New Tacoma isn't smooth slowing down, or when hitting brakes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tjaved22, Jun 6, 2021.
  1. Jun 6, 2021 at 6:01 PM
    tjaved22
    tjaved22 [OP] Well-Known Member
    Just picked up my 2021 TRD Sport 4x4 this Friday with 14 miles on it.
    When I drove it right out the lot, I noticed when slowing down with or without the brakes, there's a small stutter, even a vibrating feeling in the steering wheel.
    I drove it right back to the dealership and the sales rep said not sure what he could do other than set up an appointment with their service department. So I went on their website and set up an appointment for this Tuesday.
    Anyone have an idea of what this could be?
  2. Jun 6, 2021 at 6:36 PM
    In2Ndo
    In2Ndo Well-Known Member
    California
    MGM 2021 Tacoma TRD OR
    It’s probably just the truck down shifting . I think it started with the 3rd gens. I don’t remember my 2nd gen doing it. This trans are programmed to slow the truck down when you let go of the gas.
  3. Jun 6, 2021 at 6:42 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    did you test drive it first?
  4. Jun 6, 2021 at 7:05 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    FWIW, my 2nd Gen will downshift around 30 mph when slowing/coasting and foot off the throttle.
    It is noticeable, but not annoying. Its just part of the truck's personality.
    asuchemist likes this.
  5. Jun 6, 2021 at 7:13 PM
    Bishop84
    Bishop84 Well-Known Member
    It's a truck not a car.
  6. Jun 6, 2021 at 7:25 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I vaguely remember mine doing something similar a few times when I first bought it. Whatever it was it went away after a few hundred miles. Hasn’t happened since 7000 miles later. I figure just break in.
  7. Jun 6, 2021 at 8:05 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Two things... the Tacoma utilizes engine braking (google it) and
    It takes around one thousand miles before your brakes "bed" which can also be googled.
    Your fine.
  8. Jun 6, 2021 at 8:28 PM
    Mallrat60
    Mallrat60 Not all of us in CA are libs.
    Nor-Cal, Sacramento area
    2015 Dbl cab L/B 4X4
    ADS 2.5 #700 springs, RCI metal fab full skids, JBS UCA, OME rear leaves, Fab Fours front, and rear bumpers, BAMF Rock Sliders and other stuff
    3rd Gens have some issues. Check out the you tube video from the car care nut. The guy is a master Toyota tech. He has a video on the common 2016-2021 Tacoma problems. I will stick with my 2015 V6 for now.
  9. Jun 6, 2021 at 8:43 PM
    ethanolman
    ethanolman Active Member
    Just traded my 2019 ford ranger for a 2021 tacoma, try the brakes on a ranger, that is high anxiety hoping you stop the first few times
    Grindstone and davidstacoma like this.
  10. Jun 7, 2021 at 5:02 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Sounds the same as my 2020 sr5, but i didn't feel it through the steering wheel. At 1,500 miles it was totally gone. A buddies 2019 trd has the same issue to but very minor, plus its got another vibration that comes and goes at various speeds. He's complained to the dealer he got the truck from...they told him its fairly normal to that model. Its always been the same and hasn't gotten worse.
    On your truck try putting the transmission in neutral when it happens...when i did the stutter disappeared.
  11. Jun 7, 2021 at 5:06 AM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    2021 Pro not experiencing this
    2011 sport every now and then
  12. Jun 7, 2021 at 5:43 AM
    EL Taco Verde
    EL Taco Verde Well-Known Member
    2021 TRD Off Road
    Factory lift kit. Lomax tri fold Tonneau.
    I have a 2021 OR. with 300 miles on it, yes the truck does downshift shortly after I let off the gas. The 2016 Sport 4x4 I traded in did the same. Check the tire pressure. When I got mine from the dealer the tires were at 43psi , it picked up all bad spots in road and sent vibrations into chassis . Lowered air when I got home. Rides great now.
    plasticsnaks likes this.
  13. Jun 7, 2021 at 4:50 PM
    flacoloco
    flacoloco Well-Known Member
    tsb 0124-20
  14. Jun 7, 2021 at 4:59 PM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    Ok new rotors new pads new truck.
    I have no idea why people try to freak out new owners.
    Have you ever studied on bedding brakes?
    Basically there must be a smooth thin layer of brake pad material applied to the rotors and drums. This can happen slowly over time, or intentionally very quickly IF you follow instructions. If you are interested in learning more, private message me or mention me and I will link you to the information if you can't find it yourself.
    There is no reason to worry yet.
    TLDR Rotors rust, rotors and pads have to be bedded together.
  15. Jun 7, 2021 at 5:04 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Normal characteristics of the drum brakes they blow .
  16. Jun 7, 2021 at 5:07 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    there are at least 5 major components woking together
    2 front wheels...........probably Not locked
    front drive axles
    transfer case
    rear axle with whatever traction setup
    rear wheels.....................NO 1 makes a 4x4 that doesnt have tolerances
    a thousandth at each location AddZ UP !!!!!
    if only it wasa thousandth at each location...................................
    U can put it on a lift all wheels up
    start twistin on sh!t
    got to have s o m e s l a ac k
