NEW SUSPENSION HEEEELLLLLLPPPPP!!!!!
Discussion in 'Suspension' started by Fox2011PM, Jan 22, 2012.
  1. Jan 22, 2012 at 5:35 PM
    Fox2011PM
    Fox2011PM [OP] "The Mountains are calling"
    '13 DCSB 4X4 TRD OR
    ADS 2.5" CO's w/adj, ADS 2.5" Rears w/ piggybacks, Firestone air bags and 1.5" AAL, SCS SR8s, Tom Woods custom one piece drive shaft....more to come
    Ok here goes. Cuz my head hurts, too...many...options! I want a perfectly level stance, no more than 2.5" lift, and a great ride on road, with good performance in some MINOR off roading. Wanna run 265/75/16s. This is, and will be my long time daily driver, I don't plan on beating her up, but def stretching her legs! I have been researching SO many different options that I am at a stale mate. It's between the OME full kit, or the Toytec adjustable Billstein kit with Eibachs( I think its listed for $899.99)? OME is right around $750.00. I don't necessarily HAVE to go the cheaper $ route, just want whats best for my applications. Any and all input GREATLY appreciated!
  2. Jan 22, 2012 at 5:45 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Its all up to you man, both of those are great kits, used by many members on this site.
    you can fit 265/75 stock, btw
    The ome supposedly has a better ride, but I can't talk from experience.
    I have the billy/eibachs and love it.
  3. Jan 22, 2012 at 5:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Old Man Emu is hard to beat regardless of price. Given the 2 choices, I would get the OME all day long.
  4. Jan 22, 2012 at 5:52 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    I'm running 265/75/16s and I got ome 885s with 5100 on all 4 corners.
  5. Jan 22, 2012 at 5:55 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    I went through the same deliberation. I ended up with the eibach, 5100 and aal option. I am very pleased with the results. Great ride quality and have no vibe issues. A lot of guys on here with sage advice swear by the OME lift as well so .......
  6. Jan 22, 2012 at 6:08 PM
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Blackshirts, so you can run 5100s w/ OME? See this is why my head hurts, some say you shouldn't do that. Then yoy have trim packing, and "taco lean spacers", i just want the best for my money and apps. Since I want a nice on road ride as my priority I am leaning more towards OME i guess, because I have heard it performs very well on road as well as off. So I guess I will narrow this down then i can go with the responses. I am going with OME, so someone PLEASE tell EVERYTHING I need to make it level at 2.5" and hwhat i need in order to do away with my spacers and blocks. Thank you so so much for input!
  7. Jan 22, 2012 at 6:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    885 springs, 1 trim packer for the driver side, N90000 front shocks, and 2" AAL and N182S rear shocks. Done.
  8. Jan 22, 2012 at 6:15 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Another member here with eibach/5100s and wouldnt go back! Either one and your good man!
  9. Jan 22, 2012 at 6:15 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    What chris said.
    Or you can skip all the headache and get the full ome 3"though kit from wheelers.
  10. Jan 22, 2012 at 6:17 PM
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Awesomec Chris4x4 thank you! I do have the TSB leaf ordered, do you suggest I just skip that and go straight to 2" AAL? Or what do I need if I get the TSB leaf done? See this is overwhelming!
  11. Jan 22, 2012 at 6:21 PM
    Hairy Taco
    North of Hell
    08 TRD
    tHE aal for a non-tsb leaf pack gives 2" lift , the aal with the tsb pack gives 1.5" lift
  12. Jan 22, 2012 at 6:22 PM
    Hairy Taco
    North of Hell
    08 TRD
    is the tsb stil an issue with 2011's?
  13. Jan 22, 2012 at 6:29 PM
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    I just assumed it was an issue with 2011, because the 2011s were included in the TSB. I contacted my local dealer and they told me to bring it in that they have already ordered it for me. Man I am so lost in all this! Don't know what the f to go with!
  14. Jan 22, 2012 at 6:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Take some deep breathes. All will be OK. I posted the parts you need. If you get the TSB springs, get the 1.5" AAL. If not, then get the 2". No biggie ;)
  15. Jan 22, 2012 at 6:34 PM
    Blackshirts
    TX
    Stuff
    You can run 5100 with 885s but highly not recommended with the 886s.
    Take measurements front and back to see what you need. If you think 2.5 up front maybe one aal in rear will make your truck sit level.
    OME shocks are better tho and prolly give you a better ride.
  16. Jan 22, 2012 at 6:36 PM
    Hairy Taco
    North of Hell
    08 TRD
    no need to worry. It really isn't that complicated. If you are getting the shop to install your lift, you might bring them the aal along when you get the tsb done so they can install them at the same time. The place you are buying the kit from will tell you which aal you need. Usually it will give you a 1.5" lift on top of your tsb
  17. Jan 22, 2012 at 6:59 PM
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Ok, thanks to all that replied. You guys are awesome! I will post my decision soon with pics! I guess what this is what TW is all about! Looking forward to becoming a lifetime member
  18. Jan 22, 2012 at 7:02 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    There's no hurry......take your time and listen to Chris 4x4, lol! He's knows his shit and had that same lift!
  19. Jan 22, 2012 at 7:12 PM
    rpking
    rpking Well-Known Member
    Roger
    Ohio
    Tacoma 4x4 TRD off road
    painted engine cover, bed cover, color match door handles, window tint, seat covers, weather gaurd floor mats, TRD stainless steel cat back exhaust, front skid pan, bug deflector, custom holster mount in center console, OME 884X springs and shocks, 2" AAL, OME shocks
    I'm mulling over this same stuff trying to decide what to do... I have a 2011 V6 access cab, if I go the OME route would I still want the 885 springs? I want about the same as Fox2011PM 2.5 inches of lift up front, I wouldn't mind keeping the stock rake, I like the rear a little higher than the front, would a 2" AAL do that?
  20. Jan 22, 2012 at 7:14 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    if you lift the front and back around the same, you'll keep the rake.
    885s are for stock bumpers, 886's are for plate bumpers/winches IIRC
