New spark plugs, worse mpg
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jeff.W, Apr 26, 2014.
  1. Apr 26, 2014 at 9:36 PM
    Jeff.W
    Jeff.W [OP] Rather be fishing
    Brazoria County
    09 Pyrite DCSB TRD
    Bought truck used and just did a tune up after driving it a year. 92k miles and it had the original plugs in it. Mpg avg before was 18.5 mixed. The old plugs were worn to about .050 to .060. Gapped new plugs to .043. I bought the oem densos from the dealer. Installed a new oem air filter also. I have filled it up twice since the new plugs. Now getting 16.0-16.5 mpg. Wtf gives?
  2. Apr 26, 2014 at 9:47 PM
    iJDub
    iJDub Well-Known Member
    Try resetting the ECU?
  3. Apr 26, 2014 at 9:58 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Do you know when the MAF sensor and Throttle Body was cleaned last?
    That's an easy one to do and is never a waste of time. I don't know if the new/better spark is related to that via the ECU making new adjustments to your air intake... it's worth a shot and 1.5 hours of your time anyway.
  4. Apr 26, 2014 at 10:19 PM
    LuckyCharms
    LuckyCharms Knows a little about a lot
    Socal
    '13 PreRunner TRD dclb
    Bigger gap = more thorough of combustion = more efficiency = better gas mileage. I always gap my plugs as wide as I can without having issues. As long as the rest of your ignition system is good, go big. Manufacturers set the gap in a neutral zone of efficiency and reliability. If you don't mind a few days of testing, find where your maximum gap is (goes for any car) and you will have max fuel efficiency and power. You won't hurt anything on your truck.
  5. Apr 28, 2014 at 10:05 AM
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    I know this seems sort of counter-intuitive, but when I filled up my truck with Premuim (93) after cleaning the MAF and throttle body I got about 16mpg. When I went back to regular (87) about 3 tanks later I jumped to 17.something. To some people's taco it doesn't make a difference, to others premium runs better. For mine, the cheap stuff is the way to go.
    Didn't know about that, I may have to remember that when I change out my plugs soon.
