New spring packs VS Helper springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thatsmrdrew2u, Jun 19, 2021.
  1. Jun 19, 2021 at 5:10 AM
    Thatsmrdrew2u
    Thatsmrdrew2u [OP] Member
    Drew
    Vermont
    Tacoma double cab
    Who can help me with this ... My stock tacoma seems like it has a bit of a sag in the back, we have been looking into getting a Bed rack and tent so thats going to add a few hundred extra pounds, I have found the OME spring packs which state they allow for 660 pounds over stock i just recently found a helper spring setup that states to allow 1100 pounds over stock. Can anyone tell me the pros and cons of going with one over the other ?
  2. Jun 19, 2021 at 5:34 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Whole leaf pack replacement will always be the better choice over helper springs with a sagging factory pack. Ride quality will also be better with or without a loaded bed with the OME pack. This answer would also apply with an aal setup vs a whole leaf pack .
    Thatsmrdrew2u[OP] likes this.
  3. Jun 19, 2021 at 6:00 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    I had a OEM leaf pack + AAL. Stock springs were sagging, even with AAL. Installing an AAL won't 'unsag' your OEM springs, but you will get lift.
  4. Jun 21, 2021 at 3:04 PM
    Thatsmrdrew2u
    Drew
    Vermont
    Tacoma double cab
    so i ended up ordering new OME heavy duty spring packs, new shocks, new rubber bumpers, new spring bushing kit, still need new shackles, new ubolts , ? what else could i be missing ?
  5. Jun 21, 2021 at 3:27 PM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    Grease for the squeak.
  6. Jun 21, 2021 at 3:37 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Yep, get ready for squeaky leaf springs. OME for 2nd gen are notorious for this.
    If it's not too late to cancel your order, go to Exit Offroad (@Crikeymike ) and get a set of the Dobinson's leaf springs.
    Crikeymike likes this.
  7. Jun 22, 2021 at 6:03 AM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    Thanks for the tag. The 3 different Dobinsons leaf packs just came back into stock, but the 111R's will run out again here in a day or 2...
    OP, a full leaf pack will generally always work better at carrying a constant load than adding a helper spring to the stock leaf pack.
