New struts causing truck to sit lower.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jarl Mikael, Oct 9, 2020.
  1. Oct 9, 2020 at 2:57 PM
    Jarl Mikael
    Jarl Mikael [OP] Active Member
    Omaha, NE
    2004 Toyota Tacoma Xtracab 4X4 SR5 TRD
    2004 Tacoma 4X4 TRD
    No mods.
    The stock 2004 struts finally made their way out on my truck. It’s a pretty beat up high mileage Tacoma so I decided to just throw some Autozone Duralast strut assemblies in to replace the old ones. It seems as though the truck sits significantly lower in the front even though when I compared them the replacements were longer than the old ones. I know I need to replace the ball joints, stabilizers, etc. still. But I’m just curious as to how this could be. Any thoughts?
  2. Oct 9, 2020 at 3:01 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Wrong coils.
  3. Oct 9, 2020 at 3:02 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I just went thru this. The parts stores do not have the correct part number .
    We need to use Four Runner assemblies.
  4. Oct 9, 2020 at 3:43 PM
    Jarl Mikael
    Omaha, NE
    Snap. Is this because of it being a TRD? You’d think they would have that as an option.. Due to time restraints if I get the same from Autozone but for a 2004 Four Runner 4WD That should do her? I assume engine size doesn’t matter.
    Also, does this say the same for rear shocks?
  5. Oct 9, 2020 at 3:52 PM
    Jarl Mikael
    Omaha, NE
    Also, from what I thought was the rattling of my failing sway bar stabilizers is probably due to not having the right struts. Correct?
  6. Oct 9, 2020 at 4:02 PM
    koditten
    Kirk
    Central Michigan
    I think you need to use a 1999 four runner. The Runners changed styles before the Tacoma's.
  7. Oct 9, 2020 at 9:02 PM
    Jarl Mikael
    Omaha, NE
    I’ve looked around everywhere to try and find information on this. I got nothing.
  8. Oct 9, 2020 at 10:28 PM
    koditten
    Kirk
    Central Michigan
  9. Oct 10, 2020 at 4:52 AM
    Jarl Mikael
    Omaha, NE
