New suspension: noises every time I brake?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoman100, Sep 13, 2019.
  1. Sep 13, 2019 at 9:37 AM
    Tacoman100
    Tacoman100 [OP] Active Member
    Just installed new OME nitro setup with with 883 springs, and now every time the car makes abrupt movement, just braking at low speeds, or turning at low speeds, I hear a creaking noise from under neath my left foot. I assume this has something to do with the new setup.
    Could this be the new bushings or the new springs? Is it normal?
  2. Sep 13, 2019 at 11:44 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    No, that's not really normal. New bushings shouldn't creek. What kind of bushings?
    Double check you have proper torque on all your bolts, and that you followed installation procedures. Make sure you installed the springs on the shocks properly, etc...
    Did you get it aligned yet?
