New Tacoma Help.
Discussion in 'New Members' started by JMacSF, Jun 11, 2019.
  1. Jun 11, 2019 at 4:21 PM
    JMacSF
    JMacSF [OP] Member
    I am getting ready to move out to Montana on the 1st of July and will promptly be looking for and buying a Toyota Tacoma. This is a 6(ish) year dream that is about to come to fruition and I want to do it right. I am between two options and have a few questions, option number 1: buy a TRD pro and keep it pretty much the same. Option 2: buy a TRD off-road, and switch out for the fox internal bypass shocks that come standard on the PRO and put new wheels and tires on. There are a lot of reasons I'm having trouble and I'll do my best to explain and keep it short. I like the PRO, A LOT, except for the width of the wheels, I wish they were a little wider for a bit "meaner" stance, so that's why option two is an option, I could put those fox shocks on and put my own tires and wheels on, plus a bit more of a lift. (through the dealer as to keep it all under warranty)
    Second issue is what I should be paying, I've been researching a bit, but was curious if anyone had any information on that, so I don't get taken to the cleaners. Any guidance would be greatly appreciated. Thanks.
  2. Jun 11, 2019 at 4:25 PM
    Bigdaddy4760
    Maner
    Poolville Texas
  3. Jun 11, 2019 at 4:37 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW...location will be a factor as far as price goes. What does the pro have that you can’t live without?
    Taco critter and irayfz6 like this.
  4. Jun 11, 2019 at 4:42 PM
    JMacSF
    JMacSF [OP] Member
    The FOX internal bypass shocks, whatever model I get, those are the shocks I want. As far as ive seen otherwise, nothing else on it is so killer that i need it.
  5. Jun 11, 2019 at 4:45 PM
    ClubSoda
    ClubSoda Well-Known Member
    Harry
    2018 Cement Tacoma TRD Off-Road
    Welcome to TW! This is a similar question I had when buying the truck, and I ultimately decided on the Off Road. Honestly, with the money you save, you can customize the truck in the exact way you need to. You really wont miss out on any crazy features the Pro will offer. If you are looking for a truck to just have 90% of the work done for you, get the Pro and get better tires. Price wise, it was about a 12k difference between the Off-Road and Pro models (38k out the door for my truck, they wanted 50k out the door for the Pro).
    For me, I really love customizing my truck the way I think it should have been, especially with Meso's products :spending:. At the end, it's really a matter of practicality and if it's worth the extra cost for things that you can do later. :headbang:
    PS: Autotrader also has an article on this - https://www.autotrader.com/best-car...coma-trd-pro-whats-difference-281474979873086
  6. Jun 11, 2019 at 4:48 PM
    JMacSF
    JMacSF [OP] Member
    One concern I had was voiding warranty with aftermarket parts, is this a common thing?
  7. Jun 11, 2019 at 4:54 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    I wouldn't be surprised if Toyota would frown upon putting pro shocks/struts on an offroad. It isn't how it came from the factory so said warranty might be voided just the same as with going aftermarket. That being said this is just an assumption on my part so take it with a grain of salt.
  8. Jun 11, 2019 at 4:56 PM
    ClubSoda
    Harry
    I always assumed they just wouldn't cover that specific changed modification. I wouldn't think they'd void engine failure as a result of a 2 in" lift.
  9. Jun 11, 2019 at 4:56 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    Good point.
    Taco critter, JMacSF[OP] and irayfz6 like this.
  10. Jun 11, 2019 at 5:10 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    PRO’s generally come with a dealer markup (YMMV). If you are concerned with function get the OR and build it up. If you got to have the PRO get a PRO.
  11. Jun 11, 2019 at 5:28 PM
    buckhuntin-tacoma
    Dennis
    Quincy IL
    Typically, to void a warranty, the part that failed has to be from a direct result of something you did or altered. If you alter the suspension and then you have electrical or engine problems that will still be covered.
  12. Jun 11, 2019 at 9:29 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
    Taco critter and JMacSF[OP] like this.
  13. Jun 11, 2019 at 9:31 PM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    Welcome!
    Taco critter, irayfz6 and JMacSF[OP] like this.
  14. Jun 12, 2019 at 8:41 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
    irayfz6 likes this.
