New speakers/sub/amp and the spacial dilemma... a JBL story
Discussion in 'Audio & Video' started by Denk, Aug 27, 2016.
  1. Sep 2, 2016 at 9:43 AM
    Denk
    Denk [OP] Well-Known Member
    PNW
    '13 Spruce TRD Sport DCSB
    If I need to get back in there for any reason, the raammat is pretty easy to cut and pull up. Then I can just make a new panel to replace. I initially thought about fabbing panels out of alu and bolting them in, but got lazy.
    The factory amp does a fair amount of signal processing and the LOC is needed to "sum" the signal and provide a low level input (rca) to the new amp. If you take the amp out, the HU stops working. I'm sure someone else could explain that better.
  2. Sep 2, 2016 at 11:39 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    I see - didn't realize you were keeping the factory HU.
  3. Sep 2, 2016 at 11:50 AM
    Denk
    PNW
    Post #2 updated.
  4. Sep 6, 2016 at 8:16 PM
    Denk
    PNW
    Decided to elevate the JBL amp instead of the LOC. This way, the LOC lays flat on the board and the RCAs will have a direct unobstructed route to the Arc amp. Came across www.speedymetals.com and ordered some aluminum 6061 angle to use as brackets/risers (1/4" x 3" x 3" cut in 1 3/8" lengths). Alu was only $5 but shipping was $16 :rolleyes:.
    Boomkanani likes this.
  5. Sep 10, 2016 at 5:10 PM
    Denk
    PNW
    Made some progress today with a front door,
    Painted the baffles,
    And took delivery of some important parts.
    Today was a good day. Now for my reward.
  6. Sep 10, 2016 at 6:04 PM
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    Is that grey top layer the ensolite? I've only put in the butyl w/foil layer so far. Haven't had the chance to research what sound proofing I want to use. Let us know how it works out!
  7. Sep 10, 2016 at 7:31 PM
    Denk
    PNW
    Yep. That's the ensolite. It helps decouple acoustical energy from resonating other parts of the door.
  8. Sep 10, 2016 at 8:19 PM
    Boomkanani
    Goldsboro, NC
    Some stuffz
  9. Sep 10, 2016 at 8:58 PM
    rob feature
    rob feature Tacos!
    Colorado
    Steve_nm likes this.
  10. Sep 10, 2016 at 10:01 PM
    Denk
    PNW
    That is some serious matting. I wouldnt mind laying that down on the floor once I'm done with everything else.
  11. Sep 11, 2016 at 1:11 PM
    Denk
    PNW
    Started dampening the driver door and ended up short on material. If you plane on going 100% coverage, the RAAMmat door package is not enough. Be sure to pick up a couple more sheets; this should also leave enough scrap to add to the back of the door panels.
    Pic of the double layer (8"x8") and ensolite behind the speaker (recommended).
    Tip: before removing the vapor barrier, make outlines of the spots that require extra attention, then use as a template. I was using saran wrap before I realized to just do it this way.
    This is for cutting out a patch panel for one of the access holes.
  12. Sep 14, 2016 at 8:50 PM
    Denk
    PNW
    Made some good progress the last couple days. Both rear doors are done and wired.
    Perfect fit. Marv's the man!
    #magneticallychallenged
    Nice 'n tight.
  13. Sep 16, 2016 at 9:39 PM
    Denk
    PNW
    Sound dampening complete. On to wiring.
    These tweeter brackets are a PITA. bent one of the mounting arms trying to loosen the bolts that hold the tweet to the adapter. Not to mention tearing up my hand in the process. Bent it back best i could, still a little tweaked.
    These are press fit into Marv's adapter, then go back on the original bracket.
    Also poked around in all the little nooks and crannies searching for a good location for the crossovers. No luck in finding some clever little spot, so just going to mount under the front seats with some velcro.
  14. Sep 17, 2016 at 9:31 AM
    Denk
    PNW
    Beautiful rainy day today, here in the emerald city. So time to show some love to the amp rack. Got my alu angle for fabbing brackets. Just need to run to the hardware store for some, umm... hardware. :cool:
    Heres the idea. Now there will be room for running the RCAs to the amp.
    Man of Steel TRD and Boomkanani like this.
  15. Sep 17, 2016 at 2:24 PM
    #35
    Denk
    PNW
    I really like how this turned out! The brackets will be secured to the board with T-nuts on the backside.
    Man of Steel TRD likes this.
  16. Sep 18, 2016 at 6:00 PM
    #36
    Denk
    PNW
    Test fitting and fine tuning the board.
    Backside, had to violate the corners a bit to get the T-nuts in since the new amp is a little too wide.
    Edit: I have never worked with MDF before, just carving out these little nut caves made a huge mess. I feel for anyone with allergies that works with this on a regular basis.
  17. Sep 18, 2016 at 7:01 PM
    #37
    rob feature
    rob feature Tacos!
    Colorado
    Coming along nicely Denk. Loving the detail in this one.
  18. Sep 19, 2016 at 4:56 AM
    #38
    Denk
    PNW
    Thanks, this has been a fun project so far and puts all my skills to the test.
  19. Sep 20, 2016 at 8:09 PM
    #39
    Denk
    PNW
    I stand corrected. Look like the crossovers will fit behind the kick panels. At least on the driver side. Nice n snug. Tomorrow I'll investigate the passenger side.
    Oooh... sexy.
  20. Sep 21, 2016 at 8:22 PM
    #40
    Denk
    PNW
    Annnd it fits on the other side as well.
    All the doors finished now. Still have to run the power wire from the engine bay, finish carpeting the amp rack and sub enclosure, them make all the connections. I can finally see the light!
