NEW! Stealth LED Light Bar Kit for 2016-2019 Toyota Tacoma | Diode Dynamics
Discussion in 'Diode Dynamics' started by Diode Dynamics, Jun 13, 2019.
  1. Jun 13, 2019 at 1:57 PM
    Diode Dynamics
    Diode Dynamics [OP] Automotive Lighting Experts Vendor
    St. Louis, Missouri
    Stealth LED Light Bar Kit for the 2016-2019 Toyota Tacoma | Diode Dynamics
    Diode Dynamics is excited to announce our Stealth LED Light Bar Kit for the 2016-2019 Toyota Tacoma! Computer-designed specifically for the Tacoma, this LED light bar kit secures a 30” Stage Series LED Light Bar using factory mounting points. There is NO cutting or drilling needed!
    The included steel powdercoated brackets allow you to easily mount the 30" Stage Series LED Light Bar in the factory lower grille opening. Again, these brackets use OEM mounting points, so you won’t have to modify your Tacoma! This Stealth LED Light Bar Kit retains the factory lower grille for a clean, OEM-like appearance. Additionally, if preferred, the lower grille can be modified to make the light bar more visible.
    Features:
    • Direct fitment on 2016-2019 Toyota Tacoma.
    • Allows you to mount one 30" light bar in the lower grille opening.
    • CAD-designed for perfect fitment and OEM-like appearance.
    • Utilizes existing mounting points for easy installation - no cutting or drilling required.
    • Highly durable powdercoated steel construction.
    • Plug-and-play wiring harness included to power light bars.
    Diode Dynamics Stage Series Light Bars have been designed using optical simulation modeling, for maximum functionality. Their custom-engineered TIR optics provide FAR more usable light output than much larger, heavier generic LED light bars. Depending on your auxiliary lighting needs, you can order our Stealth LED Light Bar Kit with a white or amber light bar, with the following optic options:
    Driving: The Driving pattern was designed to supplement your high beams. Rather than a simple "spot" pattern, the Stage Series Driving pattern has a rectangular 20Wx8H degree pattern that is far more useful for directing light downrange at high speeds.
    Flood: The Flood pattern was designed to provide uniform, even illumination and a full 80Wx50H degree spread of light. Unlike generic "flood" light optics that are simply a heavily diffused spot, our flood optic is a true optically designed spread, resulting in the biggest spread in the industry! It is perfect for lighting up anything at low speeds, a backup or reverse light, or to light up a worksite.
    Combo: The Combo pattern combines both the Driving and Flood optics. It shines light downrange in a focused, rectangular 20Wx8H degree pattern while also illuminating area around it in a full 80Wx50H degree spread. The Stage Series 30" Combo Light Bar features three driving lenses in the middle with two flood lenses on the outer edges.
    Each Stealth LED Light Bar Kit features everything you need to install it on your 2016-2019 Toyota Tacoma, including:
    • Two (2) Application-Specific Heavy-Duty Steel Brackets for Installation on 2016-2019 Toyota Tacoma
    • One (1) SS30 Stage Series 30" Light Bar
    • One (1) Heavy Duty Single-Output Harness
    • All Necessary Hardware
    • Installation Guide
    Installation: Installing our Stealth LED Light Bar Kit is simple and straightforward, requiring only basic hand tools. Check out our step-by-step installation guide for detailed instructions, or watch the install video below!
    Fitment:
    • Fits all 2016, 2017, 2018 and 2019 Toyota Tacomas
    • Fits all trim levels including Limited, Limited RWD, SR, SR5, SR5 RWD, TRD Off Road, and TRD Pro
    Diode Dynamics Stealth LED Light Bar Kit for the 2016-2019 Toyota Tacoma is proudly engineered and tested right here in the USA, and is backed by our 3-year worry-free warranty! Want to check out more LED lighting upgrades for your 2016-2019 Toyota Tacoma? Click here!
    *PM us for the free-shipping code* (U.S. forum members only)
    Thanks for looking!
    Jake H.
    Diode Dynamics
  2. Jun 14, 2019 at 7:09 AM
    rgvaggie11
    rgvaggie11 Well-Known Member
    2017 Quicksand TRD 4x4
    I need to see a review on this asap!!!! Been looking into a bumper light bar
  3. Jun 16, 2019 at 8:35 PM
    tedsm556
    tedsm556 Active Member
    Tommy
    Brevard County, Florida
    2019 White Tacoma TRD Off-Road
    - Toyota OEM Predator Tube Steps - Toyota OEM All-Weather Floor Mats - EyeCatcher Tailgate Insert Letters Matte Black - Toyota OEM Door Sill Protector w/ White Vinyl Decal - Rexing V1P 3rd Gen Front + Rear HD Cameras w/ Hardwire Kit - Diamondback SE Truck Cover - Total Chaos Bed Stiffeners - Toyota OEM Tacoma Bed Mat - Toyota OEM Bed Header Rail - Diode Dynamics Interior LED Lighting (Dome, Map, Vanity, License Plate) - Diode Dynamics Stealth Light Bar Kit (30" DD Stage Series Light Bar and Mount)
    Very interesting, how does it compare to all the competition?
  4. Jun 17, 2019 at 8:41 AM
    Diode Dynamics
    St. Louis, Missouri
    mcharfauros likes this.
  5. Jun 18, 2019 at 7:35 AM
    Diode Dynamics
    St. Louis, Missouri
    More output shots coming soon!!
    Jake H.
    Diode Dynamics
  6. Jun 20, 2019 at 9:08 AM
    Diode Dynamics
    St. Louis, Missouri
    Check out that fitment! You can also remove the secondary lower grille if you want maximum light output!
    Jake H.
    Diode Dynamics
    tedsm556 likes this.
  7. Jun 21, 2019 at 6:30 AM
    tedsm556
    Tommy
    Why aren't these brackets aluminum? I just realized they are powder coated steel and will probably rust within a year in Florida...
  8. Jun 21, 2019 at 1:15 PM
    tedsm556
    Tommy
    Review/thoughts coming soon. Received mine today and am installing now.
  9. Jun 24, 2019 at 8:29 AM
    Diode Dynamics
    St. Louis, Missouri
    Definitely keep us posted on your thoughts! Regarding the bracket material, our engineers report that an aluminum solution would likely be too soft for the abuse our kits endure off-road.
    Even if the bracket didn't bend right away, it's entirely possible that the mounting points could shear if jolted hard enough.
    Hope this helps, and thanks for your support!
    Jake H.
    Diode Dynamics
  10. Jul 2, 2019 at 12:09 PM
    Diode Dynamics
    St. Louis, Missouri
    Don't forget to shoot us a PM for free USPS shipping on any U.S order!
    Jake H.
    Diode Dynamics
  11. Jul 17, 2019 at 8:10 AM
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    @Diode Dynamics Please can you clarify the electrical interface? Does it plug/play in parallel with the high beam circuit? Do I need to supply a relay/relay harness/cabin switch? Please specify mating connector (manufacturer/part#) I need to supply and pinout. If I am designing/supplying harness, what is the steady state current draw of the amber combo light bar on battery voltage (engine off), or running engine, whichever higher?
    Sorry if this is stated somewhere, I looked but did not find.
    Diode Dynamics[OP] likes this.
  12. Jul 17, 2019 at 12:10 PM
    Diode Dynamics
    St. Louis, Missouri
    Sure thing!
    Each kit includes one of our Heavy Duty Single Output Light Bar Harnesses. On the Stealth Light Bar Kit listing, you can check out all the specs by clicking the "specifications" tab just below the images.
    If there is any additional information you'd like, don't hesitate to shoot us an email at Contact@DiodeDynamics.com, and our service team will be happy to help!
    Jake H.
    Diode Dynamics
  13. Jul 26, 2019 at 9:50 AM
    Diode Dynamics
    St. Louis, Missouri
  14. Aug 7, 2019 at 12:42 PM
    Diode Dynamics
    St. Louis, Missouri
  15. Aug 29, 2019 at 7:57 AM
    Diode Dynamics
    St. Louis, Missouri
    Don't forget to shoot us a P.M for free USPS shipping on any U.S order!
    Jake H.
    Diode Dynamics
  16. Oct 29, 2019 at 2:51 PM
    Thedecathlete
    Thedecathlete Just Another Member
    San Diego
    2019 Cement TRD Sport 2WD
    Premium Package, Predator Tube Steps, Rough Country tri-fold bed cover, blackout badges
    Reviving this thread to get some feedback from people who have purchased and installed the Stealth LED light bar kit. Possibly looking to add this one to the Christmas wish list; any input would be appreciated.
  17. Nov 1, 2019 at 8:27 AM
    Diode Dynamics
    St. Louis, Missouri
    Don't forget to shoot us a PM for FREE USPS shipping on any U.S order!
    Jake H.
    Diode Dynamics
  18. Nov 26, 2019 at 7:53 AM
    Taco_Banger
    Taco_Banger Well-Known Member
    Henry
    2018 Tacoma MGM SR5 2WD
    Do you have any pictures of a tacoma with one of your light bars in amber? I can’t find any.
  19. Nov 26, 2019 at 10:23 AM
    Diode Dynamics
    St. Louis, Missouri
    Great question!
    After doing some digging, it appears as though we haven't received any installed images of the Stealth Kit with an amber LED bar.
    I'll keep my eyes open, and post as soon as I come across some!
    Jake H.
    Diode Dynamics
  20. Dec 2, 2019 at 9:46 AM
    Diode Dynamics
    St. Louis, Missouri
    LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 12/2/2019, you can use coupon code "BLACKFRIDAY" at checkout for 20% off your entire order of lighting upgrades, including our NEW SS3 LED Pods!!! Don't wait, this sale ends TONIGHT!
    Jake H.
    Diode Dynamics
    Sale ends 11:59 p.m. CST on Monday 12/2/2019. Cannot be combined with other coupon codes.
