New Shortie Headers from Holly.
Discussion in 'Performance and Tuning' started by Torspd, Dec 18, 2014.
  1. Sep 24, 2015 at 7:02 AM
    #61
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Do you have any pictures of it? And how much did that cost you?
  2. Sep 24, 2015 at 11:56 AM
    #62
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Who makes it though? Looks similar to what I remember of the OBX one.
    No way that should be so cheap, unless they have overstock and are trying to give them away. Not if that is quality 304ss.
  3. Sep 24, 2015 at 1:26 PM
    #63
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I'd pass on that.
    Lord Helmet likes this.
  4. Sep 24, 2015 at 1:52 PM
    #64
    Torspd
    Tor
    The Great America!
    I'm with him. ^^^
  5. Sep 24, 2015 at 2:49 PM
    #65
    Tacoma SS
    Denver
    But either way I would have to weld my rear cats into whatever y pipe I buy in order to pass emissions correct?
  6. Sep 24, 2015 at 2:57 PM
    #66
    Tacoma SS
    Denver
    Also, what is the benefit of doing the 70mm throttle body adapter?
  7. Sep 30, 2015 at 3:33 PM
    #67
    Captain Stabbin
    Captain Stabbin Well-Known Member
    Justin
    SOMD
    2010 DCSB
    I bounce it offa stuff.
    The benefit is being able to add a 70mm throttle body from a late model 4runner or FJ. The stock TB is 65mm.
  8. Sep 30, 2015 at 8:24 PM
    #68
    Tacoma SS
    Denver
    What's the horsepower gain?
  9. Sep 30, 2015 at 8:37 PM
    #69
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    kerious too
  10. Oct 1, 2015 at 2:22 PM
    #70
    Captain Stabbin
    Justin
    SOMD
    2010 DCSB
    I haven't seen any numbers for this on an NA taco. You'll probably want to hit up Gadget at URD to see if he has any dyno runs. I can't imagine it adding much of anything to an otherwise-stock motor. The ECU is still going to hold a 14.7 AFR unless you stand on the gas. I would think that means the throttle body would be slightly more closed to compensate for the larger diameter, but my logic may be bass ackward.
  11. Oct 1, 2015 at 5:27 PM
    #71
    Tacoma SS
    Denver
  12. Oct 2, 2015 at 8:42 AM
    #72
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    The plate is an adapter with diameter of 70mm to 65mm.
    Even at 70mm, the throttle body is still probably the more restrictive componments. The more restrictive parts are elbows, reducers, and valves like the thorttle body. A larger area will reduce air speed trough the TB and then the pressure loss. The plate is not expensive. The problem is to find a Throttle body. 70 mm seems to be harder to find then the 76 mm and it can be very expensive.
    I dont think you'll find specific number for that mod.
  13. Oct 2, 2015 at 8:51 AM
    #73
    Torspd
    Tor
    The Great America!
    The 70mm adapter port matches the I.D. of the OEM plenum of the single VVT-I engines. Thus the 70mm TB with that adapter, into the OEM plenum is a smooth straight shot.
    The stock 65mm TB, which comes with single VVT-I engines is smaller in I.D. than the plenum which it bolts to.
    The TRD S/C is port matched with the 65mm TB.
