New Tacoma, 1000 miles oil change?
Discussion in 'General Tacoma Talk' started by manoweb, Aug 6, 2023.
  1. Aug 9, 2023 at 1:40 AM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    Engine oil and engine oil filter is cheap. Compared to engine spin bearing, burn bearing. Can do oil and filter change at 1,000 miles, but beyond 5,000 miles is pushing it. Also, every six months, or every 5,000 miles, whichever comes first, the oil change.
  2. Aug 9, 2023 at 2:09 AM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    When the 5th gen EV Tacoma comes out in 10 years, we can stop having this conversation. We can talk about how many miles per 1.21 gigwatts we get or how we found a deal on a 2035 Tacoma for under $100k.
  3. Aug 9, 2023 at 8:54 AM
    manoweb
    manoweb [OP] Member
    Electric cars still have tranny and differential fluids that are important to change.
  4. Aug 9, 2023 at 9:37 AM
    tacomadome
    tacomadome Well-Known Member
    Here's the Blackstone for the oil, Zinc is not particularly high although Silicon, moly boron and copper are:
    Every vehicle I've bought with a 'break-in' process has it outlined in the manual when and how to change the oil. Toyota just says to go easy on it for the first few thousand; if it were critical to break-in that this oil remain in the motor I would think they would say so. That said, it's a personal choice, I doubt waiting matters much.
    tacoma_ca likes this.
  5. Aug 9, 2023 at 9:42 AM
    STEELeR43
    Hawaii
    Maybe. I would never buy it. Can EV Tacoma handle crossing water? EV high maintenance?
    23MGM[QUOTED] likes this.
  6. Aug 9, 2023 at 9:49 AM
    SmoothTRD
    SmoothTRD Well-Known Member
    My first oil change is at 10k with synthetic
  7. Aug 10, 2023 at 9:25 AM
    Cyberfool
    Cyberfool Well-Known Member
    Jack
    Balto MD
    Um, no. At least some, most, maybe all electric vehicles do not have any kind of mechanical transmission and hence no transmission fluid.
    Electric vehicles are more different than most people think.
  8. Aug 10, 2023 at 9:29 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Hahaha. They sure don’t.
  9. Aug 10, 2023 at 9:54 AM
    manoweb
    manoweb [OP] Member
    Hello, why do you have to say this? Look it up, for example Tesla dual motors have a 1 speed (mechanical) transmission with a ratio of 9.71:1 in the back and 9.34:1 in the front, so they can optimize the efficiency bands. Nissan, VW, have equivalent speed reducers, that manufacturers try not to call transmissions for marketing reasons. Some rare, higher performance ones even have multi-gear transmissions (Porsche). I have never heard of any direct drive electric car, wheels turn way too slow for an electric motor to be in the optimal efficiency range. And unless we are considering some exotic electric car that has one motor (and tranny) per side, there is going to be a mechanical differential. And, given that electric motors tend to have high torque compared to endothermic engines for the same power class, the forces on those gears are going to be higher and fluid maintenance even more important.
  10. Aug 10, 2023 at 9:56 AM
    manoweb
    manoweb [OP] Member
    "Ahahahah" drive unit oil change on Tesla:
    https://youtu.be/JG9S2hByn-Q
    Make sure to watch at the end the oil coming out of the drain exactly like any other car. Even the housings are the usual cast aluminum
  11. Aug 10, 2023 at 10:12 AM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    I like to wait until 3kmi. for the first engine oil change. Gives you some time to gather all the tools. Every 5k after that. Some old habits are hard to break... Actual oil & filter change is a piece of cake. Make sure you put the big o-ring in the proper groove... If unsure, read or ask !
    manoweb[OP] likes this.
  12. Aug 10, 2023 at 1:33 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Fumoto valve, I just installed the F133S. Instead of oil gushing out you move a small lever and control the oil draining. But you need to first do an oil change with uncontrolled drain. The S has a short nipple (attach a hose to direct the oil drain) or long nipple, or get one with no nipple to break off.
    The funnel shown for the Motivx has a feature that is not obvious ... normal funnels do not lock into the oil fill neck. The Motivx funnel does more-or-less lock into the Tacoma fill port for focusing on management of 5-quart oil bottles.
