New suspension/lift help..
Discussion in 'Suspension' started by Tacoma 2000, Oct 26, 2014.
  1. Oct 26, 2014 at 1:01 PM
    Tacoma 2000
    Tacoma 2000 [OP] Member
    2000 Prerunner SR5
    I have a 2000 tacoma prerunner. I have stock suspension on the truck now. I know the shocks are done. Question is, if I put the bilsteins on the stock coils, will I still recieve the full 2.5" of lift even though the coils are worn out?
    Planning to do a 1" or 1.5" aal in rear+ the rear 5100s.
  2. Oct 26, 2014 at 4:24 PM
    Tacoma 2000
    2000 Prerunner SR5
    c'mon anything??
  3. Oct 27, 2014 at 12:57 PM
    Tacoma 2000
    2000 Prerunner SR5
    Anyone!!
  4. Oct 27, 2014 at 1:11 PM
    colbyrainey
    colbyrainey Well-Known Member
    Colby
    KC
    '11 Dbl TRD Sport
    TSB Leafs, Bilstein 5100's @ 1.75", K&N Filter, Kenwood DNX 6180, BFG Rugged Terrain T/A's, ImMrYo Rearview Mirror Bracket, Extra D-Rings, Gloss Black Stock Wheels, Grillcraft Grille
    You'll probably get some lift, but not all. Bilstein 5100's set at anything other than 0" of lift put pre-load on the coil so if the coil is worn it will probably make the front-end sag.
  5. Oct 27, 2014 at 1:19 PM
    Tacoma 2000
    2000 Prerunner SR5
    Thanks. I might get replacement OEM coils to offset this problem.
  6. Oct 27, 2014 at 1:53 PM
    colbyrainey
    Colby
    KC
    '11 Dbl TRD Sport
    Might as well get some aftermarket ones. OME or Eibach are popular around here...
  7. Oct 27, 2014 at 4:18 PM
    Tacoma 2000
    2000 Prerunner SR5
    I will look into those. Thanks
