and larger tires?
  7. Sep 17, 2013 at 8:54 AM
    Alpman
    Alpman [OP] Member
    Greg
    Angels Camp, CA
    I knew I would lose a little bit of mileage, but 20% seems extreme.
  8. Sep 17, 2013 at 8:55 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Now, now; he probably new there would be a loss, we all did, but I was getting 22MPG city driving before, and now I drive extra conservative on the highway and on a good tank get 18 mpg, but typically only 17.5 mpg. It is a pretty drastic drop.
  9. Sep 17, 2013 at 8:56 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Yes, it is, and I had a long debate when I just got new tires a few months ago because I wasn't sure if really wanted the look versus the savings. I still went with the bigger tires.
  10. Sep 17, 2013 at 8:57 AM
    Alpman
    Alpman [OP] Member
    Greg
    Angels Camp, CA
    The ATP's aren't that aggressive either. They are very quiet on the road. I've had larger BFG AT's on two other trucks in the past and never had this kind of drastic difference.
  11. Sep 17, 2013 at 8:58 AM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    Your tires are now ~3.7% larger than your previous tires...you must factor that into your calculations.
  12. Sep 17, 2013 at 8:58 AM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    Maybe your calculating it wrong and forgetting to compensate that the larger tires have a longer rotation? tire size calculator
  13. Sep 17, 2013 at 8:59 AM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    beat me to it lol
  14. Sep 17, 2013 at 8:59 AM
    jmg256
    Al Tonter
    TRD Offroad
    I run the exact same tire btw
  15. Sep 17, 2013 at 8:59 AM
    Pugga
    Massachusetts
    The Cooper ATPs aren't an overly aggressive tire and, since they're still p-rated, shouldn't really be much heavier.
    OP, drive with a lighter foot, especially on take offs and you should be able to get back to the 18 MPG range.
  16. Sep 17, 2013 at 9:13 AM
    Alpman
    Alpman [OP] Member
    Greg
    Angels Camp, CA
    That's one of the reasons I chose them. I don't know how much lighter my foot can get though. Like I said, I was getting over 20 mpg avg, which is pretty good on our V6's. I use an UltraGauge to help maximize my mileage. On long hauls I've got 24+mpg in the past.
  17. Sep 17, 2013 at 9:21 AM
    Janster
    Jandy
    Lancaster, PA
    BINGO!!
    Is the OP making the right calculations and/or has his Ultraguage setup properly?
    Bigger tires means LESS miles/distance on the odometer.
  18. Sep 17, 2013 at 9:24 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    did you set your ultra gauge to compensate for the larger tire size? (not sure if you can on an ultragauge, I have a scangauge)
  19. Sep 17, 2013 at 9:25 AM
    Alpman
    Alpman [OP] Member
    Greg
    Angels Camp, CA
    Even factoring in the 3.7%, that would still make it just 16.6 mpg...
  20. Sep 17, 2013 at 9:27 AM
    Alpman
    Alpman [OP] Member
    Greg
    Angels Camp, CA
    The UG doesn't have the option and with the larger tires my speedo and UG are actually accurate now. I checked with my GPS.
