New Taco jittery ride
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TJH1224, Sep 23, 2021.
  1. Oct 5, 2021 at 12:16 AM
    #41
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    As I drove mine, I went from too stiff, to a little soft lol. They break in big time. I've got airbags now, I can have it as stiff as I like, or as soft.
  2. Oct 5, 2021 at 6:15 AM
    #42
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Isn't that true for every man???
  3. Oct 5, 2021 at 7:39 AM
    #43
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    I would start with dropping the tire pressure. Whoever did my PDI decided to set the tires to 40 psi (Must be preset on air compressor) and the truck rode rough. I dropped the pressure down to 32 or 33 or whatever my spec is and it drove much nicer. Funny a dealership would allow this to happen as many may assume its the truck considering its brand new and be unhappy.
  4. Oct 5, 2021 at 7:43 AM
    #44
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    An educated consumer would check tire pressure daily since we essentially have it in the dash. That said totally unacceptable from the dealer
  5. Oct 5, 2021 at 7:49 AM
    #45
    CalcityRenegade
    2023 T4R ORP KDSS
    Assuming you have the feature. Both my 2016 and 2020 have a simple dummy light if the tire pressure drops below a certain threshold. No actual reading on the tire pressure. Quite common with Canadian Tacoma's from my understanding. Additionally while TPMS is usually reliable there can be a light accuracy variance. I only really trust a good old handheld tire pressure gauge.
  6. Oct 5, 2021 at 7:54 AM
    #46
    Dual Port
    Dual Port Active Member
    B. D.
    21 Tacoma Silver V6
    If it's empty 32PSI is too high, that's the spec for a loaded truck, if it's empty you should run much lower. IIRC when I had my truck weighed it was 4700 with 2050 on the back axle. The load charts I saw didn't even go as low as 1025 on a tire, they stopped at 1700lbs with a tire pressure of 24PSI at that load. I run 26-27 (just enough to keep the TPMS light off) when empty.
    TJH1224[OP] and AmateurTaco1313 like this.
  7. Oct 5, 2021 at 9:06 AM
    #47
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    I just needed some assistance with it :/
