New Sno-Way
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrbadwrench, Dec 22, 2013.
  1. Dec 27, 2013 at 11:05 AM
    mrbadwrench
    mrbadwrench [OP] Well-Known Member
    Cleveland Ohio area
    2014 GMC Sierra 4x4, 1988 Mitsubishi J53
    That or, the other problem with lifts is that the mounts are designed for trucks at factory suspension heights. When you raise the truck, you raise the mount higher and that throws off the height of the A-frame relative to the ground, which will make the blade contact the ground unevenly when angled.
    Any kind of lift on a truck requires a custom built mount, period.
    Most snow plow mounts (including the Sno-Way) are designed to have the mount pin holes on the truck 8"-10" off the ground.
  2. Dec 27, 2013 at 4:11 PM
    Goatman68
    Goatman68 New Member
    Northern NJ
    TRD Sport
    3in. Sus. Lift, Add-a-leaf in rear with 3° shims
    So is there a poly plow that works on a taco with a 2 1/2 lift?
  3. Dec 27, 2013 at 4:54 PM
    mrbadwrench
    Cleveland Ohio area
    Yes, any plow. You just have to fab your own mount or modify a factory one so it sits lower.
  4. Dec 27, 2013 at 5:03 PM
    mrbadwrench
    Cleveland Ohio area
    This photo best illustrates plows on lifted trucks. You can see the mount, with the holes at the bottom which the plow/plow A-frame pin into. Those holes need to always be the same distance above the pavement, no matter how high your truck gets.
    So you can see that on this lifted truck, the mount is quite substantial. A non-modified factory mount on this truck would have the holes much higher off the ground, making the plow not work.
  5. Dec 27, 2013 at 10:02 PM
    Yaozer
    Yaozer Well-Known Member
    North Jersey
    2011 Red DCSB TRD Sport
    Flowmaster exhaust, 3" Old Man Emu lift, Konig Countersteer Rims, and too much more.
    I get that you can fab a mount or modify a factory one, but would it add more stress to the frame or suspension bc of the angle of the mount?
  6. Dec 27, 2013 at 10:24 PM
    cgs2k2
    cgs2k2 old man
    literally saw you today!!! cant remember if it was in cleveland heights or near oberlin college - im drunk
  7. Dec 28, 2013 at 6:38 AM
    mrbadwrench
    Cleveland Ohio area
    Yeah that was in Oberlin - I saw your truck parallel parked along main street Friday. :cool:
  8. Dec 28, 2013 at 6:39 AM
    mrbadwrench
    Cleveland Ohio area
    Great question, I don't have an answer for that.
  9. Dec 28, 2013 at 6:55 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    You have a serious snow removal arsenal there. I prefer a 2 speed compact track loader, myself. They don't move the most snow, but they are the most fun.
  10. Dec 28, 2013 at 7:31 AM
    mrbadwrench
    Cleveland Ohio area
    I had to rent a tracked skid steer recently, and that thing was all different kinds of hilarity. Wheelies, spins, and some sweet jumps were all enjoyed that day :D
  11. Dec 28, 2013 at 8:13 AM
    DJB1
    Dave
    SLC, UT
    If the surface is slick enough and it's a 2 speed machine, you can even make it power-slide!
  12. Dec 30, 2013 at 12:36 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Frame yes. Suspension yes as well, but only because of the extra weight from the longer mounts.
    The frame would have more stress at the weld points. An easy illustration would be to lift a can of soup with your hand, and then at the end of a three foot stick. The perceived weight of the can is higher at the end of the stick because your leverage is worse. Same thing applies for longer mounts; the further from the frame you get the more stress you'll be placing on the weld/bolt points on the frame because it's a longer lever.
    Yaozer likes this.
  13. Dec 31, 2013 at 7:57 PM
    johnny 5
    johnny 5 Well-Known Member
    wisconsin
    Black 07 TRD Off road 4x4
    7-6'' sno-way plow w/DP
    Hey everyone I run a Sno-way 7'6" on my 07 dbl cab it has been doing a plow route of 19 driveways every snow event since winter of 07 and has been super reliable! I have had just a couple small issues with the plow other then that the Tacoma is right out there along the full sizes at all hours of the night. The truck has never let me down and for not having a so called plow prep,the charging system isn't even phased by the load of the plow and my extra lighting. Don't underestimate these trucks they will take a punishment and it is well maintained however.
  14. Jan 1, 2014 at 6:54 AM
    Yaozer
    North Jersey
    Thanks for the explanation. That makes a lot of sense. I'm probably getting a Western, which should sit on the truck just fine without mods to the suspension.
  15. Jan 1, 2014 at 7:42 AM
    #35
    Noelie84
    Noel
    Wales, Maine
    No probs. Silly me had to weld the mounting points on the bucket of my old tractor twice because I didn't stop and think about the whole "leverage" thing the first time I mounted a plow to it and broke one of the tabs off. :rolleyes:
    The second time I welded it I shortened the arms on the plow first, haha.
    Figured I'd save you the same problem.
  16. Jan 1, 2014 at 12:01 PM
    #36
    mrbadwrench
    Cleveland Ohio area
    I've never broken a plow mount, but I've hit some stuff where I saw the blade stretch its springs to the max and faceplant on the asphalt and thought "OH CRAP". Nothing puckers your butthole faster than hitting the edge of a manhole cover at 15 mph :D:eek:
  17. Jan 1, 2014 at 1:13 PM
    #37
    G17GUY
    G17GUY Well-Known Member
    Modesto Ca
    tacoma
    spining hub caps chrome stick-on trim new car smell air freshiner stering wheel suicide knob nut sack on hitch back window curtain
    I was wondering about that:D Does the poly blade flex, or will it break?
  18. Jan 1, 2014 at 1:14 PM
    #38
    mrbadwrench
    Cleveland Ohio area
    Got a storm coming in tonight and tomorrow, and we had the "warm-up" snowfall early today. Good news for me! :cool:
  19. Jan 1, 2014 at 1:18 PM
    #39
    mrbadwrench
    Cleveland Ohio area
    It won't break from catching things on the pavement with the cutting edge, but if you smack a rock or large fence post (happened to me :( ) that is buried in the snow in the right way in super cold conditions, you can crack the poly. Very rare tho.
  20. Jan 1, 2014 at 1:22 PM
    #40
    1993t100
    1993t100 I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    Nice truck! Looks like a good setup for you. Up here in upper Michigan, I would be a little leery with that though.
    I'd love a 2014 Tundra with an 8' BOSS on it :D
