New Shortie Headers from Holly.
Discussion in 'Performance and Tuning' started by Torspd, Dec 18, 2014.
  1. Dec 18, 2014 at 4:31 AM
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. Dec 18, 2014 at 4:41 AM
    Large
    Large Red
    Nice. Although I don't know the difference (or any kind of gain) between short and long. Mind explaining?
  3. Dec 18, 2014 at 4:45 AM
    Torspd
    Tor
    The Great America!
    Cats versus no cats. All I've got. :anonymous:
    AR15xAR10 likes this.
  4. Dec 18, 2014 at 1:47 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Boo nothing for 12+ Tacoma
  5. Dec 19, 2014 at 10:04 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    seriously contemplating these in place of my URD headers..
    Tor.. any input..
  6. Dec 19, 2014 at 11:33 AM
    Torspd
    Tor
    The Great America!
    Not for the cost, unless you really want to have cats back in there. If this was your first go, then yeah. Let's get those other issues on your truck fixed up first, then we can focus on this "possibility".
  7. Dec 19, 2014 at 3:36 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    selling my URD headers would easily cover the cost of those Holly's tho. but true.. I think its just the winter weather/winter gas/etc.. that and the driveshaft.. :eek:
    I'll get it sorted out by the first of the year and go from there.
  8. Mar 1, 2015 at 12:56 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Any updates on these? Wondering if they are bolt up or if manifold bolts needs changing?
  9. Mar 9, 2015 at 3:40 PM
    Captain Stabbin
    Captain Stabbin Well-Known Member
    Justin
    SOMD
    2010 DCSB
    I bounce it offa stuff.
    I didn't see this thread before I started one. I've got a Jeg's account, and the black ones are $275 there. Ceramics are $360. Trying to figure out if I want to chance it or not. Flowtech is a Holley brand, and Holley has a damn good rep (far as I'm aware), so it seems like a good bet.
  10. Sep 21, 2015 at 11:01 AM
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Do you think these are better than thorleys?
  11. Sep 21, 2015 at 5:24 PM
    Captain Stabbin
    Justin
    SOMD
    2010 DCSB
    I wound up buying URD Spec-U headers. I know they are not the cheapest option and the install is tougher than other LT's, but I'd buy them again any day.
  12. Sep 21, 2015 at 5:25 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :thumbsup: x2
  13. Sep 21, 2015 at 5:26 PM
    Tacoma SS
    Denver
    So you also had to buy the new o2s?
  14. Sep 21, 2015 at 5:31 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yes. Any LT header will require o2 sims
  15. Sep 21, 2015 at 5:35 PM
    Tacoma SS
    Denver
    Would it be pointless to do headers without doing a Y pipe? I want a little bit of extra power but I still want my cats so I'm not too noisy and I can still pass emissions
  16. Sep 21, 2015 at 5:38 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    You have 2 sets. Front and rear. The LT's ditch the fronts, the Y has the 2nd set. I had them weld in 2 new cats when they made my Y.. So I have one set still
  17. Sep 21, 2015 at 6:00 PM
    Tacoma SS
    Denver
    Oh yeah, you got the custom y pipes made. Did you just buy like a URD y pipe and then weld cats into it, or are your pipes actually like custom custom?
  18. Sep 21, 2015 at 6:08 PM
    Captain Stabbin
    Justin
    SOMD
    2010 DCSB
    URD cuts a deal on the O2 sensors when you buy the headers. The equal-lengths cut a bit of rasp from losing 2 cats and keep gains across the power band. URD dyno'd a stock v6 at a peak gain of 18rwhp and max of 22rwhp with no loss at low RPM. If you need to pass smog, idk because I'm registered in FL, which does not do emissions. You did not specify a state, either. Smog tests vary by state.
  19. Sep 21, 2015 at 6:10 PM
    Tacoma SS
    Denver
    I'm from Colorado where they check for cats but I don't know if they would look for the upstream cats. But I also don't know if it's worth the risk which is why am thinking about just doing shorties and keeping all of my cats.
  20. Sep 21, 2015 at 6:15 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    What do you guys think of AFE's twisted steel headers? They have high flow cats on them too.
