new t stat not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by truckerman49, Jul 28, 2012.
  1. Jul 28, 2012 at 3:19 PM
    truckerman49
    truckerman49 [OP] New Member
    Frank
    salkum wa.
    96 tacoma 4x4
    hay guys i just put a motor 2.7 3rz in my 96 taco and i am having problems with the t stat not opening i have went threw two t stats so not sure what to do top hose is hot bottum is cold and heater hoses are hot any ideas?
  2. Jul 28, 2012 at 8:04 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) From your description of your problem, you have a clogged radiator, with no water traveling through it. Your water makes a loop from the top of the radiator to the bottom, exchanging heat with the air through the air fins of the radiator. The hot water is at the top and it is cooled by traveling through the radiator to the bottom where the water pump, pushes through the engine back to the thermostat and the upper radiator hose.
    If your hose on top is hot and your hose on bottom is cold, you are not getting any coolant/water through your radiator. Your bottom hose should be warm, but not as warm as the top hose if all was working right. You need a new radiator. Good Luck.
