New speakers/sub/amp and the spacial dilemma... a JBL story
Discussion in 'Audio & Video' started by Denk, Aug 27, 2016.
  1. Sep 22, 2016 at 7:37 PM
    #41
    Denk
    Denk [OP] Well-Known Member
    PNW
    '13 Spruce TRD Sport DCSB
    Another piece of the puzzle...
    The power write was a PITA getting through the firewall grommet. Felt like i was gonna rip the shit out of it, but very strong material.
    I got the under hood LED on in this pic. Makes the fuse look like it had its own led.
    Still working the plan for tapping the jbl amp for inputs to the new amp, but at least all the wires are rooted to the back now.
    Man of Steel TRD and Boomkanani like this.
  2. Sep 23, 2016 at 6:25 PM
    #42
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    I think I need one of these
  3. Sep 23, 2016 at 9:54 PM
    #43
    Man of Steel TRD
    Man of Steel TRD Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    Me too!! That's exactly what I was thinking of for my fuse holders. Nice build man!! Really nice work. Can't wait to see it all done @Denk!!!
  4. Sep 24, 2016 at 5:18 AM
    #44
    kenrickv
    kenrickv Well-Known Member
    TN
    2016 Inferno DCSB OR
    Too many to list
    Nice write up. I started a similar JBL upgrade thread. Still waiting on my gear to come in but I have a plan for the JBL harness interface. It might give some ideas on yours if interested.
    https://www.tacomaworld.com/threads/3rd-gen-jbl-upgrade-round-2.448377/#post-13118862
  5. Sep 24, 2016 at 1:53 PM
    #45
    Denk
    PNW
    Thanks. My first real build thread. Ill be happy to have the music going again!
    Ill give that a read. Thanks. Right now, i have some ideas on the wiring but nothing real solid.
  6. Sep 24, 2016 at 2:36 PM
    #46
    Denk
    PNW
    @rob feature , @1sttruckguy78
    Heres a better pic of the whole thing. The arm that goes down, where the breaker is mounted, has a tab at the bottom that fits under the foot of the fuse box and is secured by the same bolt.
    A pic of my template.
    Man of Steel TRD likes this.
  7. Sep 24, 2016 at 5:38 PM
    #47
    rob feature
    rob feature Tacos!
    Colorado
  8. Sep 25, 2016 at 12:51 PM
    #48
    Denk
    PNW
    So after researching posts from the TW pioneers and cross-referencing against what I found in my truck, I came up with the below. The only part I am still uncertain of is the sub wiring. I know it has two voice coils, but not sure which is which. I left out the 24-pin plug since that seems to be all the inputs to the stock amp. Although, it would be nice to know which is the acc power, so I can tap for remote-on for the LOC and new amp.
    After a visual inspection of wiring:
    12-pin plug (white)
    01 - violet
    02 - pink
    03 - blue
    04 - blue/black
    05 - green/yellow
    06 - brown
    07 - brown
    08 - empty
    09 - light green
    10 - blue/red
    11 - empty
    12 - green/white
    10-pin plug (blue)
    01 - white/blue
    02 - blue
    03 - black
    04 - white
    05 - white/blue
    06 - pink
    07 - red
    08 - red/white
    09 - yellow
    10 - red
    4-pin plug (white)
    01 - blue/black
    02 - green/yellow
    03 - blue/red
    04 - green/white
    And the final pinout when combined with other research. The 4-pin plug wires match those of the 12-pin plug.
    12-pin plug (white)
    02 - FL+ pink
    01 - FL- purple
    09 - FR+ light green
    03 - FR- blue
    05 - WFL+ green/yellow
    12 - WFL- green/white
    04 - WFR+ blue/black
    10 - WFR- blue/red
    10-pin plug (blue)
    03 - RL+ black
    09 - RL- yellow
    10 - RR+ red
    04 - RR- white
    08 - TWL+ red/white
    07 - TWL- red
    02 - TWR+ blue
    06 - TWR- pink
    *Edited for accuracy based on new information.
  9. Sep 25, 2016 at 3:19 PM
    #49
    fergsonfire
    fergsonfire Electrical Guru
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    I have a 2013 DCSB that had JBL Entune as well. This should give you everything you need.
    See the attached PDF
  10. Sep 25, 2016 at 3:25 PM
    #50
    fergsonfire
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    Subwoofer wiring is on the White 12 pin
    04 - Green/Yellow WF1+
    05 - Blue/Black WF2+
    12 - Green/White WF1-
    10 - Blue/Red WF2-
    Accessory (Remote Turn On) is on the White 24 pin
    12 - Grey
  11. Sep 25, 2016 at 5:00 PM
    #51
    Denk
    PNW
    F*CK YEAH! That is freakin' awesome! Thanks, man! You just saved me so much grief.
    :bowdown: :hattip:
  12. Sep 25, 2016 at 5:05 PM
    #52
    fergsonfire
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    I did this myself at first and then said screw it and went aftermarket head unit so I know your pain. Best bet is to get an LC8i and sum channels 1/2 (Front and tweeters) then us the two sub inputs as stereo on channel 4, LC6i doesn't have enough channels. The other thing you could do is get a Rockford Fosgate 3sixty.3 instead and use the line level inputs, that way you are set for the future and can tune the system as well. Either way you are going to need 8 channels if you want everything from the JBL amp.
  13. Sep 25, 2016 at 5:18 PM
    #53
    Denk
    PNW
    I was thinking about the LC8i, but after some convos with Marv and reading a few other posts, it looked like the LC6i would be enough. Below is what I was planning.
    Main Input: front speakers
    Channel 2: tweeters
    Channel 3: rear speakers
    Then for the sub, run it direct to the new amp using a rockford fosgate high to low level adapter. Do I need to revaluate?
  14. Sep 25, 2016 at 5:22 PM
    #54
    fergsonfire
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    yeah I guess that would work too, saves you a few bucks. I don't know the quality of the RF H/L so couldn't comment on that. I am big on controlling everything. I personally started with the LC8i and then realized how shitty the JBL eq is and went to a RF 3Sixty.3. Eventually even that wasn't enough so I swapped out the head unit to, haha. Keep me up on how your install goes, I love watching the audio/electronics as I have been a tech nut for decades.
  15. Sep 25, 2016 at 5:33 PM
    #55
    Denk
    PNW
    Yeah, I was really torn between going with a new HU (and all the great functionality) and sticking with the stock JBL (+all the other work), but I really love the stock look. I too want control of everything, but it's not so important in this application since I dont spend THAT much time in the truck (3 yo and just hit 28K on the odo). What I'm really saving for, and planning the shit out of, is the theater room in my new house. Plus, the wife is way more likely to approve the expense since she is an intense collector of music and video.
  16. Sep 25, 2016 at 5:46 PM
    #56
    fergsonfire
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    Nice, yeah I have been spending too much on my home theater now that the truck is setup (minus some rewiring). Check out Aperion Audio for home theater speakers. Their Verus Grand line is AMAZING for a pretty low price comparatively.
  17. Sep 30, 2016 at 11:23 AM
    #57
    Denk
    PNW
    Definitely a skill learned by practice practice practice. Mine didn't turn out so bad. At least the fronts are presentable and the small screwups are hidden on the sides.
    20160930_092319.jpg 20160930_100236.jpg 20160930_110945.jpg 20160930_111016.jpg
  18. Sep 30, 2016 at 5:21 PM
    #58
    Denk
    PNW
    Well, after getting the carpeting finished and getting all the wires routed to the back end, I popped in the amp board and sub enclosure to see how things were gonna fit. The bottom seat makes a lot of contact with the sub enclosure. Once the sub is asctually installed in the box, I don't think it's gonna fit at all. I'll post some pics later.
    I remember reading about someone moving the bottom seat forward with spacers. Anyone have a quick link? I'll search around some... I know it's around here somewhere.
    Edit: Yup, here we go... https://www.tacomaworld.com/threads/rear-seat-rub-issue.64978/
  19. Sep 30, 2016 at 6:49 PM
    #59
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Nice job!!
  20. Oct 2, 2016 at 12:08 PM
    #60
    Denk
    PNW
    Alright, getting things wired... there is some confusion on how to properly add the inputs and afix the jumpers for summing on the LC6i. After a bunch of reading, I have come up with the below.
    For separate factory signals (tweeters and mids in front), connect the tweeters to channel 1, the mids to channel 3 and the rear to channel 2. Sum channel 3 to main and leave channel 2 separate. On the output side, channel 1 is your front signal (summed from channel 1 and 3), channel 2 is your rear signal (remains separate) and channel 3 is your sub signal (using the front door woofer signal).
    Does this sound right? Or should I be running the sub signal directly to the amp, ano not using one of the outputs from the LOC?
