New Tacoma, 1000 miles oil change?
Discussion in 'General Tacoma Talk' started by manoweb, Aug 6, 2023.
  1. Aug 6, 2023 at 11:34 PM
    manoweb
    manoweb [OP] Member
    I'm picking up a new Tacoma before they stop making the 6 cylinders. I will travel across the nation to get the one I want and then drive it back home, about 2500 miles. I've heard that many people like to perform an oil change at 1000 miles. I'd be in Cheyenne WY at that point. Anybody knows a very reputable place around there to perform the oil change? Or should I just drive home and do it myself at 2500. Opinions?
  2. Aug 6, 2023 at 11:41 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You can change the oil early if you want or just change it at the factory specified interval and be fine as well. Stop at any Toyota dealer along the way and get it done if you want to.
  3. Aug 6, 2023 at 11:46 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Just drive it home and do it yourself.
    Deeahgee and TacoPacific like this.
  4. Aug 7, 2023 at 12:02 AM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Lot's of strong opinions on this subject. Do what you are comfortable with. I was comfortable with 1200 miles.
    TacoPacific likes this.
  5. Aug 7, 2023 at 1:03 AM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    I only had to drive 300 mi to go pick up a v6. For 1k oil change I asked for a 5k service so they would look over the other fluids, can't hurt (hopefully).
    If you are considering a 1k oil change be sure to consider the 10yr/125k mi Toyota platinum warranty from Kansas for $1795
  6. Aug 7, 2023 at 1:45 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Do the rear diff oil, too.
  7. Aug 7, 2023 at 5:17 AM
    manoweb
    manoweb [OP] Member
    OK thanks!
  8. Aug 7, 2023 at 5:22 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    I'd be honest, every single new car I've ever bought, I've always done the oil change at the factory recommended interval. I don't know anyone that had engine problems from a brand new vehicle bc they didn't change their oil in the first 500-1000 miles of ownership. This isn't a race motor or an old school big block. But what do I know, I just sell wheels for a living o_O.
    Personally, I think you'll be fine driving it back home and getting it done there.
    Deeahgee and wayupnort like this.
  9. Aug 8, 2023 at 7:10 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You can DIY it in a Walmart parking lot :D
  10. Aug 8, 2023 at 7:39 PM
    manoweb
    manoweb [OP] Member
    A vehicle with a regular oil filter yeah, but the complication they used for this model, no way
    I guess I could theoretically do the oil change only and leave the old filter, but it's not worth it as we.have determined.
  11. Aug 8, 2023 at 7:40 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    It’s not anymore difficult to change the filter in a third gen compared to any other vehicles.
    wayupnort likes this.
  12. Aug 8, 2023 at 10:00 PM
    manoweb
    manoweb [OP] Member
    Wait, I thought the Tacoma had a filter that requires to go under the engine in order to swap it. Am I learning it's on top of the engine, easily accessible just by popping the hood? Good news thanks!
  13. Aug 8, 2023 at 10:02 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    No, it’s underneath like most engines. You have to go down there to drain the oil anyway so it’s not a big deal. And it’s a truck so you don’t need jacks to fit under to work unless you’re a fat dude.
  14. Aug 8, 2023 at 10:14 PM
    Fire
    Fire Well-Known Member
    Humboldt County
    2021 Toyota Tacoma with Poverty Package.
    Steering wheel
    Quickest break-in period ever. I suppose your trek will put it through the wringer for a proper multi load break-in. Personally, I’d just drive it home and get the oil changed then if you’re determined on getting a pre 10k oil change.
  15. Aug 8, 2023 at 10:18 PM
    tacomadome
    tacomadome Well-Known Member
    I bought the $60 set of tools that includes the special wrench for the filter housing and the EZ-mode pre-drain hose attachment thing: https://www.amazon.com/gp/product/B0791MWXDC
    I took it to a pay-to-use lift around 1000 miles and did it myself and sent a sample to Blackstone. I'll be doing it again at 5k with another sample. I was told by a random Toyota parts guy that it has 'break-in oil', but didn't believe him because 10k is too long for that sort of thing in my mind. Blackstone said the viscosity of the oil in the truck was 5w-20, which differs from the 0w-20 they recommend, so maybe he was right?
    Either way, there are members on this forum with 200-300k who have mentioned changing oil at 1k, and it seemed like it couldn't hurt to do.
    tacoma_ca likes this.
  16. Aug 8, 2023 at 10:34 PM
    manoweb
    manoweb [OP] Member
    I was thinking to go with 30 weight oil; usage of 20 weight is only because back in the day Obama mandated better gas mileage, the side effect of course is less longevity of the engine
  17. Aug 8, 2023 at 10:39 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    drizzoh and Lawfarin like this.
  18. Aug 8, 2023 at 10:53 PM
    tacomadome
    there are multiple members of this forum pushing 300k that have only ever used the Toyota 0w-20 this motor is specced for. I don't think anyone has seen any extended life by going off-book with oil weight but its your truck.
  19. Aug 8, 2023 at 11:55 PM
    El Reymono
    El Reymono Well-Known Member
    Raymond
    East Providence, Rhode Island
    2010 2.7 regular cab manual Tacoma
    the oil they put in at the factory isn't just oil. it has additives like zinc and other compounds that are meant to help in the break in period. don't change your oil early.
  20. Aug 9, 2023 at 1:30 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
