new spark plugs or ask the machinist
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacogriz, Nov 27, 2011.
  1. Nov 27, 2011 at 3:48 PM
    tacogriz
    tacogriz [OP] Member
    griz
    arizona
    flat black 97 4wd tacoma 4 cylinder
    so,
    about six months ago i thought i had a serious transmission problem, but upon digging around i realized i just needed to change wires and spark plugs...everything was fine...tonight as i was driving i started to lose power..i stopped on the side of the road , and being a girl, had about every man stop and try to assist me. thank-you out there!
    i had the free diagnostic done at autozone which told me that cylinder 3 was misfiring. i promptly bought one spark plug and dropped her right in and away i went. about an hour later...loss of power...wierd clanking noise maybe coming from exhaust system.?..engine sounds real loud....shifts fine though.....
    so im wondering if there could , in fact, be a more serious problem rooted in the engine,rather than just from the plug and wire connections. what do yall think?
  2. Nov 27, 2011 at 3:54 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    No clue, lots of members in Arizona, maybe one will step up and lend a hand.
    Good luck.
  3. Nov 27, 2011 at 3:59 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    You mention exhaust?? Normally the exhaust having a hole in it would have almost like a loud ticking sound or like a reverb of the sound waves escaping... I'm not sure how to explain it but besides being loud and having a minor power loss. your exhaust wont effect much unless its suddenly become blocked or plugged..
    Anyone know if the 1st gens run distributor caps?? because if you only changed your plugs and wires that could be the issue. they wear out over time
  4. Nov 27, 2011 at 4:07 PM
    tacogriz
    griz
    arizona
    my truck has no distributor cap...the plugs go right into the block
  5. Nov 27, 2011 at 4:13 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    How did the old plug from #3 look?
  6. Nov 27, 2011 at 4:22 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    First Welcome.
    This is something your going to have to take in and have looked at. WAY to many things it could be and we don't want to send you down the wrong road.
    You could have dropped a valve with the misfire and funny noise out the exhaust or could have blown out a plug. You seem to to know when things don't sound right so i would get it looked as ASAP before a potential to make things worse.
    GOOD LUCK !!!
  7. Nov 27, 2011 at 5:55 PM
    tacogriz
    griz
    arizona
    the old plug had barely any signs of use....
    what does dropping a valve entail?
    i really hate bringing in my truck.....rather work on it myself if i can.
  8. Nov 27, 2011 at 7:29 PM
    JDMcQ
    Kudos for wanting to fix it yourself. I don't know that we (or at least I) can diagnose too much over the internet. You might want to have a local mechanic look at it to at least figure out what is wrong.
    Not sent from an iPhone.
  9. Nov 28, 2011 at 7:02 AM
    tacogriz
    griz
    arizona
    thanks so much yall!!!
  10. Nov 28, 2011 at 7:22 AM
    tacogriz
    griz
    arizona
    looking foward to being a part of this website...im on my way to talk to a buddy of a buddy whos got a shop!!
  11. Nov 28, 2011 at 7:33 AM
    JDMcQ
    Glad to have you. Let us know how you make out.
  12. Nov 28, 2011 at 7:39 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Try doing compression check on all cylinders. That should rule out valve or head gasket issue.
  13. Nov 29, 2011 at 11:40 AM
    tacogriz
    griz
    arizona
    turns out i just needed to change the coil pack!!!!! easy fix, changed it out in about five minutes!!!!it cost me 75 bucks though!!!maybe should of went to the junk yard, but now its in and done and my truck is running great!!!!
  14. Nov 29, 2011 at 11:45 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    A girl who works on a drives a truck. Where have you been all my life..lol
  15. Nov 29, 2011 at 2:22 PM
    Andres
    Andres Well-Known Member Vendor
    Andres
    Hawthorne, CA
    2013 Toyota Tacoma TRD off-road
    X2~!!!
  16. Nov 29, 2011 at 2:30 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    It's very hard to diag things in a forum. With strange sounds and weird Clanking noises you don't want to take chances. LOL
    Awesome you want to work on your own stuff.
    glad your set to go.
  17. Nov 29, 2011 at 2:30 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Damn, that was my next guess. Good job, and welcome to the site.
    Welcome to the internet. Now calm down.
  18. Nov 29, 2011 at 2:54 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    It's best to replace all the plugs at one time. Coat the threads with antiseize. Replace the wires as well. Add a dab of dielectric grease to the boots.
    Misfires can be caused by bad plugs, wires, coil packs or injectors. Bad wires and coil packs can be diagnosed by, in a dark garage, misting the wires with a spray bottle of water and look for leaking spark. Injectors can be swapped to see if the problem moves to the other cylinder.
  19. Nov 30, 2011 at 10:18 AM
    tacogriz
    griz
    arizona
    well, i kind of did that...not in a dark garage though...in the parking lot of autozone ..i took spark plug 3 out of the coil pack and turned the truck on....did not see any spark..took spark plug one off and turned it on...was spark....causing me to believe that the coil pack just needed to be changed...yup..
  20. Nov 30, 2011 at 3:15 PM
    tacogriz
    griz
    arizona
    truck all of a sudden started to lose power and fuck up again...i changed the oil....was pure black when it came out..no metal in it..therefore no internal engine problems...correct?......new air filter...checked the other coil pack and barley any spark coming out....going to change out the other coil pack and replace all plugs and wires tommorow....what a money pit!!!!thats two hundred something dollars in two days god dammit!!!!!...pepboys wanted 104 dollars to diagnose...theres no way in hell im going to let these dudes check it out for 100 bucks to tell me to change my plugs and wires!!!hahah....thought i fixed it...even got drunk in celebration...
    sincerley working on truck with hangover all day,
    grizelda.....
