New Taco Owner, so here is the plan...
Discussion in 'Suspension' started by dtrujillo63, Sep 1, 2008.
  1. Sep 1, 2008 at 11:13 PM
    dtrujillo63
    dtrujillo63 [OP] Well-Known Member
    Denny
    Los Angeles
    08 Tacoma DC 4x4 Sport
    So here is the plan…
    3" Toytec Spacers in the front, AAL in the rear, Diff Drop, 285/70/17 BFG ATs on stock TRD sport wheels.
    Now I have a couple questions. Will I have any problems using the stock wheels? Will my towing capabilities be affected at all? How much will my ride quality decrease? Will my MPG decrease? If so, around how much?
    Sorry for all the questions... I'm very new at this :confused:
  2. Sep 1, 2008 at 11:25 PM
    MyTaco
    MyTaco Well-Known Member
    Az
    08 Prerunner & 2017 SR
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    Those tires will rub your UCA's on stock wheels. you will have to get aftermarket wheels with less back spacing like 4.75" or 5".
  3. Sep 1, 2008 at 11:26 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    your tires should be fine for the stock sport rims but will rub uca's, mpg will decrease might not be alot though, dont know by how much.
  4. Sep 1, 2008 at 11:39 PM
    dtrujillo63
    Denny
    Los Angeles
    What are my options? Should I get smaller tires like some 265/70/17s or can I use some type of wheel spacers? If I go with the smaller tires, should I go with some 2" or 2.5" spacers instead? I want to make sure the height looks good with whatever tires I go with.
  5. Sep 1, 2008 at 11:41 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    you will need a 1/2" spacer to clear the UCA.
