New sized spare wheel?
Discussion in 'Wheels & Tires' started by AviateGW, Apr 19, 2013.
  1. Apr 19, 2013 at 1:19 PM
    AviateGW
    AviateGW [OP] Well-Known Member
    Glenn
    Atlanta area
    Black '99 3.4 SR5 4x4. OME/Dakar
    16x8 KONIG Countersteer Offroads from FN, OME/881s in front, OME shocks/Dakar leafs in back. K&N CAI, and last, but not least, TRD Shift knob.
    I recently switched from my stock 15" to a FN 16" wheel. I love the look of the truck, but it occured to me that my spare is a 15" wheel, with a much smaller diameter tire than my new tires. If I wind up having to drive on the spare for any significant amount of time, I'm more than a little concerned that I might hurt my differential.
    1) Would that hurt my differential/anything else?
    2) If I need to, I can pick up a 16" spare wheel and similar sized tire to what I have on the rest of the truck. How do I know the specs of the bolt pattern I'll need for the spare wheel?
    Thanks in advance,
  2. Apr 19, 2013 at 1:25 PM
    moondeath
    moondeath Winter is Coming
    Pa, Carlisle
    2013 TRD Sport DCLB 4x4
    5100 @ 1.75", 1.5" Icon Progressive 3 leaf, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    1) best to try and keep the spare up front if you can get away with that if the time comes.
    2) you could keep the wheel and get a tire with a larger sidewall to match the diameter of your other tires. Or you can get a different wheel and tire to match.
  3. Apr 19, 2013 at 1:31 PM
    moondeath
    Pa, Carlisle
    Someone from 1st gen will probably chime in, but you need to find your lug pattern for your truck. 2nd gens are 6 on 5.5". 6 lug with 5.5" between opposing lugs.
  4. Apr 19, 2013 at 1:35 PM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road SR5 Impulse Red
    5100's @ 1.25", Scangaugae II, deck plate mod w/AFE Pro Dry S filter, grey wire mod, alarm mod, defrost w/o compressor mod, de-badged, 17" sport wheels powder coated black, 1" B.O.R.A. wheel spacers, 265/70/17 Cooper Zeon LTZ's, sockmonkey beside decals.
    1st and 2nd gens do have the same lug pattern
  5. Apr 19, 2013 at 5:35 PM
    DevL
    DevL Well-Known Member
    Tire diameter size matters, not rim size nor tire width.
  6. Apr 21, 2013 at 2:47 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    But 1st Gens have 4.5" BS (Back Spacing).
    You can run 1st Gen wheels on a 2nd Gen (I do) without a problem.
    But you can't run 2nd Gen wheels on a 1st Gen without spacers.
  7. Apr 21, 2013 at 4:39 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2000 Prerunner TRD
    bilsteins, 2010 Tacoma 17" alloys w/265's, driveshaft mods, 1.25" hubcentric spacers.
    "But 1st Gens have 4.5" BS (Back Spacing).
    But you can't run 2nd Gen wheels on a 1st Gen without spacers. "
    All true except for the last statement, 2nd gen wheels work wonderfully on 1st gens without spacers as long as you stay within tire specs(talking 6 lug setups)....only when I stepped up tire size +1 was the tire rubbing, and only at full lock left, easily solved with 1.25" HC spacers, could easily have lived with the slight rubbing...
    BTW, BS on 2nd gens (at least the 17" alloys) is 5", so the extra 1/2" goes to inside..
    I like the slightly wider look too..
    just sayin'....
  8. Apr 21, 2013 at 9:20 AM
    4Wheelin4Banger
    Randy
    OK it was just what I had heard here. I had said it would probably cause problems because it moves the tire & wheel in closer to the UCAs & frame in another thread. Two members said you could run them as long as you used spacers.
