New Taco Guy! RPMs seem high?!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NFLDTACOTACO, Nov 23, 2023.
  1. Nov 23, 2023 at 12:23 PM
    NFLDTACOTACO
    NFLDTACOTACO [OP] Member
    2021 White Tacoma TRD Off-Road
    Hello Tacoland,
    I joined this community on the recommendation of some friends. I'm actually posting on behalf of my dad, who isn't as computer-savvy as he used to be!
    He recently purchased his first Tacoma (2021 with 50,000kms) and has noticed that the MPG is higher than what other sources had led us to expect. He's mentioned that the RPMs seem unusually high, especially compared to his previous V8 truck. For instance, the RPMs are between 1000 to 1200 in park or neutral, and drop to around 500 when stopped in Drive or Reverse. This striked him as odd. Additionally, there was an instance when, while going uphill on cruise control with the speed set at 102 KM/H, the RPMs shot up to 4100 and remained there for about 10 seconds after the road had leveled off.
    His previous V8 truck rarely exceeded 2000 RPMs.
    Despite this, he loves the truck! We just thought these observations were unusual and are curious to know if any experts here can offer some insights. Thanks in advance!
    Cheers!
    NFLDTACOTACO
  2. Nov 23, 2023 at 12:27 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    The Tacoma has a v6 (or a I4).
  3. Nov 23, 2023 at 12:28 PM
    NFLDTACOTACO
    v6! Thanks gudujarlson
  4. Nov 23, 2023 at 12:29 PM
    gudujarlson
    Minnesota
    Just politely pointed out the obvious. Cheers. Happy thanksgiving!
    NFLDTACOTACO[OP] likes this.
  5. Nov 23, 2023 at 12:31 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    normal, this engine makes it's power in the upper RPM range. No point in even comparing to a V8, or a vehicle that is 7-10 year older,, things have changed.
    Tell him to fill it with gas, do regular maintenance, and enjoy it,,, don't overthink it. It's not perfect, but it's pretty darn good,, just very different from back in the day.
  6. Nov 23, 2023 at 12:32 PM
    NFLDTACOTACO
    Thanks for the helpful information Chew. I will let him know! Appreciated.
    Chew[QUOTED] likes this.
  7. Nov 23, 2023 at 12:32 PM
    NFLDTACOTACO
    Lol. Ok! Good to know, sir.
  8. Nov 23, 2023 at 12:37 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    you bet, I hope he enjoys!
    BTW: before you convince yourself the little V6 is gutless, take it out and floor it,,, let the RPM's bounce off the top the red range, and you will most likely change your mind.
  9. Nov 23, 2023 at 12:40 PM
    gudujarlson
    Minnesota
    The first time I floored my 2016 AT to make a pass it scared me.
    The only comparable car I’ve owned is a 90’s Mitsubishi mirage that was a cheap rocket. I think the 0-60 was around 7s and on par with the taco. The taco is so much heavier and the v6 roars unlike a 2L 4 banger
    Ok I admit to never owning any fast cars.
    Stevie17 and NFLDTACOTACO[OP] like this.
  10. Nov 23, 2023 at 12:41 PM
    NFLDTACOTACO
    Chew! Dad wanted to ask more
    "Interesting, thanks. My last truck was a 2020 GMC AT4, which isn't exactly from 'back in the day'. What I'm curious about is why the engine revs higher at idle than when it's in gear. Higher revs typically mean increased fuel consumption. I do understand that a smaller engine often needs to rev higher to achieve the same amount of work. So it's not strange for the engine to rv twice as high at idle than in gear"
    FYI - Neither of us are experts on trucks, so we're just trying to learn
  11. Nov 23, 2023 at 12:42 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Drive it where it likes to rev
    don’t low rpm lug these engines.
    NFLDTACOTACO[OP] and Pista1 like this.
  12. Nov 23, 2023 at 12:47 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    ahh gotcha,, yeah that is not old at all. Sorry to be presumptuous,, we get a lot of folks here comparing 20-30 year old tech, and that simply isn't relative.
    I don't know why it idles higher, mine does it. I can however assure you,,, Toyota engineers have eeeked any and all fuel savings and reduced emissions out of this thing, that they can. If it was as simple as turning down the idle to get better MPG's, they would have done that in the first hour of tuning, before anyone even saw or heard of this truck. Often times, I think it has to do with getting the catalytic converters warmed quickly, to reduce emissions.
    Sorry dad, that's all I got,, but we all know you have to keep the big GOV and it's 3-4 letter agencies happy,,, or else.
  13. Nov 23, 2023 at 1:00 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    It should be idling under 1k RPM once things are warmed up. Cold idle will be higher than normal but once coolant temps are up RPM should settle down.
  14. Nov 23, 2023 at 1:04 PM
    NFLDTACOTACO
    Chew,
    His closing words "that catalytic converter thing could be a plausible explanation. I won't be using the remote start anymore"
  15. Nov 23, 2023 at 1:04 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Some engines get their torque at 2000-2500 rpm, especially modern diesels and many old school V8 gas engines. Most modern gas engines need around 3500 rpm but will often have all the power they need unless loaded/pulling heavy closer to 2000 rpm. That includes older Tacoma's. The engine in 3rd gen Tacoma's needs around 4500 rpm to get its power. It simply has to be running faster and in lower gears to get power.
    It's more complicated than that. The engine has a range of rpm's where it is most efficient. If the engine isn't spinning fast enough it is actually working harder and using more fuel.
  16. Nov 23, 2023 at 1:28 PM
    NFLDTACOTACO
    Thanks Marshall. I passed it on. Gave him the login details if he wants to come in and chat.
    Out2gtcha likes this.
  17. Nov 23, 2023 at 1:56 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    oh yeah,,, good point! Using remote start on any vehicle will drastically drop MPG's.
    I still use it, but conscious of it's impact.
  18. Nov 23, 2023 at 2:06 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    This and if defrost, or a/c is on, it will idle at a higher rpm.
