New struts or new coils ?
Discussion in 'Performance and Tuning' started by Santa Cruzin, Apr 1, 2018.
  1. Apr 1, 2018 at 3:45 AM
    Santa Cruzin
    Santa Cruzin [OP] Well-Known Member
    NorCal
    05 Tacoma Prerunner SR5 4.0 DCSB
    im thinking about getting some new struts or coils for my lifted Tacoma 2005
    Would you guys recommend I get struts or coils. I don’t have the funds to get both right now. I can get four new 5100 struts or I could get the two front 6112 coils ? What would you guys get? Thanks
  2. Apr 1, 2018 at 3:51 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I guess I need to know why you need new parts. Are they bad?
    Usually the shocks go bad before the springs go bad. Change the shocks and you will have a good riding truck.
    I don't think you have struts, even though they look like it.
    Sig45 and Santa Cruzin[OP] like this.
  3. Apr 1, 2018 at 3:55 AM
    Santa Cruzin
    NorCal
    The trucks got about 110k miles and has a newly installed lift kit. I don’t think the shocks or springs were changed it looks like they are the original ones so I was thinking it might ride smoother if I get new ones . It rides very stiff and bumpy which I know is normal since they need to be stiff for off-roading but thinking new ones might help in some way
  4. Apr 1, 2018 at 3:57 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Do you know what kind of lift was installed?
  5. Apr 1, 2018 at 3:59 AM
    Santa Cruzin
    NorCal
    The previous owner told me it’s a rough country lift but I’m not really sure if that’s true
  6. Apr 1, 2018 at 4:00 AM
    Sig45
    Mark
    Maine
    Pics of current lift?
  7. Apr 1, 2018 at 4:02 AM
    Sig45
    Mark
    Maine
  8. Apr 1, 2018 at 4:09 AM
    Santa Cruzin
    NorCal
    My profile pic is my truck , I’ll get some more pics when the sun comes up
  9. Apr 1, 2018 at 4:12 AM
    Santa Cruzin
    NorCal
    ConcreteTRD likes this.
  10. Apr 1, 2018 at 4:13 AM
    Sig45
    Mark
    Maine
    No, but you'll learn a lot. Up to you.
  11. Apr 1, 2018 at 4:16 AM
    Santa Cruzin
    NorCal
    I’ll check it out thanks
  12. Apr 1, 2018 at 4:24 AM
    Clearwater Bill
    Billy
    Largo Florida
    Actually it does.
    You don't know what you have now; how the lift has been accomplished, or what parts were changed/used
    You think it has to be stiff for off road use. Hint: Stock Off Road models have a more compliant ride stock than Sport models.
    You don't know the difference between functions of a spring or a shock. If you did, you'd not be asking your particular question, once you figured out what was on the truck now.
    None of this is bad. We all have to learn. But when you ask the wrong questions you'll never get the right answer.
    So, as @Sig45 suggests, do some reading and learn. There is a high chance you will wind up figuring it out for yourself.
    Now, here's my bet.
    To do it right, you'll wind up removing the Rough Country stuff and installing a higher class of parts to solve your issue and make your truck well behaved. Yes, you don't have enough money to do it now. So what? Keep saving until you do, do it once, do it right. :hattip:
    JW87, BuddyS and Sig45 like this.
  13. Apr 1, 2018 at 4:34 AM
    Santa Cruzin
    NorCal
    Not trying to be rude but did you read the question I wrote? Just don’t want to read a hundred pages of people jabbering that’s all
    And yes I’m guessing if you’re going to be off roading you’d probably want a stiffer suspension right? Hint: if it’s loose you’ll probably be bottoming out the whole time...
  14. Apr 1, 2018 at 4:37 AM
    Clearwater Bill
    Billy
    Largo Florida
    Ok. Do it your way.
    Enjoy!
    koditten and Sig45 like this.
  15. Apr 1, 2018 at 4:45 AM
    Santa Cruzin
    NorCal
    I was just confused cause the thread he put is titled “Tacoma lift FAQ”??? I didn’t ask about the lift... I asked if I should get shocks or coils.
  16. Apr 9, 2018 at 1:24 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Ill keep it simple
    Junk country is a spacer lift and most likely blocks in the rear.
    Refer to that other link as to why spacers suck.
    U want to lift with coils... not spacers.
    So, buy new lift coils and struts like 5100s to handle the increased spring rate.
    Or buy 5100s alone and set them to ur desired lift height and suffer rough ride if u set em at 2.5"
    Or get an assembled adjustable coilover kit.
    Dont cheap out... thats what the prior owner did.
    Keep saving your money and do it better.
  17. Apr 9, 2018 at 1:32 PM
    inwood customs
    Dave
    Incorrect.... i suppose the prior owner told u that as a selling point somehow?
    Offroad..... cab is pretty steady.
    Suspension is supposed to dance, not the truck.
    They could run any suspension they want for the money.... i dont see the truck bouncing around.
    Or Bj has it all wrong
    https://youtu.be/QCOI0Mhdrts
    Brice and FinnJ like this.
