New Suspension...Now Rims/Tires
Discussion in 'Wheels & Tires' started by sac130e, Apr 14, 2011.
  1. Apr 14, 2011 at 12:14 PM
    sac130e
    sac130e [OP] Well-Known Member
    Scott
    Milton, FL.
    11' TRD Off-Road 2wd
    JVC Nav. System and entire Memphis Audio Speakers/Amps
    Installing 5100's all around with fronts set at 1.75 and 1.5" AAL in the rear.
    Looking at either 16x8 or 17x9 rims. Which is best (opinions) and what would be max tire fit for each size rim wihtout having issues with rubs (no trimming).
    Thx
  2. Apr 14, 2011 at 12:17 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    For zero trimming a 265/75/16 and a 265/70/17. The 17x9 might be a little too wide for a 265/70. Try looking for a 17x8. Just my .02.
  3. Apr 14, 2011 at 12:30 PM
    NLF
    NLF Well-Known Member
    Levi
    Minneapolis, MN
    '11 TRD Sport DC LB 4x4
    OME 884 & Bilstein 5100s @ 0, TSB Rear w/5100s, 20x8 Mamba M2 275/55/20 Geolander, Access Cover
    I am running 265/70/17 Revo 2's on 17x9 XD Revolvers and they fit well.
  4. Apr 14, 2011 at 12:31 PM
    sac130e
    Scott
    Milton, FL.
    With the lift I am getting, I should be able to run a 275 on either rim size..from what I have been gathering on this site. Was looking at 17x9 MM 955's with Nitto TG P265/70R17 or BFG A/T KO at 275/70R17.
    But going with the 16x8 is fine as long as I can get the biggest tire on it without rubbing (275)
  5. Apr 14, 2011 at 2:26 PM
    sac130e
    Scott
    Milton, FL.
    Found the Ultra Goliah 17x8 with +10mm offset and 4.88 BS and bolt pattern of 6-139" from TrieRack. Will the Duratrak 265/70R17 C work with these rims or stick with the 265/65R17 instead? ? Also getting the TPMS sensors installed from them for 2066 shipped...good deal or find better elsewhere?
    Thx
  6. Apr 14, 2011 at 5:59 PM
    sac130e
    Scott
    Milton, FL.
  7. Apr 14, 2011 at 6:03 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You'll be fine with the 265/70/17's with those specs
  8. Apr 14, 2011 at 6:08 PM
    sac130e
    Scott
    Milton, FL.
    Thx, so those specs will work fine on a 17x8 rim?
  9. Apr 14, 2011 at 6:09 PM
    KPT
    09 Prerunner
    Yep
  10. Apr 14, 2011 at 6:48 PM
    sac130e
    Scott
    Milton, FL.
    Would I be pushing the rub issue if I went with a 275/65/17 or even a
    275/70/17?
    Thx
  11. Apr 14, 2011 at 7:18 PM
    KPT
    09 Prerunner
    Yeah you would be pushing it. I can't say for sure because those are pretty uncommon tire sizes
  12. Apr 17, 2011 at 5:50 PM
    sac130e
    Scott
    Milton, FL.
    Understood..but the BFG KO comes in a 275/70/17 size and measures 32.2 across. This should fit with little to no trimming. Just hope it will fit on the 17x9 rim without to many issues. Tires specs say 7-8.5 rim size, but heard people run those sizes with little issues
