new suspention
Discussion in 'Suspension' started by JAMM, Mar 23, 2011.
  1. Mar 23, 2011 at 3:13 PM
    JAMM
    JAMM [OP] Member
    jim
    rosendale ny
    2010 tacoma
    5100 bisteins front & rear ome885 front coils rear aal wheelers
    Ijust orderse 5100 bilsteins front and rear ome 885 coils and wheelers add a leaf for load capacity in the rear . what do you think?
  2. Mar 23, 2011 at 3:15 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    I think you could have done better.:p:D
  3. Mar 23, 2011 at 3:27 PM
    JAMM
    JAMM [OP] Member
    jim
    rosendale ny
    2010 tacoma
    bummer i wanted to add load capacity to the rear , what do you sugest
  4. Mar 24, 2011 at 6:49 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    If you want more payload capacity I suggest you get a full sized truck.
    Payload capacity isn't solely dependent on the springs, it also depends on what the shocks were designed to dampen, the strength of the bed, the type of tires you have (P vs. LT) etc.
  5. Mar 24, 2011 at 8:17 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    885s raise the front a lot. Be sure to set the 5100s at zero when you install them.
    When you say "load capacity" I assume you're not overloading your truck past its maximum GVWR, but rather you want it to drive and ride better when it's loaded to that capacity.
    AAL usually gives the truck more stability when loaded to capacity, but with 885s in the front, you'll definitely be "ass-down" when fully loaded in the back with only an add-a-leaf.
    Dakar leaf packs are designed to work well with OME springs in the front.
    Another alternative is adding air bags you inflate when carrying a load.
  6. Mar 24, 2011 at 5:30 PM
    JAMM
    JAMM [OP] Member
    jim
    rosendale ny
    2010 tacoma
    bjmoose yeh i load it heavy , the dakar leaf packs are the way to go ? with the helper spring?
  7. Mar 25, 2011 at 3:42 PM
    JAMM
    JAMM [OP] Member
    jim
    rosendale ny
    2010 tacoma
    BJ MOOSE yes i will be loading the truck maxed out , how much lift do you think i"ll grt with the 885"s i added or will be adding a 2" aal in the rear
  8. Mar 25, 2011 at 3:48 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Most get 3" with 885s and no bumper.
  9. Mar 25, 2011 at 3:49 PM
    JAMM
    JAMM [OP] Member
    jim
    rosendale ny
    2010 tacoma
    chris 4x4 i saw your aal installation , what do you think of 885"s with a 2" aal in the rear ,5100"s all around ? i"m on the road 90% but load the truck with firewood alot of the time.
  10. Mar 25, 2011 at 3:50 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah. Go Dakar instead of aal for heavy loading. Or all pro expedition leaf pack.
  11. Mar 25, 2011 at 3:50 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    X2
  12. Mar 25, 2011 at 3:52 PM
    JAMM
    JAMM [OP] Member
    jim
    rosendale ny
    2010 tacoma
    BJmoose well i hope i didnt foul up on the 2" aal i ordered it thourgh wheelers and they said it would match up
