New suspension!!! (If they'll fit)
Discussion in '5 Lug' started by Minnis12, Jan 21, 2013.
  1. Jan 21, 2013 at 9:34 AM
    Minnis12
    Minnis12 [OP] Well-Known Member
    Blanchard, La
    '09 Tacoma BASE 2.7L i4
    de-flapped, Pro-Flow Super V muffler, Pilot offroad lights with 7 color changing LED's, fog lights
    So I'm gonna buy a set of the OEM TRD Bilstein shocks off a local guy. I was curious if they will fit. I called Toyota and the guy said they should but I just wanted to see if anyone on here has first hand experience with them and howich difference they will make in ride and lift. I have a 2009 4cyl base model and I'm hoping for a smoother ride and better performance off the pavement.
  2. Jan 21, 2013 at 9:37 AM
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '24 F-150
    If those came off of a six lug they will not fit.
  3. Jan 21, 2013 at 9:38 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I see you posted this in the 5-lug section. Do you have a 5-lug 2WD truck? If so, the 6-lug shocks pictured will not fit.
  4. Jan 21, 2013 at 9:40 AM
    Minnis12
    Blanchard, La
    Ya I got a 5 lugger and what is the difference in the 5 and 6 lug as far as the suspension tubes?
  5. Jan 21, 2013 at 9:45 AM
    Oowen
    Owen
    Reno, NV
    '24 F-150
    Geometry of the suspension system.
  6. Jan 21, 2013 at 10:12 AM
    Minnis12
    Blanchard, La
    Is it how they fit or would it throw off balance? So there's no possible way to properly install 6 lug suspension?
  7. Jan 21, 2013 at 10:20 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
  8. Jan 21, 2013 at 2:33 PM
    fender104
    fender104 Active Member
    stanley
    Camp Lejeune
    11 Regular Cab 2wd
    Tint, Boston Speaker, Fog Lights, Tool Box,Debadged, Black Box mod, XRunner Rims, nitto terra grapplers 285/60/18/, Intermittent wipers,Scan Guage, front HD bilsteins, rear trd offroad bilsteins, Fat bobs lift
    The rear shocks will fit if you add a leaf. The fronts will not fit no matter what you do.
  9. Jan 21, 2013 at 2:47 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    It will if he cuts off the shock tower and welds another 6" on! lol.
    In all seriousness though, there are a lot of people selling their "mid travel" setups because they're jumping to long travel. I'm sure you can find a good deal out there if you're looking for a little bit of lift.
  10. Jan 22, 2013 at 7:03 AM
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    Remember you will need at least a 3" bump stop with the 6lug shock.
    can anyone comment on the differences and pro/cons of each design?
    six lug obviously has a taller spindle right? perhaps a bigger shock travel/suspension travel ratio.
    When both in mid-travel form, 5lug and 6lugs have the same travel figures.
  11. Jan 22, 2013 at 6:04 PM
    KenLyns
    Belly of the Beast
    Travel figures may be similar, but static ride height are different. If a mid-travel 5-lugger is as tall as a stock 6-lugger, then a mid-travel 6-lugger sits another 3" higher.
    The 6-lug truck is simply designed to sit taller - this to fit the 4x4 transfer case and front diff under the truck. The shock bucket, control arm mounts and spindles are designed to accommodate the greater height distance between the frame and the wheel hub. The 6-lug lower control arm is positioned lower relative to the hub to make room for the CV joint.
    So I guess you can say the 5-lug suspension geometry is suitable for 2WD while the 6-lug suspension geometry is suitable for 4WD truck design. :)
  12. Jan 23, 2013 at 8:29 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    far smaller spindle plus different design equals much less unsprung weight equals why 5 lug trucks are better than 6 =)
  13. Jan 23, 2013 at 6:32 PM
    KenLyns
    Belly of the Beast
    The 6-lug spindle doesn't weight much compared to the brake disc and caliper. And the 6-lug brake with 4-piston calipers is significantly more powerful.
