New Sport Rims no TPMS, What do I need?
Discussion in 'Wheels & Tires' started by Rhody76, Apr 3, 2011.
  1. Apr 3, 2011 at 8:48 AM
    Rhody76
    Rhody76 [OP] Well-Known Member
    Rhode Island
    2011 SR5 DCLB 4x4
    Rear leaf TSB, Bilstein 5100s set at 1.75",1" blocks, UWS low profile toolbox in black, husky liners, tint, LED interior and reverse lights, yellow fogs
    So I just purchased a new set of 17" sport rims from a seller on ebay. These do not come with TPMS. If I want to have TPMS installed on these what exactly do I need and what am I looking at for cost? I have seen a set of 4 tpms on ebay for around $150. I have a buddy who is a mechanic so I'm pretty sure he has the tool to program them.
    I do have the 16" steelies with the TPMS still installed but from what Ive read these are not compatible with the 17" alloys. Has anyone had succcess using the TPMS from the steelies with the 17" alloys??
    I really dont want to put a piece of electrical tape on my display to hide the light but I dont want to spend big $$ on new sensors and programming. Any advice would be appreciated.
  2. Apr 3, 2011 at 8:53 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You have to turn the sensors 180° for them to work in alloy wheels IIRC.
  3. Apr 3, 2011 at 8:59 AM
    azntha1one
    azntha1one Well-Known Member
    Sean
    Long Beach
    06 Prerunner
    A few
    you would a new set of tmps with an 40 degree offset. i dont believe the stock steels tmps will work, but dont quote me on it.
    if your purchasing them on ebay just make sure its compatible. btw, a dealership will want $400+ for a set of tmps. that is from my experience.
    if you have the extra cash, i would get a new set of tmps. otherwise, electrical tape it.
  4. Apr 3, 2011 at 10:22 AM
    cyclonerider2
    cyclonerider2 Active Member
    Youngstown, Ohio
    PreRunner
    So, if I run wheels with no TMPS for the summer and just cover the warning light, will that cause any problems with the vehicle or the computer? I've been wondering about what to do if I install aftermarket wheels. It doesn't bother me to cover the light. When I reinstall the stock wheels for the winter, can I reset the system or does that need to be done at the dealership?:confused:
  5. Apr 3, 2011 at 12:22 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    So turning them 180 degrees will work and I can use the ones I have?
  6. Apr 3, 2011 at 12:56 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    There's been mixed sucess with various shops trying this. For some, it has worked, others the shops claimed they couldn't get the tire on with the TPMS rotated.
    You can get a set of wheel straps and use standard valve stems also. The wheel straps strap the old TPMS sensor to the center of the wheel so their still functional. Some members are running these with aftermarket wheels so they could keep their stock sensors.
    http://www.revolutionsupply.com/strapkit.aspx
    (I just googled it and this was the first supplier that came up)
  7. Apr 3, 2011 at 1:06 PM
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    ive seen people put their old sensors in a piece of pvc with a valve stem and pump it up to 30 psi. then just ziptie it under your truck somewhere. then you dont have to buy new sensors and your light wont be on.
  8. Apr 3, 2011 at 7:07 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    x2, I had to use the TPMS straps.
