New Shoes, Crappy Mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alpman, Sep 17, 2013.
  1. Sep 17, 2013 at 9:28 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    This is very minimal for these two differences in tire sizes, so the calculation is barely affected, not even enough to make 1mpg difference.
  2. Sep 17, 2013 at 9:29 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You need to take your miles drive, multiply by 1.037, then divide by gallons used.
    You can recalibrate your UG for the bigger tires. Download the manual and see how to set it up to properly correct for your actual fuel consumption.
  3. Sep 17, 2013 at 9:29 AM
    Alpman
    Alpman [OP] Member
    Greg
    Angels Camp, CA
    '12 DCSB PreRunner SR5
    2" Shock Spacers, 1/2" Blocks & Gabriel Air Shocks, Projector Fog Lights as Aux Reverse Lights, 4" Running Boards, Alpine INE-Z928HD w/ Perfect Fit Kit
    .592, to be exact.
  4. Sep 17, 2013 at 9:32 AM
    Alpman
    Alpman [OP] Member
    Greg
    Angels Camp, CA
    I've been thru the manual and didn't see anything on it. Maybe I have an older version?
  5. Sep 17, 2013 at 9:38 AM
    Alpman
    Alpman [OP] Member
    Greg
    Angels Camp, CA
    I still can't believe that going to a 265 would make that big of a change, but I guess there's no other explanation...
  6. Sep 17, 2013 at 9:46 AM
    mike92y
    mike92y Well-Known Member
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    OME all around. SPC UCA. This and that.
    The Ultra Gauge has a milage calibration. I bought my AT tires by comparing the weight of the tires I wanted campared to the weight of the stock Rugged Fails. I really wanted BFGs but they were just to heavy.
  7. Sep 17, 2013 at 9:55 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You said you have a GPS.... Have you compared odometer readings also? Using GPS and highway mile markers?
    Being off a certain percentage will vary depending on how fast/slow you're going.
    Where are you from? I get 2mpg decrease/increase when the gas mixture changes between summer & winter gas. My truck gets its best mileage while going about 45mph......Not highway speeds like you'd expect.
    Have you changed gas octane lately?
    Could be a variety of things 'adding' to your MPG downfall.....
  8. Sep 17, 2013 at 10:02 AM
    Pugga
    Massachusetts
    I have an old version, there are calibrations for MPG and miles driven. If you have never done the calibrations and are relying solely on that to calculate your MPG's, chances are it was incorrect from the beginning.
  9. Sep 17, 2013 at 10:07 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Seconded.
    I went from the stock 245's to a set of 265/75R16 LRC Duratracs, and started feathering the throttle a little more. I take off a little slower and let off the throttle a little sooner to coast down to a stop when I can. I'll still kick her in the ass if I have to pass somebody, and I pace traffic during my commute home (when I go in there's nobody else on the roads).
    Before the upgrade I was averaging 22-23; since then I've still managed between 20-21, with one trip to around 18 (spent the weekend hauling a trailer around).
  10. Sep 17, 2013 at 10:19 AM
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    Unsprung weight increase will make a big difference. I went from stock sport tires to michelin ltx ms2's (stock load rating) and was surprised at a decrease of about 2-3 mpg due to the increased weight.
  11. Sep 17, 2013 at 10:28 AM
    Captflack59
    Captflack59 Member
    steve
    rockland, maine
    13 Tacoma trd 4x4
    You said you changed plugs?......what kind did you use????
  12. Sep 17, 2013 at 10:36 AM
    Alpman
    Alpman [OP] Member
    Greg
    Angels Camp, CA
    I did find these settings and I did do the calibrations when I first got the UG, so it should have been accurate before the tire change, thanks. I have also checked in the past to see if the UG is accurate compared to the speedo/gal used at time of fill up. I did go into the calibration settings and adjusted the miles driven (multiplied by 3.7%) and it did change the trip MPG to 16.1, not much difference. The MPG calibration is for gallons of fuel and is accurate so I didn't change anything there.
  13. Sep 17, 2013 at 10:43 AM
    Alpman
    Alpman [OP] Member
    Greg
    Angels Camp, CA
    Yes, seven thousand miles ago and didn't see any real difference in mileage. Old plugs actually looked great. I used NGK Iridiums. I know you're not supposed to use Iridiums in the 4.0L but I did not have any adverse effects. I've towed a trailer and hauled heavy loads since the plug change and never had a problem with them. I seriously doubt it's the plugs.
  14. Sep 17, 2013 at 10:48 AM
    taco duck
    taco duck Well-Known Member
    SR5
    im enjoying that as well (see Fuelly)
  15. Sep 17, 2013 at 10:51 AM
    #35
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    I moved from a 265 65 17 to a 265 70 17 and lost about 2mpg around town. You aren't alone on this as like everyone is saying: new tread pattern, larger tire, rotation, etc all play into the mix. If you aren't happy with them, sell them and go back to stock tire and size. There is a reason the dealerships put certain tires on vehicles so the mpg on our trucks look good. Pay the price for your looks :)
  16. Sep 17, 2013 at 11:04 AM
    #36
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    I still have my factory sport tires on my dcsb 4x4, which are 265 65 17. I get 21+ all day long on the hwy. I can't see how those tires at 1 size bigger would do that.
    I'm planning on going to the dynapro atm in 265 70 17 and wasn't expecting much if any change. Plenty of people have said that tire and size did nothing to there mpg.
  17. Sep 17, 2013 at 11:25 AM
    #37
    MBentz
    MBentz Active Member
    Sacramento, CA
    '17 Inferno DCSB TRD Sport 4x4 6M/T
    How? Does the city you drive in have one stop light?
  18. Sep 17, 2013 at 11:29 AM
    #38
    Pugga
    Massachusetts
    The iridiums shouldn't have any adverse effects on the V6, they're just not required like they are for the 4 banger. I don't think that anything you're experiencing has anything to do with the plugs either.
  19. Sep 17, 2013 at 12:20 PM
    #39
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Yeah, a few more than 1, maybe just not as heavy a foot as you? :notsure:
  20. Sep 17, 2013 at 12:40 PM
    #40
    Brian007Taco
    Brian007Taco 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    Larger diameter tires = less rotations = less odometer reading than actual miles traveled. When I went from 245 to 265. My reading of 10 miles on the odometer was actually 10.38 miles traveled. May not seem like much, but over the a 300 mile tank of gas, that will mean your mpg has dropped by about 0.50-.75mpg in odometer reading. Over time, this will make a difference. This can easily be fixed by having the odometer and speedometer recalibrated. You will also lose some mpg, but not much with a heavier tire. Also, type of tire will also effect this. A street tire is going to be more mpg efficient that a mud tire. It's all on what you are looking for. Do you want better mpg, or a tire that will go offroad and not wear as fast because it's designed to go offroad.
