New speakers WOW
Discussion in '3rd Gen. Tacomas (2016-2023)' started by iridelow, Sep 18, 2019.
  1. Oct 10, 2019 at 11:50 AM
    #101
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    For those with the Kicker Key Amp - How involved is the install?
    I already have the Subaru tweeters, and Kicker speakers installed, and while the stereo sounds much better than stock, it still is lacking. It's a lease so I don't necessarily want to add a sub, and feel with a little more power these upgraded speakers could sound much better.
    GreyBaldTaco likes this.
  2. Oct 10, 2019 at 11:57 AM
    #102
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    Not bad. There is a write up in the audio section including making a plug and play harness.
  3. Oct 10, 2019 at 12:00 PM
    #103
    aturk
    Tony
    Charlotte, NC
    Anybody making a harness? I just viewed some posts of people making a harness, while I'm more than capable, as my truck is a lease I definitely don't want to go cutting up the factory harness.
  4. Oct 10, 2019 at 12:17 PM
    #104
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    I was hoping to find someone to make the harness for me as well, so far I haven't found one.
  5. Oct 10, 2019 at 12:47 PM
    #105
    MrGooch
    MrGooch Well-Known Member
    2021 Black TRD Pro
    I have the JBL system in my 19 so the subaru tweeter thing doesn't apply to me. Can I simply replace the stock door speakers with something or do I have to re-do my entire setup, incl headunit?
  6. Oct 10, 2019 at 4:14 PM
    #106
    Dogtown Darren
    Dogtown Darren Well-Known Member
    Powder Springs, Georgia
    2002 Tacoma Double Cab Pre-Runner TRD Limited
    I'm kind of a noob at this stuff, once you get the door panels off, is this a simple plug and play swap, or will some additional wiring have to be done?
  7. Oct 10, 2019 at 5:03 PM
    #107
    aturk
    Tony
    Charlotte, NC
    You will have to plug the Crutchfield supplied connectors onto the speaker, and they will allow you to plug directly into your factory harness. You will need to mount the speakers (they come with the necessary screws) to the Crutchfield supplied speaker adapter plates. Then use the factory hardware to mount the speaker to the doors. It's easy. You will have to drill new holes to mount the 4th screw on the front speakers to the adapter plates. You will also have to trim some of the adapter plate (easy with a dremel).
    All in all, it probably took me 3 hours beginning to end. I had some trouble figuring out the door panels, mainly how they go back on.
    Real easy overall. I could do it again in 30 minutes.
  8. Oct 16, 2019 at 3:00 PM
    #108
    MarineBob
    MarineBob Well-Known Member
    Bob
    Massachusetts
    2024 TRD Sport Long Bed
    Step bars coming
    Installed the speakers this afternoon. I would say the hardest part is removing the cable plug. But as others noted, take your time, push the clip part and it pops off. I would say they are an improvement but I am not sure these speakers are a $100 improvement if that makes any sense at all. I tested the first install vs. the original in the other side and there is definitely improvement, the replacements sound more like real speakers rather than buzzers. One note on my '17 TRD Off Road, on the passenger side there is , I guess a light sensor of some sort. I was not sure how to unclip its wire so I left it in place and worked around the speaker grill still connected to that wire. Just made it a bit tighter to get at the windshield side bolt but not too bad. Oh yeah, one thing I did was stuff some shop towels into the crevasses around the speaker once the grill was off. If I didn't do that I am convinced I would have dropped a bolt into the abyss of the dash, never to be seen again. Maybe next I will go for the doors. Appreciate the helpful comments.
  9. Oct 16, 2019 at 3:08 PM
    #109
    GreyBaldTaco
    2019 F150 5.0
    Give the speakers some time to break in, I felt the same way initially. They are sounding much better now imo.
  10. Oct 16, 2019 at 3:22 PM
    #110
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    From what I have read, there is nothing at this time compatible with JBL system.
  11. Oct 16, 2019 at 3:53 PM
    #111
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    I don't get why everyone is doing the kicker upgrade, Kicker speakers are usually crap, are they better than stock? Yes, but they're so cheaply made too
  12. Oct 16, 2019 at 5:52 PM
    #112
    Tacospike
    Two Trucks
    Yeah, most haven’t had a lot of experience with different speakers and brands. Once one thing pops up everyone gets on it. From the thousands of people upgrading and having longevity of good use over the years, I can see the hype and choice for these especially from most running through stock HU
  13. Oct 23, 2019 at 1:41 PM
    #113
    MarineBob
    Bob
    Massachusetts
    Step bars coming
    Had the dash speakers installed for a while now. Definite improvement over stock. One observation that a 12 year old might have known : working an Amazon playlist off my wife's phone was Ok, not great. But then it occurred to me that I had to push the HU volume to way past half, maybe 3/4+ just to get moderate loudness. So upped the phone volume and made a world of difference lowering the HU volume. Full disclosure, I do not own a cell phone but I thought a bluetooth connection would not rely on the phone's volume as it is sent to the receiving unit. I guess I learned something there. Anyway, with the phone volume up and the HU volume down, much, much better reproduction with the new tweeters. Worth the effort especially with my midrange listening preferences.
    A question that is probably answered elsewhere. Can you have a bluetooth connection, say to play music and plug the phone into the USB to charge at the same time? If you can, I sure as hell can not figure out how. I am able to play a music playlist while charging using Apple Carplay in my wife's Mercedes, but that's not an option in the TACO. Is my observation right about the blue tooth OR charge, but not both simultaneously?
  14. Oct 23, 2019 at 1:45 PM
    #114
    MarineBob
    Bob
    Massachusetts
    Step bars coming
    Hey GreyBald, Semper Fi. I just noticed the EGA. Those are Marine Phantoms in my pic
  15. Oct 23, 2019 at 4:50 PM
    #115
    blackmist27
    blackmist27 Well-Known Member
    17 Tacoma TRD Pro
    Leer shell 100XR
    i think this is worth doing... how hard is it to do the install yourself?
  16. Oct 23, 2019 at 4:55 PM
    #116
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    Better than stock is a gross understatement.
  17. Feb 1, 2020 at 7:23 AM
    #117
    SmileyGuy
    SmileyGuy Well-Known Member
    Darrin
    Nova Scotia
    20 Tacoma Off Road Voodoo Blue DC SB TRD Premium CAN
    This should be a sticky that is the top topic in the audio section.
  18. Feb 1, 2020 at 8:24 AM
    #118
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Was the 1st mod I did to my truck. Kicker speakers (the better ones) Subaru tweeters and kicker amp with the PnP harness. Was the easiest stereo install I've ever done. The only thing that went wrong is that I did the install on a windy day and the stock speakers I took out all blew away into the woods and I can't find them :)
    SmileyGuy likes this.
  19. Feb 1, 2020 at 10:15 AM
    #119
    Griswold
    Griswold Lurker
    Taco
    What brand/type and if you don't mind me asking how much did the lot cost ya?
  20. Feb 1, 2020 at 11:01 AM
    #120
    TacoSupremo19
    NJ
    This was my entire order
    The subaru tweeters are here
    https://www.amazon.com/gp/product/B00PV6F8I2/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
    The 2 harnesses for the amp install
    https://www.amazon.com/gp/product/B0002BEQJ8/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
    https://www.amazon.com/gp/product/B00029X1KA/ref=ppx_yo_dt_b_asin_title_o03_s01?ie=UTF8&psc=1
    And some Kilmat sound deadening
    https://www.amazon.com/gp/product/B0751CBXBT/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    Guess I spent near $500.
    Didn't have to cut anything. ALL the brackets lined up using original mounting hardware.
    It took me about an hour to put in all 4 speakers. Probably would have been less if those stupid little plastic clips on the rear door pillars weren't falling out.
    Hardest part was finding a good picture of the harness to go by. Once I started soldering it up though I realized that almost all the color wires matched up and just tie the blues together. I had a little trouble disengaging the one blue loop wire though. There's a tool for it that I don't have. I'm sure that there'e a McGyver way but it was late so I just cut that little section of the plug up as it was not being used anyway. You'll see what I mean if you get into this. This thread has the right info for the harness and Destin Meeks knows his stuff
    https://www.tacomaworld.com/threads/kickercs-upgrade-with-kicker-key-amp-install-assistance.568985/
