New Style TRD CAI
Discussion in 'Performance and Tuning' started by thib454ss, Aug 21, 2010.
  1. Aug 21, 2010 at 7:31 PM
    thib454ss
    thib454ss [OP] New Member
    Thib
    Da Bayou State
    09 TRD Sport 4x4 LB
    Bazooka bass tube, Keyed bull bar
    Just ordered one. I'm kinda worried now after reading some negative feedback. Has anyone installed this without having any problems follow? I'll keep my fingers crossed.
    Thanks.
  2. Aug 21, 2010 at 7:33 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    are the problems your talking about the making lean of the engine? If so you will actually see a power gain in a naturally aspirated truck. The forced injection ones are the only ones that have anything to worry about or so Ive heard.
  3. Aug 21, 2010 at 7:34 PM
    Duff Man
    Duff Man Well-Known Member
    Sean
    North Carolina
    09 TRD Off Road
    AEM CAI, Magnaflow exhaust, DT headers, all speakers replaced with (2) 10's and amp behind rear seats, color matched grill, grillcraft, projector headlights, 8000k HID's, DC Torque wheels, 3" Toytec lift, Bilstein 5100 shocks.
    I looked into one of those, the dealership wanted to charge me $475.00 for it though...F*#! that.
    I've never heard of anyone having any problems from the intake though
  4. Aug 21, 2010 at 7:37 PM
    thib454ss
    Thib
    Da Bayou State
    09 TRD Sport 4x4 LB
    I've read that it fux up the MAF's computing and gives a CEL.
  5. Aug 21, 2010 at 7:46 PM
    Duff Man
    Sean
    North Carolina
    09 TRD Off Road
    I've only met one person who ran into problems with his MAF sensor after running an intake and that was because he never cleaned it. But I'm not exactly and expert on the matter.
  6. Aug 28, 2010 at 12:09 PM
    lasllc
    lasllc Well-Known Member
    SW Denver Burb
    13 SuperWhite DCSB Sport 4X4 Tow Pack
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    I have run one now for quite a while and have gone through a period of P0101 codes. Took a bit to figure out the problem. Please note that all the following is purely empirical evidence.
    Once the intake was seen as the originator of the code then (with Scangage) it was easy to isolate the particular event causing the code. This is an '09 TRD, 40k.
    These trucks computer will, to a point, "learn" from your driving habits and sort of fine tune themselves. The operative term here is "to a point"; the cai allows a much greater volume flow rate of air thru the intake, it is not linear, the higher the RPM the greater the increase in VFR beyond the previous sample. My experience is that accelerating wide open to 3500 or beyond for a period of time or several times in succession, pushes the MAF beyond its capability and confuses the computer, generating a P0101 code; after resetting it and driving a bit more conservativly, no problem.
    The P0101 code is a problem in itself as it disables the stab. control system until reset. Also, note that higher RPM ranges do not, of themselves, seem to be the problem, but it is more a case of how often and how rapidly you get there. So, I have not seen my self limited in goosing it as much as i need to jump onto the interstate.
    All this being said, I like the intake as it sounds nice, actually has improved my MPG a bit in hiway cruise (certainly not in town stop and go, nothing works there) and the higher rpm pick up is noticeably improved.
  7. Aug 28, 2010 at 12:15 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    Dont have a problem with mine... lots of bullshit rumors in my opinion.
    FinnJ likes this.
  8. Aug 28, 2010 at 12:21 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    OP keep us posted...I was eventually looking at getting one of these as well.
  9. Aug 28, 2010 at 12:34 PM
    6spdtaco
    6spdtaco Well-Known Member
    Nate
    East Wallingford, VT
    Taco
    Tom Woods driveshaft. TRD short throw shift kit. TRD exhaust. AFE Stage II intake. CBI Bumpers front and rear. Warn 8000i winch/ synthetic line. OME 3" lift w/ dakar springs and 886 coils. ATO Front skid. ARE MX cap. Trail Team FJ wheels. Cooper Discoverer ST 265/75-16 C tires. Diff breather relocation mod.
    I've got one. It seems fine except for the fact that it doesn't stay closed! The way that it clips shut is something that can be improved. Two clips and two "tabs" as I call them. The tabs are closest to the passenger side. I've taken it to the dealer and pop the hood and show them that it isn't shut, they snap it back down and tell me to see if it happens again and THEN bring it in for warranty. I believe that the side to side movement of the engine upon start up or on hard shifts or rough terrain the top of the intake shakes itself loose.
    Maybe I just have a defective one, I have been told by the dealer's parts manager that he has installed lots of these intakes with no issues. Maybe its just mine or maybe no one looks under their hood until the mechanic goes to do some regular maintenance and just closes it again.
    Sorry for the rambling, I am just worried that by not being completely shut, my MAF might get screwed up. I have had to deal with MAF issues on other vehicles before and they are a pain in the butt.
    As far as performance, I cannot tell the different in power, and can't tell of much noise difference. Down shifting to pass or go up a hill gets louder, but not by much.
  10. Aug 28, 2010 at 12:48 PM
    AriZonaD54
    Andrew
    Valley of the Sun
    Mine closes nice and tight. Call up your Toyota stealership and complain.
  11. Aug 28, 2010 at 1:14 PM
    thib454ss
    Thib
    Da Bayou State
    09 TRD Sport 4x4 LB
    I ended up canceling the order and doing the SAF removal + drop in AFE mod. It's a hell of a lot cheaper and I figure it'll do me just as good. Thanks for the help anyway. :cheers:
  12. Aug 28, 2010 at 1:21 PM
    justin14200
    justin14200 frequent reader
    justin
    baton rouge
    2010 prerunner sr5 bsp
    stock
    whoa, it looks just like a fatory 2.5l i4 ford ranger intake box....looks to be useless... just like in my old ranger
  13. Jun 27, 2011 at 7:10 PM
    csg8449
    csg8449 Active Member
    Columbus,GA
    08 4X4 SR5
    TSB leaf spring up TRD Quickshifter TRD shift knob Nfab steps Weathertech floor liners Stubby antenna Sock monkey decals TRD cat-back exhaust Bronze TRD wheels TRD CAI Bilstein 5100's @ all around , front @ 1.75 Toyo AT2 Open Country Tires
    I installed mine about a week ago and have not experienced any problems. I like the sound even if there is only a very small increase in HP. I have read about the problem of the air/fuel mixture tending toward too lean. If this is so, I would like to know who determined that and by what means it was determined rather just going with hear say.
