New Taco Access cab 5 speed shifting question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kwelhand, May 18, 2011.
  1. May 18, 2011 at 10:43 PM
    kwelhand
    kwelhand [OP] Well-Known Member
    I've been diving 5 speed for years and trying to get used to my new Taco Access Cab w/ 2.7L + 5 speed.
    It seems like Taco vibrates when I'm trying to shift at lower RPM especially 1st & 2nd gear.
    With today's gas price, I'm really trying to stay under 2k RPM as much as possible... unfortunately, sometime it cause my Taco to vibrates pretty bad.
    Is this type of vibration bad for my engine, flywheel, clutch, etc?
    Any thoughts?
  2. May 18, 2011 at 10:46 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    Yes, it is bad . You have to keep the rpm's higher in 1st and 2nd gear. I shift all gears at around 2500 rpm
  3. May 18, 2011 at 10:53 PM
    kwelhand
    It seems like I've to stay at min 2K~2.5K to avoid vibration.
    How bad is it to the engine & tranny?
    Also, I put the gear into neutral position just before the engine die while stopping.
    Someone told me that it will save the brake since I'm using the engine braking.
    Is this also bad practice?
  4. May 18, 2011 at 10:57 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    I personally wouldn't shift under 3k rpm. I have an auto these days so no worries for me, but when I did have the stick I found somewhere in the 3k - 4k range to be normal, fluctuating within that range with the driving conditions (hills, acceleration, etc).
    I am pretty sure you can't really harm the engine by shifting it too low.. but it certainly thrashes about if you do.. geez. You don't save that much gas.
  5. May 18, 2011 at 10:57 PM
    TacomaBuzz
    CT
    I edited that post, I usually shift at 2500 rpm's, i usually downshift if I have time and use the engine to brake. I idle in gear rather than neutral.
  6. May 18, 2011 at 11:05 PM
    kwelhand
    Could you clarify a little bit more?
    So it seems like I've to rev up to 2.5K to shift and it will not hurt the MPG that much or clutch?
    I used to rev up 3K+ on my previous car but I'm trying to baby my new Taco + I thought it will save me some gas & clutch...:eek:
  7. May 18, 2011 at 11:06 PM
    TacomaBuzz
    CT
    When I'm at a stop light, Im idling in 1st gear rather than neutral.
  8. May 18, 2011 at 11:11 PM
    kwelhand
    ic... thanks. :)
    So apparently, you shift into 1st while stopping as a engine brake and ready to launch when the light turns to green without shifting again?
    Sounds like a good idea.
    I'm getting old these days and my leg hurts if I keep depressing that clutch pedal too long.:rolleyes:
  9. May 18, 2011 at 11:16 PM
    TacomaBuzz
    CT
    The 1st gear is weird on these 2nd gens, it will not let you shift into 1st until you are almost completely stopped. And you can't force it or you'll screw up the synchros. I never shift into 1st until I'm completely stopped but I will downshift from 4-3, 3-2 if I want to save on the braking.
  10. May 18, 2011 at 11:18 PM
    ne0tas
    ne0tas Well-Known Member
    Erick Iglesias
    Duarte, California
    None. :[
    Shifting into first while moving? Isn't that really bad for the tranny?
  11. May 18, 2011 at 11:21 PM
    kwelhand
    Thanks for the .02 cents!:)
  12. May 18, 2011 at 11:23 PM
    TacomaBuzz
    CT
    yes, it is . At least on the Tacoma. Most cars will allow you to downshift into 1st if you are creeping along at a slow speed but the 2nd gen locks out 1st until you are stopped. Many people have noticed this.
  13. May 19, 2011 at 12:12 AM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    shouldn't be in first if you're rolling anyway, anyone can take off in 2nd ;p
  14. May 19, 2011 at 4:29 AM
    Tinfish
    Tinfish Active Member
    2013 Reg Cab 4x4 5spd
    Not on mine. I've read this often here, so I'm not doubting what people are saying -- but mine shifts like every other truck I've had, and you can get into first while moving (though you'd only want to if you were going slow, obviously). I don't know if there are actual design differences at play, or if it is just some combination of manufacturing variances and differences in drivers.
    Anyway, I probably shift between 2500 and 3000. The engine pulls ok from about 1500 but lower than that (or uphill, or with a load) you'll be lugging the poor thing.
  15. May 19, 2011 at 4:36 AM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    you hold the clutch in while at a stop light? i personally would not be holding the clutch in for a long period of time at a stop light.
  16. May 19, 2011 at 4:54 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    all you need to do is rev-match to get it into first if your going more thatn 5mph. by doing that your bringing everything to the same speed, doesn't really screw things up. plus its an aisin transmission, theyre pretty bulletproof anyway.
  17. May 19, 2011 at 9:01 AM
    TacomaBuzz
    CT
    It's a matter of preference, I know a lot of people that will do this. I don't think it hurts the clutch because I'm not moving.
  18. May 19, 2011 at 9:11 AM
    Fire Force
    Fire Force Well-Known Member
    Ian
    Houston, TX
    2010 4x4 SR5 TRD Offroad (mostly stock)
    Bull bar, UWS toolbox, Yaesu FT-8800R dual band ham radio
    I've noticed the thing about first gear, too... you basically have to be stopped to shift into first. The previous manuals I drove were a 95 Jeep Wrangler with the most sensitive transmission in the world (at least it felt that way to me at age 14) and a 99 F-350 dually that had all sorts of wiggle room for shifting and I never got that feeling with them.
    I hardly ever engine brake but it's something I need to start doing.
    I've driven manuals since I was 13 years old and there's still stuff to learn about them!
  19. May 19, 2011 at 9:33 AM
    kwelhand
    So true....:)
  20. May 19, 2011 at 9:38 AM
    808matt
    hawaii
    19 Ranger
    not too sure but i think i remember reading somewhere that holding the clutch in like that wears out something.
