New Taco owner, lookin' to lift!
Discussion in '1st Gen. Tacomas (1995-2004)' started by comanche5L, Jun 26, 2010.
  1. Jun 26, 2010 at 5:51 AM
    comanche5L
    comanche5L [OP] Member
    Fall river, Nova Scotia
    Daystar 3.5"
    Hey guys ive driven jeeps all my life, but just picked up a 2000 taco 2.7L reg cab from florida and plan on getting a lift under it. Just curious on what you guys are running for ~3" lift?
    i was either leaning towards the skyjacker 3" with full strut and AAL, or the daystar 2.5" + 1" BL.
    Open to opinions for sure! would like to get at least a 31" KM2 under it, or possibly a 32" MT.
    also will i need to get another set of rims with more offest so the tires wont rub?
    Thanks guys, sorry for all the questions im sure you've heard 10000 times before!!
    Heres the old girl, just turned 100 000 miles:
  2. Jun 26, 2010 at 5:58 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner
    if you can find some bilstien 5100s with a aal out back and if you 31 wont rub but you will need wheel spacers to run 32 if you actually wheel it
  3. Jun 26, 2010 at 7:02 AM
    BajaTaco96
    BajaTaco96 Well-Known Member
    Silver Springs, FL
    1996 Toyota Tacoma 4wd, 3" suspension lift
    K&N, ToyTec 3" front spacers, 3" Fabtech AAL's, Flowmaster exhuast, no cat, Exedy Stage 2 clutch
    I've got ToyTec front 3" spacers and a 3" AAL out back, I've got more than enough room for my 31" KM2s. I wish I would have went with some kind of 32" tires, I ran 33x12.5 perfectly fine with very minor rubbing under flex.
  4. Jun 26, 2010 at 10:42 AM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    Look for a Toytec lift, or for Billy 5100. Both affordable ways of gaining a little lift.
  5. Jun 26, 2010 at 11:08 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    my 2005 2nd gen has more miles than your 1st gen lol!
    Great lookin truck bud, all the options listed above are great choices to lift the Taco :cool:
  6. Jun 26, 2010 at 8:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Believe it or not but you might be able to run 32's with minimal rubbing with no lift, though I wouldn't recommend that if your intent is to take in on the trail. You certainly do not need 3" of lift to easily clear 32's.
    Welcome to a whole new world of Tacomas and TW.
  7. Jun 27, 2010 at 10:42 AM
    comanche5L
    Daystar 3.5"
    thanks for all the info guys, i really like the look of that toytec one, i might see if i can switch the daystar for that one instead. i dont plan on wheeling this one too seriousally ill use my old jeep comanche for that.
    ill post some before and after pics once i get it installed.!
  8. Jun 27, 2010 at 11:24 AM
    BajaTaco96
    Silver Springs, FL
    You'll like the ToyTec, can't go wrong with it and it's damn sturdy. I had a hairline crack ran down the center of my daystar leveling kit after a year of heavy wheeling.
  9. Jul 6, 2010 at 5:02 PM
    kyle39
    kyle39 Reppin' BC
    Kyle
    Vancouver BC
    04 Tacoma Trd
    Deck plate mod, rhino lined, A.r.e. flush glass shell, 265/75/16 Duratrac's, MB72 rims, Full OME lift, Dakars in the rear, Tint allround
    You running stock UCA w/ ur 31s??
