new stereo build for 99 extended cab
Discussion in 'Audio & Video' started by Greensystemsgo, Mar 13, 2012.
  1. Mar 13, 2012 at 12:54 PM
    Greensystemsgo
    Greensystemsgo [OP] 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    howdy!
    recently purchased this deck, a kenwood KDC-BT948HD for 120 bucks.
    http://www.crutchfield.com/p_113BT948HD/Kenwood-KDC-BT948HD.html?search=kdcbt948hd&tp=5684
    was looking at these speakers for all around, Polk Audio DXi 650s's
    http://www.crutchfield.com/p_107DXI650S/Polk-Audio-DXi-650s.html?tp=105#details-tab
    and maybe this sub? Polk Audio db840
    http://www.crutchfield.com/p_107DB840/Polk-Audio-db840.html?tp=111
    Right now i know very little about this, the deck as far as i know can power everything, but not quite to its full potential, so i guess im in the market for an amp? is there a more affordable, but = quality for speakers/sub? im looking for good quality and a little bump, but nothing crazy.
    I listen to old and modern punk/rock, old school hiphop, and older country.
  2. Mar 13, 2012 at 4:19 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    The deck can power you speakers just fine but doesn't have a sub amp or crossovers for the sub, the deck doesn't have low pass or high pass x-overs needed to run the sub, so you will need at least a sub amp. The sub, using its stats online, seems good. If you want to save some money you may like the speakers running off the deck because they have such a high sensitivity that they will get loud without an external amplifier and they do sound good this way, that is first hand experience, so you may be able to save $200 by not buying an extra amp. A good amp for that sub would be this. It will over power your sub with the gains all the way up but you will need to take it to a shop anyway to have it tuned and you can ask them to set it below or at the RMS of that sub.
  3. Mar 14, 2012 at 12:20 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    see if I get an amp I thought I mighnt as well do 3 channel for left/right/sub to atleast be able to crank it and get full potential if I wanted. But I don't need anything like 1200w.
  4. Mar 14, 2012 at 12:29 AM
    Warhorseforever
    Will
    Sand Lapper
