New stereo died along with cigarette lighter
Discussion in '1st Gen. Tacomas (1995-2004)' started by dopesoner930, Nov 12, 2013.
  1. Nov 12, 2013 at 2:12 PM
    dopesoner930
    dopesoner930 [OP] Member
    Daniel
    Installed my first head unit on my own in my truck soldered the wired covered in electric tape all was fine for 2 days then last night when i shoved the cigarette lighter in the port the stereo died along with the cigarette lighter port. I would imagine it be a fuse but i am not seeing where this fuse is and also have check most all fuses and am not seeing any blown fuses can someone tell me where the fuse is and also any other ideas?
  2. Nov 12, 2013 at 2:15 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    If it's a 2nd gen, then the fuse for these are behind the cubby door on your dash to your lower left. That little door can be pulled out, and the fuses are behind it.
  3. Nov 12, 2013 at 2:16 PM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
    did you pull the radio again and test for voltage at the connection? either with a test light or voltmeter.
  4. Nov 12, 2013 at 2:17 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Check fuses before you start pulling stereos. I think the lighter and the radio are on separate fuses, so separate issues here.
  5. Nov 12, 2013 at 2:20 PM
    dopesoner930
    Daniel
    I apologize I didnt specify its a 1st gen tacoma prerunner 2001 to be exact. I havnt pulled it since this happened last night because the cig lighter went out I didnt think it would have been an issue with the radio
  6. Nov 12, 2013 at 2:22 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    check fuses FIRST
  7. Nov 12, 2013 at 2:31 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Ahh, then it might be the same fuse but I'll let a 1st gen owner answer for that. I know the two used to be tied together on the same fuse in my old Nissan. I don't know where the fuse panel is on 1st gens.
  8. Nov 12, 2013 at 2:34 PM
    BamaToy1997
    Bill
    Navarre, FL
    15 amp fuse labeled "ACC" is for the radio and the cig lighter. Check it out.
  9. Nov 12, 2013 at 2:35 PM
    jspansel
    jspansel Just duct tape it
    Jay
    Central OR
    01 V6 Xtra Cab Tacoma, 5 Speed, 4x4, Lifted
    5100s front at 2.5" with Moog replacement springs, 5100s in rear with 2" Wheeler's AAL
    Don't apologize... You are in the 1st gen forum for what its worth.. :D
    Check them fuses.
  10. Nov 12, 2013 at 2:44 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Oh yeah, LOL
  11. Nov 12, 2013 at 2:58 PM
    jspansel
    Jay
    Central OR
    :D
  12. Nov 13, 2013 at 1:24 PM
    dopesoner930
    Daniel
    This did the trick 1st off there was a 20a fuse where the 15 should have been and it was indeed blown popped in new one and power is back. Hoping thats all it was and that it was a coincidence i just installed the stereo and nothing else. Thank you everyone for your help. Have been following the forums here for a while now and finally decided to join since i got a taco of my own. Will be attempting quite a few mods thanks to everyones right ups! Looks forward to more chat in the forums! :)
  13. Nov 13, 2013 at 1:28 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    For some reason this happens to me too. I have a phone charger plugged into my cig lighter and if I push it all the way in with the truck on it blows that fuse every time.
  14. Nov 13, 2013 at 1:37 PM
    dopesoner930
    Daniel
    That blows I havnt tried it yet since replacing the fuse, theres gotta be a way to keep it from happening
  15. Nov 13, 2013 at 1:38 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Try a different phone charger then. I had a small air pump that shorted out and blew my cig fuse, but it was just the device and not the circuit. Might be something wrong with your phone charger's circuitry or something weird. Or, just try your cigarette lighter and see if the fuse blows.
  16. Nov 13, 2013 at 1:49 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah the phone charger does it to my fiance's nissan too. It's not an issue though because I just keep the phone charger plugged in all the time, and if i ever need to move it I do so when the truck is off.
  17. Nov 13, 2013 at 2:36 PM
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    Hello! Now go OVER HERE and start your build thread to track everything you've done to your Yoda! All the ups and downs help others learn, plus it's cool seeing the evolution of someone's baby.
    I know I've sure learned a lot in the last year!
  18. May 12, 2018 at 2:37 PM
    hubcapsc
    hubcapsc Un-Known Stranger
    Upstate South Carolina
    2002 6cyl 4x4 manual
    thread resurrection...
    We got a 2002 tacoma the other day... when I got it home my wife noticed
    that the radio and the clock didn't work anymore. This thread clued me into
    looking at the acc fuse, it was blown. I had plugged my phone into the
    cigarette lighter instead of one of the other plugs since my short USB cable
    reached there easily. I guess you're not supposed to do that :) ...
    -Mike
  19. May 12, 2018 at 3:15 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    Guys Google how to make a power relay!, super easy, and you could put power to the lighter up to 30 ampere. Good way to stop this prob requires some 12+awg wire and 30 amp relay, problems forever gone. o_O
