New Spark Plug Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by maxpower29, Feb 19, 2017.
  1. Feb 19, 2017 at 5:41 PM
    maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Swapped them out a few months ago and my old ones looked bad after about 130k kms. When I bought them on ebay they came and were NOT gaped properly. I fixed the gap to what the spec was and installed them doing it as I had read how. Torqued and never seized. But now lately everytime I start the truck, the first half second or so it sounds like its going to die as it starts. Im wondering if the plugs are ruined from being re gaped or something else? Seemed like an easy install to be honest
  2. Feb 19, 2017 at 5:59 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    My truck did this during the summer
    Cleaned the map sensor (or what ever it is) using the TW thread, worked great
    How long after you installed did it start doing this
  3. Feb 19, 2017 at 6:01 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    almost right away I think, I have map sensor cleaner too so I'll try that out tomorrow
  4. Feb 19, 2017 at 6:05 PM
    tacofish
    N NJ
    14 ext cab 4x4
    if right away not sure about sensor
  5. Feb 19, 2017 at 7:07 PM
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    What plugs did you go with, OE Densos?
    If it were me, I'd pull the plugs and check them for cracks or a prong that got bent when dropping the plugs in the cylinders. If everything looks good, reinstall and ensure the coil pack gets installed securely on the plugs (maybe even add contact goop). Check wiring for each coil pack, etc.
    When you replaced the spark plugs, what all did you remove to gain access to them? You could also doublecheck anything you touched in that sense and ensure there's noting undone, loose, broken.
  6. Feb 19, 2017 at 7:41 PM
    badger
    badger Well-Known Member
    07 SR5
    check all your vacuum hoses on the drivers side. You left one of them disconnected.
    14TACO4X4 likes this.
  7. Feb 19, 2017 at 8:47 PM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    Which is why I didn't disconnect any of them. Just removed that damn bracket, and worked around the vacuum hoses.
  8. Feb 19, 2017 at 10:28 PM
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Very possible, specifically the hose abouve the middle driver side cylinder. Clamps to the intake plenum and runs back toward the firewall. I unhooked this one when doing my plugs.
    DONT touch the MAP sensor yet! Retrace your steps first. Since the problem seemingly came up right after you changed the plugs, investigate that first before messing with other things. Personal experience; eliminate the most likely thing before goofing with other things, keeps troubleshooting more structured and simple.
    monsterkx2fiddy likes this.
  9. Feb 19, 2017 at 10:43 PM
    14TACO4X4
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    ^^You're talking common sense, brother. Ain't no time fo that here!
  10. Feb 20, 2017 at 4:57 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Ill be out there checking it soon. Thanks guys
  11. Feb 20, 2017 at 5:03 AM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
  12. Feb 20, 2017 at 5:06 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    What plugs did you install?
  13. Feb 20, 2017 at 5:07 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    OEM replacement
  14. Feb 20, 2017 at 5:43 AM
    badger
    07 SR5
    Let us know what you find. Those vac hoses are easy to accidentally pull off when you are trying to get your hand in there. There are a couple that I just remove right from the get go. If a hose is off you will notice it at idle, but likely not at cruise. If you are sure they are all on, then my next place to look is at the plugs. When you use anti-seize, you have to be careful to keep it away from the electrode/insulator area. It is a conductor, so it will short the plug. I just use a very thin wipe on the threads,...no gooping. You would probably feel shorted plugs at every speed though, same with bad coil wire connection.
  15. Feb 20, 2017 at 7:53 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Checked all the connections and they all seem to be fine. I know what your saying about the anti seize, your right I use it at work all the time on ships and it has to be put on careful but I know I was. I'm going clean the map sensor now and if that's not it it must be the plugs.
  16. Feb 20, 2017 at 8:03 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Cleaned the sensor and started fine on the first go. Might be the issue. I'll try it a few times more today and tomorrow see how it goes
  17. Feb 20, 2017 at 8:03 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    what does the plug manufacturer say about using anti-seize ?
    don't.
    but what do they know about vehicle ignition systems anyway, amirite ?
    kryten likes this.
  18. Feb 20, 2017 at 8:07 AM
    Aztex
    Aztex Well-Known Member
    2013 Tacoma TRD 4x4
    Double check your gaps!
    I had the same issue with a 2000 Taco that spec'd two gaps for the same motor but different models. I first tried the wider gap and it was just a bit too wide for the spark to arc when damp from fuel.
    When warm and running it actually seemed peppier but difficult to start.
    I recall getting them from Toyota and rechecking to spec's provided.
    It was a CA emissions vehicle that was the difference I think....
    HTH
    14
  19. Feb 20, 2017 at 8:08 AM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    I agree w/ you but I used a small amount as well w/ no issues. My father in law as well on his 05 4 runner w/ no issues. IIRC Toyota also says never to change the trans fluid. I don't agree w/ them on that one either.
  20. Feb 20, 2017 at 8:15 AM
    badger
    07 SR5
    Lots of manufacturers recommendations are just to save idiots from themelves. Rather than bother to tell you how to use it properly, it's easier to just say don't use it,...problem solved,....idiot fail overted. Anti-sieze on the plug threads is a good thing. It prevents galled threads, and allows a more consistent gasket crush. Anti-seize on the insulator is a bad thing,..pretty simple.
