New speakers/sub/amp and the spacial dilemma... a JBL story
Discussion in 'Audio & Video' started by Denk, Aug 27, 2016.
  1. Oct 8, 2016 at 12:06 PM
    #101
    Denk
    Denk [OP] Well-Known Member
    PNW
    '13 Spruce TRD Sport DCSB
    Connections to the jbl amp speaker outputs. You can also see the ground for the LOC (top) and ground spot for the amp (bottom).
  2. Oct 8, 2016 at 12:50 PM
    #102
    Denk
    PNW
    Still not sure about coiling the rcas under the jbl amp, but it's okay for now. These are 3ft, need more like 1.5ft.
  3. Oct 8, 2016 at 1:57 PM
    #103
    Denk
    PNW
    Major milestone reached. Everything wired (for testing) and powered on for the first time. After making connections at the battery, and before turning the key to the accessory position, I got a blinking orange light on the amp. Judging by its flashing nature, i presume this to be a diagnostic code of some sort. I switched the key to accessory and the bling orange went solid green. I wonder it it just had to reset itself after being powered up for the first time? I need to check the documentation before proceeding any further.
  4. Oct 9, 2016 at 2:44 PM
    #104
    Denk
    PNW
    Well, the product manual didn't reveal anything about this particular scenario, so i proceeded carefully from the beginning. Check the ground at the amp and LOC, check the +12v and remote in/out, then one by one attach each pair of RCAs, then one by one attach each pair of speaker wires then the sub. Everything checked out, the amp stayed solid green and music started pouring out. I'll burn in for a week or so before final tuning and dress-up of the wires. At low level, the HAT components sound pretty good.
  5. Oct 10, 2016 at 11:08 AM
    #105
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I did 3 coats of primer and 2 coats of DEI Boom Mat spray on my adaptors, I love the way they came out. I am going to do my box/amp rack this same way but just do 2 light coats of primer and 1 coat of regular matte paint on the back of the box to seal it up
    Oh and this is my back wall
  6. Oct 10, 2016 at 4:52 PM
    #106
    Denk
    PNW
    Interesting. Looks like a rubber spray. I'm def going with paint on any future builds.
    Day one listening to the new system, I have to turn the HU volume up a lot more to get the same level as before. I presume this will change as soon as I finish tuning and turn up all the dials on the amo and LOC.
  7. Oct 20, 2016 at 5:22 PM
    #107
    JoseyWells
    JoseyWells Well-Known Member
    Joe
    Corona, CA
    12 prerunner
    Demello sliders, Icon ext coilovers, icon rear shocks, icons UCAs, 17" Konig Countersteer Type X, 285/70/17 Nitto Trail Grapplers
    whered you get the carpet from?
  8. Oct 20, 2016 at 7:44 PM
    #108
    Denk
    PNW
    Honestly, I can't exactly remember now, but fairly certain it came from crutchfield.
    JoseyWells[QUOTED] likes this.
  9. Nov 5, 2016 at 8:04 PM
    #109
    Denk
    PNW
    WARNING: Avoid adding inline LOC at all costs!! Severe angst and confusion follows.
    Spent a good part of the day working with @Mr Marv on tuning the system. Final result came out great. Marv definitely knows his sh*t.
    Original LOC setup:
    Input from JBL amp
    main: tweets
    ch2: rears
    ch3: fronts
    Output to new amp
    main (summed with ch3): fronts
    ch2: rears
    ch3: sub
    While working through the front speakers, I found that the sub signal was quite weak; adjusting the bass knob made no difference. We eventually decided that the ch3 input was not a full signal and the whole arrangement needed rework. We tried summing all channels, but only caused more headache. After much deliberation and questioning why audioControl would create such an overly complicated, almost out-dated, processor for the laughable purpose of providing multiple full range signal outputs...
    Input from JBL amp
    same as before
    Output to new amp
    ch2: rears
    ch3: not used
    Brought the sub signal straight from the JBL amp. Now everything works like it should, while maintaining complete fade functionality.
    I still need to finish routing and mounting the bass knob and some minor cosmetics on the amp rack. Other than that, bring on the tunes!
    Man of Steel TRD and Boomkanani like this.
  10. Nov 13, 2016 at 4:38 PM
    #110
    Denk
    PNW
    Nice n tidy...
    Hidden bass knob.
  11. Nov 13, 2016 at 4:42 PM
    #111
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    Nice Set Up!! Well Done!
  12. Nov 13, 2016 at 8:09 PM
    #112
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    Looks great man!
  13. Nov 14, 2016 at 4:19 AM
    #113
    Denk
    PNW
    Thanks!
    Soul Surfer[QUOTED] likes this.
  14. Nov 14, 2016 at 7:32 AM
    #114
    Soul Surfer
    Jimi
    ‘25 TRD OR
    Was the Mass Vinyl that you used self adherence? And a item # if it's convenient. Thanks.
  15. Nov 14, 2016 at 11:56 AM
    #115
    Denk
    PNW
    Yes, the material is very sticky, but still easy to work with. Details found in post #2. Raamaudio also offers a discount for forum members.
  16. Nov 28, 2016 at 5:32 AM
    #116
    Denk
    PNW
    Alright, it's been two weeks, time for a mini review. System has been performing flawlessly. The stock HU gives very little control over the levels, but that was to be expected. Otherwise the HAT components and Arc amp are handling quite well. I'm picking up on more of the fine detail in the music I'm playing, like the sound of fingers sliding over guitar strings. notes are more pronounced and less of a quagmire of indistinguishable sounds.
    I had an alarm installed last week and the guy was trying to upsell me on a bit10 processor. while I'm sure that would help to squeeze every last ounce of available tuning out of the system, I think it would defeat the purpose since I'm still running the stick jbl amp.maybe one day, but for now an very happy.
    One thing not up to par is sound when making a hands-free call via BT. not sure if there is adjustment for that, but i have to turn up the volume more than what's comfortable to actually hear the voice clearly.
  17. Dec 10, 2016 at 2:28 PM
    #117
    Denk
    PNW
    Bit of an update. A couple days ago, a somewhat loud 'crack' came from the back seat and the radio cut out for a couple seconds then came back. Last night, same thing, except is was multiple 'cracks'. I immediately turned off the HU for fear something was shorting. This morning, I turned the HU on with some music and started poking connections to see if I could reproduce the 'crack'. Nothing. Getting close to the rear door speakers, I can hear a little static, but still mostly clean sound coming out. The fronts did not seem to have the same static.
    Any thoughts?
    @Mr Marv
  18. Dec 10, 2016 at 2:35 PM
    #118
    Andres
    Andres Well-Known Member Vendor
    Andres
    Hawthorne, CA
    2013 Toyota Tacoma TRD off-road
    Great job!
  19. Dec 10, 2016 at 3:51 PM
    #119
    Man of Steel TRD
    Man of Steel TRD Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    Sounds to me like something is grounding out. is anything on any sharp metal that might move just right and make contact?
  20. Dec 10, 2016 at 5:23 PM
    #120
    Denk
    PNW
    That's what i have been looking for, but nothing found yet. probably 80% of the wiring has extra sheathing as well.
