New Taco and I'm already worried. Help please.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by marcosbullock, Nov 4, 2010.
  1. Nov 5, 2010 at 9:42 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Good point to go through a tank or two to see what is up.
    plus your driving vs the other person who put the 6500 on...who knows...
    doesn't the ecu learn your driving style?
    best of luck with your new truck, do not throw in the towel yet...you gotta post up some pics if you can of your new to you truck! :)
  2. Nov 5, 2010 at 9:52 AM
    benq
    benq Active Member
    Surprise, AZ
    2010 Doublecab, Shortbed, TRD Offroad
    Borla Turbo XL muffler TRD air filter
    newbee here...
    Do you have to somehow calibrate your speedometer/speed sensor if you are running bigger/larger tires? Could that be throwing off his gauges?
    Also is it possible the previous owner used a chip to change the fuel mix?
    My fuel gauge on my '10 DB 4x4 also starts to dip below Full after 20-30 miles
    my 2cents
  3. Nov 5, 2010 at 12:28 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    nah, toyota keeps their ecu's locked up tighter than a frog's ass :D
    OP, I'd try resetting the ecu and top off the tank and see what happens then.
  4. Nov 5, 2010 at 1:49 PM
    Rodallg
    Rodallg Well-Known Member
    CA
    Sounds like what my 09 is getting, after owning it for less than a month I have been getting 20 - 21 mpg consistently.
  5. Nov 5, 2010 at 1:51 PM
    militaco
    militaco Well-Known Member
    Hawaii
    2009 Double Cab, '99 Regular Cab
    exactly....Although the numbers the OP has posted seems a little disproportianate....try filling up a new tank and seeing from there, if still dissatisfied, go out a buy a prius.
  6. Nov 5, 2010 at 9:48 PM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    city driving the gauge starts to move around 20-30 miles. Highway driving I have gone 50-60 miles before the gauge starts below the full line.
  7. Nov 5, 2010 at 11:53 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    well, how big are those tame tires? does it also have 5.10 gears? Does it have a hole in a piston? If you're worried, get it checked by someone that knows.
  8. Nov 6, 2010 at 12:37 AM
    detnight
    detnight Well-Known Member
    David
    Texas City ,Texas
    Texas Edtion Sport Super White
    Bed cover, Borla exhaust,20in wheels The TEXAS edition
    MY 09 gets 15-19 in town and 21-22 on the highway. I get 17 with my 10x5x6 cargo trailer loaded with my daughters stuff in it. I have 13000 miles on it
  9. Nov 6, 2010 at 11:28 PM
    marcosbullock
    marcosbullock [OP] Active Member
    Marcos
    Texarkana, Texas
    09 Tacoma Prerunner
    I did the math. I'm getting about 10 miles to the gallon. This can't be right.
  10. Nov 6, 2010 at 11:37 PM
    kcrob1
    kcrob1 Choot It!
    Casey
    Montgomery, TX
    TRD SPORT CC/LB
    Adjustable Billies, Debadged, Painted emblem on grille Kenwood Double din, polk components, co-ax, polk 8" sub & polk amp, TSB springs, 6000K hids, FJ Wheels
    I am getting a solid 19.4 to 19.6 on every fill up. Although its all stock there is no way "tame" tires would do that. I would have the stealership check it out. In the meantime try changing the fuel filter. Obviously it sat for a while and may have had condensation built up in the tank or something and its wrecking fuel mileage. I'm used to diesels and this is always the first thing you do so if its not that way with these just call me out
  11. Nov 7, 2010 at 12:20 AM
    toothaker1219
    toothaker1219 Well-Known Member
    whats your height, climate and driving habits like (alot of traffic or piddling around town)? These can all affect your gas mileage.
    Let your truck idle, stand behind it and get a whiff of the exhaust, If its real pungent it means your running very rich. Or if you have puff of blue smoke after crank up that could also be a sign that your running a little rich.
    Mass air flow sensor wouldn't have anything to do with it? My Tahoe is like that now, but is only messing with the RPMs and a bit of my fuel economy.
  12. Nov 7, 2010 at 1:31 AM
    island808
    Jedediah
    hawaii
    Exactly...
    You are calculating it based on the odometer and not the fuel gauge. Not to be insulting, but I've known people that think the fuel gauge tells them how much gas is in their car. It doesn't.
    Now, i did just "fix" a guy's volkswagen fuel mileage problem in another forum. He was diagnosing all over the engine and complaining about the fuel mix in his new home town after driving cross country in his bug. Engine seemed fine.
    My guess (mostly because everything else had been diagnosed out)
    .. bad wheel bearing...
    Tuned out I was right; he had a bad wheel bearing which in turn was causing plenty drag, but it also threw off the rear axle alignment enough where the drum was dragging as well. Was getting less than 20mpg in a bug he claimed usually got 30+
  13. Nov 7, 2010 at 1:48 AM
    island808
    Jedediah
    hawaii
    Black smoke should be rich.. and yea, it'll make your eyes water.. blue would be a little leaky valve seal (most likely).
    Thing is, most any burning condition that would be coming OUT of the engine should throw a code from the O2 sensor. Though it might not bring up the cel yet. Losing 25-50% of your mileage on a poor mix condition should quite noticeable in driving: noise (knock), smell, response, heat. I guess a stuck VVT could do it.. they used to be prone to failure due to poor oil maintenance.
  14. Nov 7, 2010 at 4:58 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    Mine fills up past the full mark and doesnt drop below until about 60 miles later. I dont know that doesnt sound right.
  15. Nov 7, 2010 at 6:49 AM
    #35
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Disconnect your battery for a few min to reset the ecu, go through a few tanks while it learns your driving habits, see if that fixes it?
  16. Nov 7, 2010 at 2:25 PM
    #36
    marcosbullock
    Marcos
    Texarkana, Texas
    09 Tacoma Prerunner
    More details. It's got a 3" spacer lift, 17" wheels, and 265/70/17 Michelin LTX A/S tires. Is this setup my problem?
    Resetting the ECU tonight and I'll see if that helps.
  17. Nov 7, 2010 at 4:00 PM
    #37
    kcrob1
    kcrob1 Choot It!
    Casey
    Montgomery, TX
    TRD SPORT CC/LB
    The tires on mine are 265/65-17 from the factory so its not like you are running anything noticably bigger than factory tires. That shouldn't affect it at all
  18. Nov 8, 2010 at 12:09 AM
    #38
    island808
    Jedediah
    hawaii
    you're sure no one effed with the gears?
    I don't know why they would in a pre-runner.. but they could have.
  19. Nov 8, 2010 at 2:05 AM
    #39
    billabong
    billabong Well-Known Member
    Bill
    Antelope Valley
    Silver Streak- PreRunner/TRD Sport
    Anti Theft tail gate mod, Locking gas cap, Tint, Flash Light on seat,TSB rear springs, OME 884 springs, 5100 shocks Eye lids.
    Here in Ca, I have tried ARCO gas. I was at a stop light and noticed
    the gas gauge dropping. My gas mileage had dropped enough for me to worry to
    the point if I was going to make the next town. When I use top tier gas
    lasted improved. I use 87octain
  20. Nov 8, 2010 at 5:38 AM
    #40
    BeardedWeirdo
    BeardedWeirdo Junior Mint
    Texas
    2010 AC SR5 PreRunner
    Barcelona Red Pop & Lock, Tint, New Shoes, Removed Rear Headrests, Grille(in the works)
    I filled up yesterday and drove 66 miles home on the highway and my fuel gauge is still slightly about the FULL line.
