New Taco, suggestions for towing and rear sag?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fox Mulder, Dec 23, 2021.
  1. Dec 24, 2021 at 8:43 AM
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    Yeah man, no problem at all I wish you well in your towing extravaganzas!
    It’s definitely a balance of ride quality and capability.
  2. Dec 24, 2021 at 12:14 PM
    seang
    seang Eternal Noob
    TX
    17 White Off Road
  3. Dec 24, 2021 at 12:54 PM
    Paddy1337
    Paddy1337 Well-Known Member
    Carroll, MD
    '21 DCSB TRD-OR, '20 Sequoia TRD-Pro
    I had air bags on my super duty, absolutely loved them. I'm not sure that experience translates all that well to the Tacoma, though.
    Fox Mulder[OP] likes this.
  4. Dec 24, 2021 at 12:57 PM
    Pinion
    Pinion Well-Known Member
    Drew
    Brookings Oregon
    2020 DCSB limited 4x4
    Hellwig EZ-990 helper springs is what I use, 2000lb rated, easy install and remove if desired. About $220
    With a good wdh
    Mark77, Fox Mulder[OP] and wiljayhi like this.
  5. Dec 24, 2021 at 3:23 PM
    Fox Mulder
    Fox Mulder [OP] Well-Known Member
    22 Army Green TRD Sport DCSB
  6. Dec 24, 2021 at 3:25 PM
    Fox Mulder
    Do you notice any difference in the ride when you’re unloaded? Seems like the Hellwigs might be a good way to go.
  7. Dec 24, 2021 at 3:26 PM
    Pinion
    Drew
    Brookings Oregon
    Ride still good, if adjusted properly they need load to be effective
    wiljayhi and Fox Mulder[OP] like this.
  8. Dec 24, 2021 at 3:31 PM
    Fox Mulder
    I read about pinning the trans cooler on 3rd gens, I didn’t realize that changed for the newer ones. I will definitely look at my options for monitoring trans temps, thanks!
    wiljayhi[QUOTED] likes this.
  9. Dec 24, 2021 at 3:31 PM
    Fox Mulder
    Awesome, thanks!
  10. Dec 24, 2021 at 3:36 PM
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    OP I sent you a PM.
  11. Dec 24, 2021 at 4:48 PM
    Cowdog
    Cowdog Well-Known Member
    This is the route I plan on going.
  12. Dec 25, 2021 at 9:13 AM
    Luster82
    Luster82 New Member
    2016 Tacoma SR5 4x4
    To many to list
    I wanted to help with towing so I started with airbags, then new struts, new leaf springs, re-geared to 5:29, and even WD hitch. Each thing has helped make the towing better. Saving for a supercharger next.
  13. Dec 25, 2021 at 9:26 AM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    Personally, I would absolutely get a WD hitch with an anti-sway bar. Rear sag is not the only issue.
  14. Dec 25, 2021 at 9:31 AM
    Fox Mulder
    Lol, maybe I should just start with the supercharger!
  15. Dec 25, 2021 at 9:34 AM
    #35
    Fox Mulder
    You have fine taste in trucks, so I think I’m going to take your advice. I think our trucks are twins except I have the predator tubes.
  16. Dec 25, 2021 at 9:49 AM
    #36
    H6G
    H6G Well-Known Member
    Far from home...
    ‘18 Blk. Pro/ ‘17 GT350
    '22 Pro suspension/ Custom Deaver springs/ ECGS and...
    @wiljayhi
    Thank you for the info regarding Hellwig helper springs. Any noise from these, when not loaded?
  17. Dec 25, 2021 at 9:53 AM
    #37
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Neither the helper spring nor the leafs make any noise whether loaded or not. (Maybe I got lucky?).
    Fox Mulder[OP] and H6G[QUOTED] like this.
  18. Dec 25, 2021 at 9:58 AM
    #38
    H6G
    Far from home...
    Thank you...
  19. Dec 25, 2021 at 10:30 AM
    #39
    wiljayhi
    Jim
    3G, Tuned
    Your welcome. :hattip:
  20. Dec 28, 2021 at 8:59 PM
    #40
    Fox Mulder
    I’ve been looking at the RAS, how much squat does it take out on your Tacoma? Seems like it could be a pretty good solution.
