New strange vibration. please help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sheepdog, May 26, 2014.
  1. Jun 5, 2014 at 6:57 PM
    #41
    Sheepdog
    Sheepdog [OP] Well-Known Member
    Gary
    San Diego, CA
    Black 2002 Tacoma Xtra Cab, 4x4, TRD, SR5
    Eibach/Bilsteins, Beefed shackles, Bushwacker Cut-Outs, Custom roll bar, TG Sliders, Elite Front Bumper, XRC8 Winch
    So I think I have narrowed it down to the carrier bearing and possibly the pinion bearing. Has anyone had an issue with their pinion bearing? And how did you replace it? I'm thinking about just taking it to a shop.
  2. Jun 5, 2014 at 9:07 PM
    #42
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    James at the truck shop will usually diagnose for cheap/ free.
  3. Jun 6, 2014 at 7:20 AM
    #43
    Sheepdog
    Gary
    San Diego, CA
    You mean this place?
    http://www.sdtruckshop.com/
  4. Jun 6, 2014 at 7:25 AM
    #44
    nfs257
    DFW
    She gone
  5. Jun 6, 2014 at 4:11 PM
    #45
    Sheepdog
    Gary
    San Diego, CA
    Awesome! I'm going in tomorrow to get it checked out. Thanks for the help, bud!
  6. Jun 6, 2014 at 6:55 PM
    #46
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    You can usually tell when its an uneven balance because at certain speeds you will notice quite a bit of vibration through the steering wheel.
    If you have rotated the tires and still notice that it still does it, you can get a floor jack lift up one tire in the front and push/pull back and forth on the tire to check for slop and then determine if it's the steering, ball joints, or even wheel bearings.
    Lets just hope the wheels aren't bent or you're not dealing with morons balancing the tires.
  7. Jun 6, 2014 at 8:00 PM
    #47
    Sheepdog
    Gary
    San Diego, CA
    Well I just got back from the shop and they found a bad u-joint. So they're going to fix it tomorrow.
  8. Jun 7, 2014 at 10:36 PM
    #48
    Sheepdog
    Gary
    San Diego, CA
    Issue has been resolved! The truck shop determined that it was a bad U-Joint. They replaced the bad joint, greased all the others, and did a fluid flush on the tranny. Parts and labor cost me $341. The vibration is gone and the truck shifts SOOOO much smoother now. Thanks for all the help from everyone who chimed in on here!
