New suspension questions...
Discussion in 'Suspension' started by TacomaAroma, Nov 3, 2010.
  1. Nov 3, 2010 at 2:00 AM
    TacomaAroma
    TacomaAroma [OP] Member
    Arvada
    Tacoma TRD Offroad (charcoal)
    New 2011 tacoma plans: 1) Bull bar/KC driving lights 2) 3in body lift 3) XD rockstar Rims 18'' 4) black slim crossover toolbox 5) Black running boards
    Damn you all! You got me hooked!
    Now I got that out of the way, I am lifting my new 2011 Taco and have some questions along the way. Might I point out I am a total rookie. The only work I have ever done on a vehicle is a fuel pump replacement, and regular maintenance, oil, plugs etc. So I am doing my research, and compiling the knowledge I need. Along with this I have a few questions.
    I heard it was a good idea to do a 1'' body lift with a 2'' suspension lift for the desired 3'' lift in order to keep suspension and steering geometry closer to stock. Wondering if anyone had any thoughts on this?
    Provided I go with the suspension/body lift combo, I would be using a full set of bilstein 5100 giving me 2'' front 1'' rear followed with a 1'' body lift. Then add a 1'' leveling kit to the rear. Anyone see any issues with this plan? Should I be installing a leaf instead?
    Still haven't figured out if I am going to be installing myself or not. I would like to for the project, and to save a few bucks though.
  2. Nov 3, 2010 at 8:35 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    The only geometry issues you may end up with with a 3" suspension lift is that your caster may be out of whack unless you buy new upper control arms (UCA's). Some do, some don't.
    I'm not a big fan of body lifts, so my suggestion would be for you to just set the billy's at 2.5" up front, and to use an add-a-leaf for the back.
    The "leveling kit" you're talking about for the back is actually called a "block". Blocks are known to promote axle wrap. The leaf is a better route to go.
  3. Nov 3, 2010 at 8:37 AM
    98tacoma27
    Ben
    Not Beech Creek
    ^^ That ^^
  4. Nov 3, 2010 at 11:05 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I am not a fan of body lifts, but a 1" is not too bad. If you are planning on running 5100s, the fronts will provide 2.5" of lift. Then to match that out back, I would suggest getting an AAL of 1.5" lift.
  5. Nov 3, 2010 at 11:40 AM
    TacomaAroma
    Arvada
    AAL? told ya in a rookie =)
  6. Nov 3, 2010 at 11:45 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Add-a-leaf.
  7. Nov 3, 2010 at 11:46 AM
    TexasTacoma37
    It's short for add-a-leaf. It adds another leaf to your rear leaf spring pack, and gives you lift.
  8. Nov 3, 2010 at 11:52 AM
    CUtigerfan
    CUtigerfan Well-Known Member
    South Carolina
    04 Base
    Daystar 1.5" coil spacers, bedlined bumpers, clear corners, aftermarket stereo, 20% tint, half debadged
    Seems like a PITA (pain in the ass) you said your a rookie so i'm not taking chances :p to put a 1" body lift on. You would have to come up with some sort of bracket for both of the bumpers and might need an extension on other parts (fuel filler line into gas tank, steering extension, shifter extension, etc.) You won't find a guy on here who would recommend a body lift.. they've all been converted. :D The bilsteins set to 2.5" seem like your best option unless you have a decent sized budget to buy Upper Control Arms and Coilovers. Most guys will advise against the block too. Cheap ones crack and break. The add-a-leaf will also solve the weight capacity if they didn't fix that for the 2011.
  9. Nov 3, 2010 at 2:04 PM
    TacomaAroma
    Arvada
    Well I'm convinced... Im going with suspension only balistine 1500's 2.5'' front 1'' rear and AAL... And will be installing myself. Will post progressions pics and questions along the way. Thanks!
  10. Nov 3, 2010 at 2:17 PM
    TexasTacoma37
    Do you mean the 2.5 billys up front and 1.5" AAL for the rear?
    Definately get a friend to help you with the install. An impact gun saves a bunch of time too.
  11. Nov 3, 2010 at 6:35 PM
    TacomaAroma
    Arvada
    Aye... 1.5'' AAL
