New Sprider Trax wheel spacer Vibrations?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1YOTA6, May 13, 2013.
  1. May 13, 2013 at 6:34 PM
    1YOTA6
    1YOTA6 [OP] 1YOTA6
    Kyle
    Rochester, NY
    11 Db cab LongBed Tacoma 4x4 Sport
    ReadyLift 2.75 leveling lift, 1.5inch spider trax wheel spacers, Plasti-Dip wheels and front grill, Under carriage reverse spot lights, OTTRA Switches, wether tech floor mats, Toyo Open Country AT 285-70r17, on the waiting list for HomerTaco Grill :)
    Ok so majority ruled on here that SpiderTrax wheel spacer were the better set up to get out of all spacers.
    I installed 1.5 in spacers this weekend on the truck and now have a vibration that comes and goes as i drive down the road at various speeds.....
    everything is tight and torqued properly... so whats the deal? Is this something im going to have to deal with?
    Hub centric vs. lug centrics.....
    These seem to be Hub centric spacers but what about where the wheel bolts to the spacer that leaves the lug nuts to center the wheel as a lug centric finnish to this design.
    Not very happy about this
  2. May 13, 2013 at 6:44 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I do not recommend spacers :cool:
  3. May 13, 2013 at 6:57 PM
    1YOTA6
    1YOTA6 [OP] 1YOTA6
    Kyle
    Rochester, NY
    wheels have been re-torqued and nothing was loose. same vibration as before when first installed....
  4. May 13, 2013 at 7:06 PM
    1YOTA6
    1YOTA6 [OP] 1YOTA6
    Kyle
    Rochester, NY
    no I was suppose to get the lift in but it has yet to show up.... little pieces at a time i guess....
  5. May 13, 2013 at 7:08 PM
    boopie
    boopie 05trdoffroad
    Ramon
    San Diego
    05trdoffroad
    Toytec/Eibach Bilstein set at .85, URD TCAI , TRD catback exhaust,1.5" AAL
    Try getting a alignment done. I had the same problem and the vibe went away since i got alignment done. Nothing wrong with using spacers.
  6. May 13, 2013 at 7:22 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Did you rotate your tires when you installed the spacers?
    If you did, it is common for a tire moved from the rear to the front to cause a vibration.
    If you do have a wheel out of balance it will be noticeable on the front compared to the rear.
    Either way it is a balance issue or installed incorrectly.
    When I say installed incorrectly besides the obvious install, did you clean the rotor face where the spacers mounts against, did you clean the rear face of the wheel that contacts the spacer. Any debris can cause issues.
  7. May 13, 2013 at 10:13 PM
    scotch
    scotch Well-Known Member
    Mark
    Centennial, CO
    2012 Tacoma, 2015 Tacoma, 2005 4runner 4.7L
    Lots of Stuff
    Try taking them off and reinstalling before you spend and money...
  8. May 14, 2013 at 7:08 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Hubcentric is a must, and are you sure that you dont have a stud not below the lug hole? If not sure get a straight edge and make sure, if its up even a bit this will mount the wheel at an angle and cause a vibration issue.
