New Suspension, Wheels, and Tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by michaeln, Mar 5, 2020.
  1. Mar 5, 2020 at 3:39 PM
    michaeln
    michaeln [OP] Old and In The Way
    Michael
    Avery, CA
    2020 Cement DCSB TRD OffRoad
    Monday, I got new OME suspension, Method wheels and Duratrac tires. I'm pretty pleased with it although I have to take it back to have them re-do the alignment because it is pulling to the right.
  2. Mar 5, 2020 at 3:52 PM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    Looks sharp! Like that color.
    michaeln[OP] likes this.
  3. Mar 5, 2020 at 3:58 PM
    michaeln
    Michael
    Avery, CA
    Thanks. I do too. From a distance it looks like plain grey, but when you look at it closely it has a fine pearlescent finish.
  4. Mar 5, 2020 at 4:29 PM
    CrustyComa
    CrustyComa Well-Known Member
    Michigan
    2020 SR SX TRD Sport love child
    I have the same truck and same tires, maybe a different size though. What size did you go with?
  5. Mar 5, 2020 at 5:05 PM
    WhatTheFrag
    WhatTheFrag Member
    16 Taco DCSB TRDOR
    What version of the kit did you get? Coils/ rear leaf etc.
    michaeln[OP] and SeattleTRD17 like this.
  6. Mar 5, 2020 at 5:54 PM
    Rosshoss
    Rosshoss Well-Known Member
    2016 Tacoma TRD OR
    Wheels & tires?
  7. Mar 5, 2020 at 8:34 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Looking good
  8. Mar 5, 2020 at 8:43 PM
    Catfish21
    Catfish21 Well-Known Member
    Stockton, Ca.
    Trd off road 4th Gen
    Nice rig. Welcome to the money pit.
  9. Mar 6, 2020 at 7:29 AM
    michaeln
    Michael
    Avery, CA
    I went with 265/75R16. A little taller than the stock size with more sidewall.
    71tattooguy likes this.
  10. Mar 6, 2020 at 7:31 AM
    michaeln
    Michael
    Avery, CA
    2887 coils, Dakar EL095R leaf pack.
  11. Mar 6, 2020 at 7:40 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    That color is so sick.
  12. Mar 6, 2020 at 7:41 AM
    OuchIDied
    OuchIDied Well-Known Member
    2021 Silver Sky Tacoma Off-Road
    Love it. Cement is the best color imo. I get pretty offended when people call my truck grey or silver.
    I'll be getting Duratracs once there's a good sale.
  13. Mar 6, 2020 at 7:53 AM
    Quacktacular81
    Quacktacular81 Unknown Member
    SW Colorado
    2020 Tacoma TRD Off-Road
    Discount Tire Direct is running their Spring Thank You Event, which is up to 15% rebates, plus can be stacked with Mfg rebates. GY has $50 for Duratracs.
    OuchIDied[QUOTED] likes this.
  14. Mar 6, 2020 at 9:45 AM
    Griswold
    Griswold Lurker
    Taco
    Lookin sharp OP!
  15. Mar 9, 2020 at 7:42 PM
    michaeln
    Michael
    Avery, CA
    Back to the shop today for the 500 mile retorquing and to have the alignment re-done because it had a distinct pull to the right since the lift and alignment. That was all taken care of today, the truck tracks straight now.
    The other reason I took it in today was squeaks over bumps. I found the noise difficult to localize, but I figured it was the leaves in the Dakar leaf pack squeaking. But when the mechanic drove the truck with much better ears than mine he said it was coming from the FRONT, and specifically the 2887 coils are rubbing on the sway bar causing the squeak. If you turn the wheels full lock right you can see where the coil is hitting the sway bar.
    This shop does a lot of taco suspension work, and they had not seen this before. My 2018 SR5 had the exact same suspension parts installed and it didn't do this squeak. Figure there must be something different about the 2020 sway bar, maybe larger diameter or mounted differently. Or the TRD OR has a different sway bar than the SR5.
    Anyway the mech googled for this issue and found a post here about there being a "sway bar relocation kit" designed to fix this problem.
    Have any of you folks run into this?
  16. Mar 9, 2020 at 7:48 PM
    michaeln
    Michael
    Avery, CA
    This video shows the relocation brackets and how they work to provide the needed clearance.
    El Chivo Norteño likes this.
  17. Mar 9, 2020 at 8:04 PM
    calebc
    calebc Well-Known Member
    It's weird that they do a lot of Toyota lifts and haven't run in to that because having to use the relocation brackets is really common, it's the same on 4Runners. In fact many kits usually come with those brackets, my King shocks have it built in to the remote reservoir mount and my BP51 kit just included the brackets.
    michaeln[QUOTED][OP] likes this.
  18. Mar 9, 2020 at 8:22 PM
    1cleanFG
    1cleanFG DialsGarage
    DialsGarage
    PNW
    2023 Sport 4x4 DCLB
    Toytec Alumaseries Coilovers OME El111R Camburg UCAs Scs sr8 17” 285/70/17 KO2
    Yep. Had the same setup on my 2nd gen and had exact same rub. Put on sway bar relocation kit, boom, fixed.
  19. Mar 10, 2020 at 5:49 AM
    michaeln
    Michael
    Avery, CA
    I think I may have misunderstood what they said.
    calebc[QUOTED] likes this.
  20. Mar 10, 2020 at 6:25 AM
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Those Goodyears are fairly light for that style of tire. Hows the ride?
